Shock/Strut and Lift Kit Suggestions
Discussion in '1st Gen Tundras (2000-2006)' started by evanhmn, Aug 17, 2021.
  1. Aug 17, 2021 at 9:38 PM
    evanhmn
    evanhmn [OP] mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Has anyone(of course they have) gotten new shocks/struts and if so, have they actually given your trucks a smoother ride?
    And also, would it be worth just adding a lift and level kit onto my truck if I’m doing the shocks anyway? Which size lift works the best in your opinion?
    thanks
  2. Aug 18, 2021 at 6:09 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Look over the 1st gen and suspension forums here, you will find the info you seek.
  3. Aug 18, 2021 at 6:34 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Don’t do lifts but these are some the questions that would help….from @Darkness, one of the many suspension gurus around here !
  4. Aug 20, 2021 at 4:06 AM
    wick
    wick New Member
    dave wicker
    2000 tundra sr5 4wd
    trd dual outlet exhaust, rims, air filter. 1 inch spacer on front
    bilstein, truck rides better than new
  5. Aug 20, 2021 at 4:47 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Lots of threads and posts on this exact question in the suspension part of the forum... Members done that and posted there feedbacks on this subject matter... Good luck..
    My suggestion is find your budget, narrow down your choices, determine what lift kit you want for what wheels, tires combination, then you say better than stock ride?
    Spacer lift won't do that, but a good respectable Coilovers will. Good luck
  6. Aug 20, 2021 at 6:04 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Depending on what you pick, you should typically see a smoother ride. Lots of variables here though. We'd need more info from you so we can help. As @Darkness recently said, how much is your budget and how quickly can you double it? :)
