Should both front wheels rotate freely if parked in 2Hi?
Discussion in '1st Gen Tundras (2000-2006)' started by Strangebird22, Aug 26, 2021.
  1. Aug 26, 2021 at 3:33 PM
    Strangebird22
    Strangebird22 [OP] New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    My searchfoo sucks so I'll just ask. If parked and shut off and left in 2Hi should the the front wheels rotate freely if only one side jacked up. In other words if say the right side wheel is off the ground, left side on the ground, should the right side rotate freely? Thanks!
  2. Aug 26, 2021 at 3:35 PM
    737fixer
    737fixer New Member
    absolutely
    Bear likes this.
  3. Aug 26, 2021 at 3:42 PM
    Strangebird22
    Terry
    Ohio
    Ok good. The reason I asked is because when I did my front brakes not too long ago I could have sworn that they did not turn freely and I was definitely in 2wd drive then.
  4. Aug 26, 2021 at 3:53 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    There is a good chance a piston in your caliper is sticking.
  5. Aug 26, 2021 at 4:45 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    There will be some drag from the brakes and the front diff/axle.
    Bear likes this.
