Shifting problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by Burnah3, Jul 12, 2016.
  1. Jul 12, 2016 at 8:07 AM
    Burnah3
    Burnah3 [OP] New Member
    14 tundra sr5
    Grill exhaust cold air intake
    Tried to shift my truck from park to drive to get to work this morning and didn't go the dealership said it was some fuse that was blown but can't seem to find it Any ideas?
  2. Jul 12, 2016 at 9:46 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have read, but haven't checked for myself, that if you have a brake lamp out the truck won't come out of park. Super easy to check. Also, there's a very small cover next to the shifter. Pull the cover and stick a pen or such in there and it will release the shifter so that you can drive, you'll have to do that every time you move from park. There are fuses under the hood that are obvious, but there are also some above the Park Brake pedal that can be hard to see and easy to miss.
    ColoradoTJ and Black Wolf like this.
  3. Jul 12, 2016 at 11:48 AM
    Checked the driver side kick panel area for that fuse box
  4. Jul 13, 2016 at 10:48 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    x2 on the fuse box inside the cab. Also, might be nothing but press the brake extra hard to make sure the sensor shows you're stepping on the brake.
  5. Jul 13, 2016 at 1:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's a sensor?
  6. Jul 13, 2016 at 2:59 PM
    Mike Tread lightly.
    south carolina
    Most vehicles now have like a interlock on the shifter.. unless the brake pedal is depressed it will not unlock the shifter
    the only reason for it not to unlock.. fuse, brake sensor or pedal sensor not working or the shift lock itself has failed.. or module but not likely...
  7. Jul 13, 2016 at 4:17 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I understand. Nor7 said there's a sensor, I was curious about that. I know that my truck can be taken out of park by pressing the button under the cover next to the shifter, and read hints of a burned out brake lamp preventing shifting from Park but haven't been able to test that myself with my truck currently in storage. I'm curious about the sensor, I'd like to be familiar in case I were to have trouble. And info so we can help others.
  8. Jul 13, 2016 at 6:59 PM
    Mike Tread lightly.
    south carolina
    Sensor I bet he is talking about is the brake pedal switch..
