Shop says rear driveshaft can't be fixed
Discussion in '1st Gen Tundras (2000-2006)' started by postrophe, Jul 11, 2018.
  1. Jul 11, 2018 at 8:33 PM
    postrophe
    postrophe [OP] New Member
    I'm having a problem with a rear driveshaft in my 2003 tundra. Can someone direct me as to which forum I should post to.
    Thank you for your help.
    T-Rex266 likes this.
  2. Jul 11, 2018 at 8:35 PM
    Welcome from Texas, let's see your ride and what's the problem exactly?
    postrophe[OP] likes this.
  3. Jul 11, 2018 at 8:37 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Either grease zerks or drain and fill of the fluid.
  4. Jul 11, 2018 at 8:45 PM
    postrophe
    The cadan thing, rear driveshaft, shop says can't fix it. Need to know what's the best course of action. $1500 driveshaft is not an option.
  5. Jul 11, 2018 at 8:47 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
  6. Jul 11, 2018 at 8:47 PM
    Double cardan joint in middle?
    postrophe[QUOTED][OP] likes this.
  7. Jul 11, 2018 at 8:51 PM
    Welcome from CO.
  8. Jul 11, 2018 at 8:54 PM
    postrophe
    Yes, that thing.
  9. Jul 11, 2018 at 8:57 PM
    Yeah on my T100 I had same issue about 3 yrs ago, I couldn't find at dealership, juat that part, happened to find one at driveshaft shop for $400
  10. Jul 11, 2018 at 8:58 PM
    postrophe
    Funny TX and CO say hi. I have a house in TX, and I'm broke down in CO. Sup y'all.
  11. Jul 11, 2018 at 8:58 PM
    U from Texas or Co?
  12. Jul 11, 2018 at 8:58 PM
    postrophe
    Driveshaft or just that part?
  13. Jul 11, 2018 at 8:59 PM
    postrophe
    From Maryland, been living in TX., now just stuck in Colorado.
  14. Jul 11, 2018 at 9:00 PM
    postrophe
    Would like to find a parts truck nearby to get the driveshaft out of.
  15. Jul 11, 2018 at 9:01 PM
    Where Texas?
  16. Jul 11, 2018 at 9:03 PM
    postrophe
    Very top of TX. Hour and a half north of Amarillo.
    TXRailRoadBandit73 likes this.
  17. Jul 11, 2018 at 9:03 PM
    Was the shaft WITH cardan
  18. Jul 11, 2018 at 9:05 PM
    postrophe
    Was also considering going to machine shop with an aftermarket double cadan that is serviceable with standard size u joints and having them cut the old one off and weld the new one on. Does that sound possible?
  19. Jul 11, 2018 at 9:15 PM
    Not sure I was having trouble with the U joints in the cardan area late evening out of town for work happen to find a shade tree mechanic to slap on but he kinda messed up one of the slots where u joint goes through so I bought a new one shaft with cardan $400
  20. Jul 11, 2018 at 9:16 PM
    Dumas, Dalhart?
  21. Jul 11, 2018 at 9:16 PM
    Hope you can find you one
  22. Jul 11, 2018 at 9:17 PM
    postrophe
    Dulhart
  23. Jul 11, 2018 at 9:17 PM
    Ha! I've been there for work
  24. Jul 11, 2018 at 9:19 PM
    Call that number on pic I posted maybe they have one for you
  25. Jul 11, 2018 at 9:19 PM
    postrophe
    In Trinidad Colorado right now.
  26. Jul 11, 2018 at 9:28 PM
    postrophe
    Downloaded the pic, will try in the morning.
  27. Jul 11, 2018 at 9:40 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  28. Jul 12, 2018 at 3:04 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Are you at a normal run of the mill auto repair place? If so try searching for a drivetrain shop, some place that works on tractor trailers, farm equipment, or similar. They usually have the tools to replace and balance everything.
    landphil likes this.
  29. Jul 12, 2018 at 4:28 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  30. Jul 12, 2018 at 6:56 AM
    To bad you didn't break down in Colorado Springs, I would have sent you to Drivetrain Specialist. They build all my driveshafts for my Jeep. Usually around 400.00 for a complete one...and they have repaired a few to say the least.
    NewImprovedRon likes this.
