Shifting the Automatic
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Macaveli500, Jun 7, 2023.
  1. Jun 7, 2023 at 7:21 PM
    Macaveli500
    Macaveli500 [OP] New Member
    2016 Tundra TRD Pro charcoal
    Hey all I am new here officially, although I have read through the forums for a little while prior to signing up. I have a 2016 TRD PRO and it has been great. One thing I do while driving, and wonder about if it’s dumb or even potentially harmful is, I downshift the gear to 4 and or 3 to help me slow down into stop signs and lights. I figure it saves the brakes but I wonder if it’s harmful to the transmission? Anyone have opinions or expertise I this area?
  2. Jun 7, 2023 at 7:26 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    I think you'll get some mixed feedback on this. Our transmissions are solid, but the way that I look at it after doing some of my own research is that I'd rather put more stress on the brakes than the trans. Brakes are much less expensive and easier to replace.
  3. Jun 7, 2023 at 7:29 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    :popcorn:
    I've wondered this too. I don't use S to downshift, but I have been in the habit lately of tapping my brakes when going down a hill to catch a downshift that will slow me down. I'm curious if that's a bad habit though and I should just lightly ride my brakes instead.
    Macaveli500[OP] likes this.
  4. Jun 7, 2023 at 7:30 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Stay away from extremes and all will be well. The ECU protects the trans anyway. I do the same sometimes, but it is true that Brake pads are cheaper than a transmission.
  5. Jun 7, 2023 at 7:35 PM
    Bulldog9
    NOVA
    Using the trans to control speeds on downhills is normal. If you leave it in auto, and have cruise control, and especially in tow/haul mode, the transmission will downshift while CC is on to keep you at the set speed. I am one of those that likes to flex and use all the systems regularly, so I will put in S and manually shift up and down on a regular basis. KEY I think is to avoid the extremes. Dont bounce it off the rev limiter on accel, hold at high RPM in a gear abusively or force a downshift to too low a gear on decel and you will be fine. The 5.7/6Speed is a solid and robust powertrain.
    Taco-Spike and Macaveli500[OP] like this.
  6. Jun 7, 2023 at 7:56 PM
    Taco-Spike
    Two Trucks
    I do this occasionally also.
    Tripleconpanna likes this.
  7. Jun 7, 2023 at 8:12 PM
    Fitzf15E
    Fitzf15E New Member
    2021 Limited DC TRD OR Cement
    For better or for worse, when it comes to big downhills I control speed with S mode the same way I do with our M/T vehicles. Granted, I get to rev match and feather the clutch in the manuals versus the ECU doing all the work, but that's what the ECU is designed to do. I paid for that ECU, it better do the job the engineers designed it to do.
  8. Jun 7, 2023 at 8:14 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I agree its fine to use it on occasion if you feel the need, but with the steep 4:30's in the back, I find no need if you can anticipate your stops.
  9. Jun 8, 2023 at 4:16 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    This is the correct behavior of the transmission/engine/programming it's designed to save your brakes from overheating on long downhills similar to selecting your own gear with a manual. However, the transmission is not designed to slow you down form travel speed to almost nothing like with a manual. A clutch friction disk is a wear item designed to be easily replaceable (relatively easy), the clutches in an automatic are not designed for easy replacement.
    I would pay significantly more money to get Tundra with a manual, and I would love to have the option to have manual locking hubs which essentially give you a granny gear when in 4L with hubs unlocked.
  10. Jun 8, 2023 at 4:35 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Okay, nice, thanks all. That makes me feel better about it.
    I'm definitely not using it to go from 60-0, more like when I approach the crest of a hill going the speed limit already (think 40s typically), I'll tap the brake to try to get the gear to drop and hold me at approximately that speed while I descend vs waiting to get halfway down then having to ride my brakes to shed speed.
  11. Jun 8, 2023 at 4:47 AM
    21ProWeb
    21ProWeb New Member
    Mason, Ohio
    2021 MGM Toyota Tundra TRD Pro
    I do this daily too. I have always done it in my cars and never had an issue.
