Shock Tool for Rear TRD Pro / Fox
Discussion in 'Suspension' started by Hammertimerrrr, Jul 15, 2025 at 9:05 AM.
  1. Jul 15, 2025 at 9:05 AM
    Hammertimerrrr
    Hammertimerrrr [OP] New Member
    2024 MGM Limited OR
    I have a set of 1794 LE Fox shocks on my '24 Limited and am doing some work on the truck and need to remove the shocks to do a slight spacer lift.
    I see a lot of shock tools that indicate they fit GM trucks - but have also seen some threads here that indicate that tool is a bit loose on the Tundra shocks.
    Can anyone suggest the proper tool to hold the top of the shock rod while turning the top nut so it doesn't spin?
    I know I "can" put some hose around it and use some vice grips but that always seems to result in mangling it and I'd prefer to keep it clean.
    sudobash likes this.
  2. Jul 15, 2025 at 9:14 AM
    Does the shaft not have an allen key head on it?
  3. Jul 15, 2025 at 9:20 AM
    Hammertimerrrr
    2024 MGM Limited OR
    Nope. It's similar in shape to the GM ones. Rounded on two sides, flat on the others.
  4. Jul 15, 2025 at 9:26 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    8 or 10mm box wrench will hold the shaft in place.
  5. Jul 15, 2025 at 9:46 AM
    Or a crescent wrench?, What do you do once the nut is covering the threads?
  6. Jul 15, 2025 at 10:08 AM
    tbird462002
    tbird462002 New Member
    2025 Tundra Limited TRD
    Once it gets broken loose you dont need to hold the top anymore, spray some pb blaster or something else on those threads since they look a little rusty
  7. Jul 15, 2025 at 12:39 PM
    Hammertimerrrr
    2024 MGM Limited OR
    Thanks - I'll try the box wrench. In the past when I've tried that I still ended up mangling the top. On my tacoma I sourced a <$10 tool that fit perfectly and made taking the shocks off a breeze. Was hoping there was something similar for this application, but will do what I can with what I have!
  8. Jul 15, 2025 at 1:14 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Use same method with hose and vise grip, push boot that covers shaft up high enough to expose shaft then hold shaft with vise grip hose method as depicted in similar pic below.
    Hammertimerrrr[OP] likes this.
  9. Jul 15, 2025 at 2:26 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Vice grips, break loose, if it still spins then lightly clamp the shock shaft which is hardened steel and should be fine.
    chugs and Hammertimerrrr[OP] like this.
