Should I….
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bdk437, Aug 19, 2024.
  1. Aug 19, 2024 at 8:20 AM
    Bdk437
    Bdk437 [OP] New Member
    Bruce
    2019 Tundra SR5 2wd Crew cab
    5000 series Bilstien shocks TRD sway bar
    Change my rear oil? I have 2019 SR5 2wd with 57k on it.
    KNABORES likes this.
  2. Aug 19, 2024 at 8:23 AM
  3. Aug 19, 2024 at 8:30 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    YES X2
    ZappBrannigan likes this.
  4. Aug 19, 2024 at 11:59 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    YES X3
  5. Aug 19, 2024 at 12:46 PM
    VUDUBLU
    VUDUBLU New Member
    David
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Ya I’ll take some of that. Don’t forget your gaskets for the drain/fill plugs
  6. Aug 19, 2024 at 1:21 PM
    RobertD
    Robert
    DFW, Texas
    What is rear oil? Are you asking about the rear diff?
    Shadowfax1 likes this.
  7. Sep 4, 2024 at 10:05 AM
    Bdk437
    Bruce
  8. Sep 4, 2024 at 10:40 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Yes. Less than an hour job. Make sure to break open the fill plug before the drain plug. Being in TX, you shouldn't have to worry about rust, but it's good practice to make sure you can fill it after draining.
    HulkSmurf14 likes this.
