Shift pattern issues
Discussion in '1st Gen Tundras (2000-2006)' started by Dsxx72, Mar 30, 2019.
  1. Mar 30, 2019 at 5:20 AM
    Dsxx72
    Dsxx72 [OP] New Member
    2001tundra
    I recently acquired a 2001 Tundra with the V8 the guy thought the tranny was shot because there's no reverse when I got the truck and had no reverse and no neutral we had to drag it out of the parking spot when you put it in reverse it was in Drive and neutral was also Drive it runs in all the forward gears just fine the gear shift fine at the normal RPMs when I got home I put it in park and then put it back into reverse reverse is now neutral and now the drive gears start in the neutral position I talked to a couple people and they think it might be sensor at the shift lever in the column if anybody has any idess or knows anything about this would be greatly appreciated before I send it to a shop and spend tons of money
  2. Mar 30, 2019 at 5:34 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Run-on sentence skill level: GRAND MASTER.
    Pucks18, 831Tun, bmf4069 and 6 others like this.
  3. Mar 30, 2019 at 5:48 AM
    Dsxx72
    2001tundra
    Smashed my thumb at work a couple days ago I posted from my phone so using talk-to-text since I only have one good thumb hahaha
  4. Mar 30, 2019 at 5:54 AM
    Heh...heh..I was wondering wtf. I don't own a first gen but it could be that sensor is toast.
  5. Mar 30, 2019 at 5:57 AM
    Professional Hand Model
    Hand Protectors
    Thumbs up not sure what your problem is and its not one many have on this forum but you could try an internet seach or take it to a mechanic and see what they say but not sure really as we can only guess at what the problem could be hera on this site you know what I mean
    hagrid and Darkness like this.
  6. Mar 30, 2019 at 5:57 AM
    Lot's of 1st gen owners here and I'd have to guess this issue has come up at some point.
  7. Mar 30, 2019 at 6:01 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    I would check the shift cable at the transmission first.
    -Jason
  8. Mar 30, 2019 at 6:12 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    +1
    Sounds like a linkage/cable issue need someone to shift while your under truck.
    Black Wolf and Racingjohndeere55 like this.
  9. Mar 30, 2019 at 6:15 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Possible shift cable adjustment stretched need replacement recommend get under engine running wheels locked chocked disconnect cable manually shift determine neutral someone inside move lever see how align could skip engine safer need drive shaft find lever positions. Helper NO GAS GAS = NO MO OP
    hagrid and Black Wolf like this.
  10. Mar 30, 2019 at 6:21 AM
    speedtre
    speedtre New Member
    Inland Northwest
    If it's not related to the shift cable somehow it's likely that the shifter is about the crap the bed but for some reason it hasn't broken completely so the shift sequence is just screwed up...
  11. Mar 30, 2019 at 6:30 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Shift cable linkage sounds about right and only 8 periods this whole thread
    831Tun and Black Wolf like this.
  12. Mar 30, 2019 at 6:39 AM
    Dsxx72
    2001tundra
    I appreciate the responses maybe before my thumb heels I'll set a new record for world's longest run-on sentence hahaha
  13. Mar 30, 2019 at 9:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Come on guys, this is easy! If it's in drive while showing reverse, someone put the trans in backwards! Just pull it out and turn it around! Might be hard to do with one thumb though...
  14. Mar 30, 2019 at 2:17 PM
    Racingjohndeere55
    Welder duct tape and baler twine only parts needed
