shock suggestions
Discussion in 'Suspension' started by tiogajoe, Jan 18, 2023.
  1. Jan 18, 2023 at 4:38 AM
    tiogajoe
    tiogajoe [OP] New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Looking to replace my stock Billys on my 2020 TRD. I want to keep everything stock. I wouldn't mind upgrading the front coils. I travel a lot of dirt and gravel roads. I also do long Highway trips when Camping. Camper is under 3000lbs. Ideas? Thanks in Advance
  2. Jan 18, 2023 at 4:46 AM
    Soooooo, upgrading, or keeping it stock?
    Saltyhero13, des2mtn and Fotnot like this.
  3. Jan 18, 2023 at 4:48 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    :confused:
  4. Jan 18, 2023 at 5:18 AM
    PermaFrostTRD
    Northern NY
    Upgrade + stock can be a pretty big range; But, given your intended usage, I bet Bilstein 5100's all the way around set at no lift up front would suit you just fine.
    Sierradevil likes this.
  5. Jan 18, 2023 at 5:18 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Eibach front coils with Billy 5160 in back. Under 1500, fully adjustable front without dismounting.
    KNABORES likes this.
  6. Jan 18, 2023 at 3:09 PM
    tiogajoe
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    I mean keeping it stock as far as how the truck sits from the factory. I would like to set up a notch or two as far as a better performing shock both front and rear.
  7. Jan 18, 2023 at 3:18 PM
    eagleguy
    eagleguy New Member
    Not sure if this plays into your choices but! My friend and I both have 21 SR5 2WD Crew Tundras. In wanting to level the vehicles he went with the Bilstein 5100 adjustable shocks and I went with the Rough Country 870 lift kit, staying with the factory shocks. Both are now level but his vehicle rides totaly different (not better) and there is NO change in my ride quality. Food for thought as I know this has been debated many times.
  8. Jan 18, 2023 at 3:35 PM
    tiogajoe
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Would you guys use the stock springs on the 5100's?
    PermaFrostTRD and KNABORES like this.
  9. Jan 18, 2023 at 3:42 PM
    Yes. You can run stock height that way, or move the clip up to add some lift. Some will add lift by swapping the stock springs for OME’s for a better ride.
    tiogajoe[QUOTED][OP] likes this.
  10. Jan 18, 2023 at 5:41 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Around 100k as my suspension starts to get a little squishier, I think about what to put on my truck to keep things as they are presently height-wise - I believe the OEM 'TRD OffRoad' kit is the yellow/blue Bilstein 4600's correct? I don't really want to change anything, but I'm seeing kits for the Bilstein 5100 set very attractively priced just shy of $500. I'd like to do a minor upgrade for the shocks alongside a front/rear TRD swaybar set. Stiffen things up a little, since my Tundra's a bit more of a road queen for towing things, but can't justify the fully-assembled Bilstein B8 5160 kits I see for $1300 either.
  11. Jan 19, 2023 at 6:50 AM
    tiogajoe
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    I have seen these kits too. Some of them look like regular shocks for the front? they didn't look like coil overs?
  12. Jan 19, 2023 at 11:08 AM
    MedCityMoto
    Guess you and I both just don't live in Rough enough Country for their stuff huh? =)
    Yeah I think I'll end up doing the 5100s when the time comes.
    PermaFrostTRD and Sierradevil like this.
  13. Jan 19, 2023 at 11:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    5100s on the middle setting ride much harsher than the stock 4600.
    Also 5100s are heat soaked in about 1-2 hours of log trails. I'll be looking at upgrading to FOX shocks w/ external reservoir. Wife's TRD PRO Sequoia rides amazing compared to my Tundra.
  14. Jan 21, 2023 at 6:47 AM
    tiogajoe
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Dobinson looks like a good option? A bit pricey.
    AggiePhil likes this.
  15. Jan 21, 2023 at 6:53 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dobinsons are a lot of lift i believe.
    i have eibach equivalents of bilstien 5100, they ride great
  16. Mar 13, 2023 at 3:12 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Eh, 3”.
  17. Mar 13, 2023 at 4:28 PM
    MedCityMoto
    "That's what she said!" - Michael Scott
    Hbjeff likes this.
  18. Mar 14, 2023 at 7:06 AM
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    I
    I just put 5100s all around. Very satisfied - Fox’s we’re overkill for my use case.
    Sierradevil and Hbjeff like this.
  19. Mar 14, 2023 at 9:27 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I just swapped out my worn out factory set at 70,000 miles with bilstein 6112 set at the lowest setting. I actually picked up just under 2” of lift. Rides so much better.
  20. Mar 20, 2023 at 2:38 AM
    Bayport
    Bayport New Member
    Hi
    I have a 2020 tundra double cab w about 36k all stock
    When towing my 23ft center console boat (roughly 5500lbs) it looks like the truck is sitting lower than before in the rear
    Most of my towing is less than 5 miles each way with occasional 100 mile trips
    Thinking I should replace the rear shocks
    Reading this thread I’m not sure which ones would be best and do I have to replace all 4 or can I only do the rear?
    I’d appreciate suggestions
    Thanks
    LT
