Shift column broke
Discussion in '1st Gen Tundras (2000-2006)' started by Sterlinglwood, Dec 18, 2020.
  1. Dec 18, 2020 at 8:57 PM
    Sterlinglwood
    Sterlinglwood [OP] Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    My Brother has a 2001 4.7 and says the shift column broke with the transmission stuck in drive. He’s basically homeless living in the mountains out of his truck with nowhere to go because all lodging in mammoth lakes is no go due to covid. He researched and found it’s a common problem. Is there any quick fix to get the truck into park so he can run the truck to stay warm? upload_2020-12-18_20-56-40.jpg
  2. Dec 18, 2020 at 9:29 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    I feel like @empty_lord would be a good one to ask. Can your brother provide any additional pictures in the meantime? I don’t know if it matters, but is it Limited or SR5?
    Tundra2 likes this.
  3. Dec 18, 2020 at 9:32 PM
    NWPirate
    Zach
    WA
    Damn, that's a bummer. Looks like cast aluminum.
    +1 on sir @empty_lord
    Tundra2 likes this.
  4. Dec 18, 2020 at 9:35 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    SR5
    Tundra2 likes this.
  5. Dec 18, 2020 at 9:39 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Not familiar with this problem personally, but it seems like a cable/ linkage is either bound or broken. Is it possible to access the linkage on the trans from underneath? If so, could you undo the cable and shift it manually by hand until you can figure out what is broken from the shifter? Maybe some of the 1st gen guys can weight in. Good luck.
    N84434, NWPirate and Tundra2 like this.
  6. Dec 18, 2020 at 9:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I would try @TILLY's suggestion until the shift kever/cable can be resolved.
  7. Dec 18, 2020 at 10:13 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Possible temporary solution.
    Found this video: https://youtu.be/X6wmZ7CR8Is
    He had his tundra locked in park, as his tail lights fuse was burned out. He said, if taillight fuse, then the truck will stay in park.
    Maybe remove the fuse, and it will force it into park? I don't know if the shifting mechanism is mechanical or electrical.. might work, good luck.
    If not, try pulling/pushing the cable. Looks like an expensive fix.
    torino69 likes this.
  8. Dec 18, 2020 at 10:20 PM
    TILLY
    Massachusetts
    OP's brothers truck is a 2001..
    Tundra2 likes this.
  9. Dec 18, 2020 at 10:43 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    ok ignore what i said. i was on my phone now the PC. the columns broke. junkyard column is the option that'll cost the least
    for now shift from under the vehicle. but i wouldnt do that if you need to drive it. park it for now.
    Tundra2 likes this.
  10. Dec 18, 2020 at 10:48 PM
    empty_lord
    05 rollover special
    [​IMG] that right there appears to be completely broke off, which indicates something SUPER seized, or someone REALLY cranked on this sucker
  11. Dec 19, 2020 at 8:28 AM
    Is he not able to hold the bracket in some vise grips and shift it into park with the lever? Make sure the brake is adequately depressed and the lever is fully pulled forward toward the driver, the lockout mechanism may not have disengaged when he broke that lever trying to shift. Or, the lockout mechanism may be broken. Or, the cable may be seized up. Strange it broke while in drive. Mine's so loosey goosey in drive you could almost just accidently bump it out of gear. These usually break when trying to shift out of park. Often because the brake pedal wasn't adequately depressed.
  12. Dec 19, 2020 at 5:05 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Whoa...Deja Vue! :eek:
    I think I did I writeup on TundraSolutions.com on how to fix that in my past life. :thumbsup:
    NWPirate likes this.
  13. Dec 19, 2020 at 5:11 PM
    NWPirate
    Zach
    WA
    Got a link? It looks really involved, did you have to pull the steering wheel?
  14. Dec 19, 2020 at 5:22 PM
    Jack McCarthy
    Bill
    North of Boston
    To fix it, yes you need to pull the steering wheel. I finally found the link to the thread I created years back... Edit: It may be possible to do this without removing the steering wheel as someone else did it that way. I can’t recall exactly why I took it off originally; maybe just for a better view of everything.
    For now I would just use that kidney shaped armature in the pic to shift gears and drive it around without the shifter...
  15. Dec 19, 2020 at 6:09 PM
    NWPirate
    Zach
    WA
    Nice find!
    How's your brother's situation going @Sterlinglwood
  16. Dec 19, 2020 at 6:36 PM
    Professional Hand Model
    Hand Protectors
    How did this happen? Cable seized at transmission?
  17. Dec 20, 2020 at 5:53 AM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Thanks for all the responses. I’ve sent this thread to him but haven’t heard back. I’ll probably talk to him later today.
  18. Dec 20, 2020 at 6:32 AM
    Jack McCarthy
    Bill
    North of Boston
    It’s just a bad design by Toyota where they use a cast aluminum bracket to hold the shifting mechanism. Imperfections in the casting process can lead to premature failure under normal stress fatigue. Mine just broke off one day with little to no effort.
  19. Dec 20, 2020 at 8:25 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    This is called brotherhood. Lend him yr 2017 until he fixes his. On the meantime rent one for yourself. Thats what I would do.
    Sterlinglwood[OP] and Glock 40 like this.
  20. Dec 20, 2020 at 8:30 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Be my friend.
  21. Dec 20, 2020 at 8:34 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I like my brother but I'm not loaning him my truck.
  22. Feb 11, 2024 at 3:43 PM
    Jusjoshin808
    Jusjoshin808 New Member
    Joshua
    2000 Toyota Tundra
    Aloha,
    does anyone know the total parts list to repair this? Mines snapped off the exact same way. Trying to find the parts for it.
  23. Feb 11, 2024 at 4:12 PM
    Did you miss reply #14?
  24. Feb 11, 2024 at 4:27 PM
    Jusjoshin808
    Joshua
    2000 Toyota Tundra
    Oops sorry I did and just read it.
    For anyone else that missed it, here’s the parts list based on post #14
    Parts:
    OEM support bracket: part # 45859-07010
    OEM shaft assembly: part # 33501-0C011
    Optional parts (does not include the 3 screws for mounting the shaft to the support bracket - mine were good):
    OEM tilt steering pivot pins/bolts (2 total): part #45856-07010
    OEM torx lobular screws for mounting support bracket (4 total): part #90080-10048
    OEM screw to hold column shifter arm into shaft (1 total): part #90080-16070
    aredub likes this.
  25. Feb 22, 2024 at 12:56 PM
    andyman0369
    andyman0369 New Member
    Nashville
    2002 Limited AC, RWD
    Bone stock w/ 210k miles
    Same problem yesterday...
    Good Luck finding parts! Both the Support bracket and shaft assembly are discontinued (Dorman lists a replacement but...). I got lucky after 11 phone calls to dealers from South FL to Central CA and have what I need headed my way. Call Jacob at Madera Toyota 559.674.9000, or anyone at Olathe Toyota 913.780.9919. Both fellas were awesome. Junkyard is an option but since this a metal fatigue issue, I'd rather not roll the dice on another failure.
    There were a few dealers who had OE shift assemblies on the shelf but not everyone will ship to you. The support bracket was harder to find. If your local dealer doesn't have it, ask them to check availability within the region. They should be able to see if anyone else has them on the shelf.
    Happy wrenching!
    -A
    Jack McCarthy likes this.
  26. Feb 23, 2024 at 5:52 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I see a lot of folks just slap their shifters in park. Be gentle with it.
