Shifting Issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by sebascasil13, Jan 28, 2025.
  1. Jan 28, 2025 at 5:08 PM
    sebascasil13
    sebascasil13 [OP] New Member
    I have a 2014 Tundra 1794 with over 130k miles. When it is cold, not every time, it delays the shift from 2nd to 3rd but does not slip, and the reverse it delays as well to get it. The code that it shows is the P0761, and when some time passes, it turns on the check engine and traction control light, and the code that it shows is the P2714.
    P0761 is the Solenoid C that is stuck in off position
    P2714 is pressure control D performance/stuck in off position
    I am not sure if this is a gear seal issue or if I should change the solenoid C and check it.
    Please guys, let me know your recommendations.
    Thanks in advance,
  2. Jan 28, 2025 at 5:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    These come up from time to time. Can range from low fluid, lots of clutch debri in fluid, faulty solenoid or a trans on its way out
    The valve body develops wear when clutch material is flowing through the passages causing wear and develops loss in line pressure.
    Check level and condition of fluid, top off if low. Test solenoids, ohm and actuation. Can be done at plug end or when dropping pan to clean out if dirty. Lots of posts on theses codes. Post 21 has some part numbers.
    https://www.tundras.com/threads/2010-transmission-codes-p2714-p0761.145300/#post-3823013
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-697#post-3809367
    HulkSmurf14 likes this.
  3. Jan 29, 2025 at 4:05 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I do drain&fill every 20k to prevent this sort of issues. Nothing beats clean oil.
    Mdl likes this.
  4. Jan 29, 2025 at 9:17 PM
    lr172
    lr172 New Member
    07 DC
    Ihad a similar problem, but the D solenoid. Pull the pan and replace the C solenoid. The SLT solenoid (2714 code) is likely not bad, but should be bench checked. The bsic shift solenoids are only $60 on RA . Get the rostra brand. Swapping and testing is simple. Getting the pan off can be a real challenge.
    Ponderosa_Pine likes this.
