Shop Lift: Weaver, BendPak, Rotary, ...etc.?
Discussion in 'Off-Topic Discussion' started by apbreaux, Feb 20, 2021.
  1. Feb 20, 2021 at 8:53 AM
    apbreaux
    apbreaux [OP] New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    I am looking for advice/opinions/experience regarding a shop lift. I'm currently leaning toward a Weaver, as the Rotary is quite expensive. But I'm open to other suggestions.
    Ceiling height is greater than 13'. Looking at overhead, 2-post.
    Thanks.
  2. Feb 20, 2021 at 9:05 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Rotary is professional level equipment, hence the price. I think Bendpak has a hobbyist level. You might also look at Greg Smith Equipment. I’ve had a mid rise lift from them for about a decade and it has been solid. It had one spring on a check valve get weak and they helped me trouble shoot it and sent a replacement part with no hassle. Garage Journal also has a ton of info in the subject.
    JohnLakeman likes this.
  3. Feb 20, 2021 at 10:37 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Awesome. Thank you.
  4. Feb 20, 2021 at 12:24 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If installing in a residential garage, keep in mind that two post lifts require a thicker foundation than any standard home slab. Typically, you have to design the structure foundation to the lift requirements. Most manufacturers provide information on foundation requirements/specifications.
    Because of the foundation requirements, a two post lift was out of consideration for my application. I bought a "previously-owned" four post Atlas 408-SL lift originally from Greg Smith Equipment. My lift also included the center sliding hydraulic jack, and a separate heavy-duty jack tray, for lifting the vehicle on the runways for wheel, brake, and suspension work.
    I found that the quality of four-post lifts varied widely from professional-level quality like 408-SL to less well-known offerings that appear pretty sketchy in both design and fabrication. Atlas is made in China, but was probably a thousand cheaper than an equivalent Bendpak (another excellent professional-quality lift).
    apbreaux[QUOTED][OP] likes this.
  5. Feb 20, 2021 at 12:40 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    We installed a four post Bendpak at work two years ago. No problem with it. They are professional grade and I believe made in the USA.
    A long time ago I worked at Sears auto center and one of the mechanics dropped a truck off the two post lift and it bent the studs holding the posts. They had to X-ray the concrete to see if they could re bolt a new lift or cut out the slab - as @JohnLakeman said - two post lifts need the correct footing.
  6. Feb 20, 2021 at 6:22 PM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Much appreciated advice. I have an engineered slab with 18"x18" pads at post locations with a 5" slab.
  7. Feb 20, 2021 at 7:59 PM
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    Head on over to the General Discussion forum at garagejournal.com and spend the next 10 hours reading post about lifts. When information overload sets in and you need a break, check the Gallery out.....some incredible garage builds. I got a ton of great ideas and info over there for my detached garage build (i.e., design/layout, build materials, floor coatings, electrical, lighting, etc.).
    apbreaux[OP] likes this.
  8. Feb 20, 2021 at 8:34 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Rotary are the Cadillac or Mercedes of lifts. Hence the high prices.
    I have a bendpak lift in my garage that has served me well for over 28 years. I have not had any seal issues on the ram, it just works.
    I don't have any background with Weaver.
  9. Feb 24, 2021 at 5:32 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Thanks to all for their advice. I have pulled the trigger on the Weaver® W-Pro10 Blue Certified Overhead 2 Post Lift. Also got some accessories: Weaver® W-3320 3/4 Ton Jack Stand for Auto Lifts, Weaver® W-8G 8-Gallon Oil Drain, and Weaver® W-P201730-4 Screw Pad Adapters (Set of 4). Total cost was 3,500. It'll be a bit before this is installed, but I'll keep this up to date for anyone interested.
