Shell 91 V-power!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundraxp, Dec 10, 2016.
  1. Dec 10, 2016 at 10:40 AM
    tundraxp
    tundraxp [OP] New Member
    Michael
    Tundra xp 4x4
    Rims and tires
    i usually do Cheveron Premium but I just filled my tank up with the Shell V-power and I can tell a HUGE difference. This pulls like a monster!!! Can't praise it enough! I have a 2015 CM sr5. Anybody else experience this??!!
    Metro14536 and Tiamat like this.
  2. Dec 10, 2016 at 11:33 AM
    Yup...all I put in...nitro v power!!! I panic when i travel out of town n don't see any shell around I have shell app tells u nearest shell station
  3. Dec 10, 2016 at 12:54 PM
    tundraxp
    Michael
    Tundra xp 4x4
    Rims and tires
    Hahaha love it. New app download!
  4. Dec 10, 2016 at 1:32 PM
    Shell motorist is name
  5. Dec 10, 2016 at 1:56 PM
    All I run is Premium ...because supercharger
  6. Dec 11, 2016 at 5:38 AM
    chphilo
    chphilo Tundra addict
    Western PA
  7. Dec 11, 2016 at 6:07 AM
    Stig
    Stig New Member
    No
  8. Dec 11, 2016 at 11:04 AM
    Marty McFly
    Morty McBoonJug
  9. Dec 11, 2016 at 12:43 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Gonna state the obvious. That is 1.30 per LITER!!!!
  10. Dec 11, 2016 at 12:45 PM
    jtav2002
    jtav2002 Retired Adult Film Sound Man
    Josh
    Reading, PA
    2019 GMC Sierra 1500 AT4 6.2
    Regular at whatever gas station I'm closest to.
  11. Dec 11, 2016 at 1:42 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    There's absolutely no difference putting in premium vs regular octane. unless you are force inducted.
  12. Dec 11, 2016 at 2:56 PM
    Marty McFly
    Morty McBoonJug
    Roger that sir!
  13. Dec 14, 2016 at 10:33 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Sounds like the butt dyno at work to me. Any improvement in MPG? The only thing I put premium in is my V175 Mercury OB. Running milled heads at 140 pounds.
    Abrams65 and 2cID like this.
  14. Dec 14, 2016 at 1:42 PM
    Stig
    Stig New Member
    IMO you see a bigger difference using 87 ethanol free. V Power is just a silly marketing term.
    AnonVet and Wynnded like this.
  15. Dec 14, 2016 at 1:45 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You better listen to the stig. He obviously knows.
    FlashCulprit and T-Rex266 like this.
  16. Dec 14, 2016 at 2:11 PM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    It's a tough pill to swallow though. 87 is $2.05 while 91 is $2.85. That is $24 MORE for 30 gallons.
  17. Dec 14, 2016 at 5:24 PM
    signalbobby
    Robert
    AZ
    Ecu is tuned for regular octane. Higher octane will burn cooler, however our engine will not compensate for it. It doesnt have a "performance" tune.
    Dyno will prove there is zero improvement.
    There is so much misinformation from the bench.
    CM-LENNY likes this.
  18. Dec 14, 2016 at 7:53 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Not doubting what you believe, but believe this fill up with a tank of regular and check your highway gas mileage compared to a fill-up of premium and you will note that the premium fill-up has a vastly higher MPG than the regular.
  19. Dec 14, 2016 at 8:03 PM
    Ericsopa
    Ericsopa Old man and the sea
    Bull!
    Relentless, AnonVet and Black Wolf like this.
  20. Dec 14, 2016 at 8:15 PM
    signalbobby
    Robert
    AZ
    They both get the same 15.0mpg calculated (with fuelly) on 87, 89 or 91 on 31 gallons of fill up. All the same 46 miles round trip commute.
    My 2006 R6 (about 160 miles) and 2015 R1 got the same miles per tank fill up when I had either 91 unleaded or 110 VP Racing.
  21. Dec 14, 2016 at 9:33 PM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    Has anyone tried ethanol free gasoline? I am thinking of giving it a try.
  22. Dec 14, 2016 at 9:43 PM
    Ericsopa
    I tried it. Didn't make a big enough difference to definitively say the mileage was any better and definitely not enough difference to justify the higher cost. I average around 17 MPG mixed city/hwy on E10, and calculated 17.2 MPG on one tankful of E0. Would have had to get over 21 MPG on E0 to match the cost of E10. Had I gotten even 18-19 MPG, I would have tried another tankful or two. But I always use non-ethanol in my outboard motor.
  23. Dec 14, 2016 at 10:05 PM
    MrWrench
    MrWrench New Member
    I thought there would be a bigger difference in MPG's. Ethanol free gas has a higher BTU content then E-10. I thought blended gasoline wasn't allowed to be used in boats?
  24. Dec 15, 2016 at 4:29 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Every chance I get. For me it's not about the money. I want GAS.
    scurdyness, Ericsopa and Black Wolf like this.
  25. Dec 15, 2016 at 5:23 AM
    Ericsopa
    I thought so, too. Theoretically, it should get better mileage. That's why I tried it. It's possible that the problem with the E0 that I tried was that it is 86 octane instead of 87. Possibly caused a slight ping that caused the computer to run the ignition a little retarded as compared with the 87 octane E10. But the E0 is not easy to come by. The only E0 source in my town is that 86 octane stuff. I could drive 50 miles to get 87 octane E0, at the place where I fill my boat on the way to the coast, but of course that would negate any MPG advantage. All the outboard manufacturers okay E10 for their motors. But I don't want E10 in my 60 gallon tank. Too big a chance for water absorption in a tank open-vented to atmosphere.
  26. Dec 15, 2016 at 5:28 AM
    Ditto^^^
  27. Dec 15, 2016 at 5:28 AM
    Ditto ^^^^:deadhorse:
    GNTundra likes this.
  28. Dec 15, 2016 at 6:11 AM
    Ericsopa
    What I really want is for the gov't to stay the hell out of it, and stop mandating the use of corn juice in my vehicles. Instead, they push the E15 crap, with fraudulent motives.
    Wynnded[QUOTED] and Black Wolf like this.
  29. Dec 15, 2016 at 6:34 AM
    MrWrench
    MrWrench New Member
    86 octane could be the culprit. I thought Toyota wanted no less then 87 octane in the tundra? Place near me sells E0 and I believe it is 87 octane. When I fill up, I am gonna try it and see if the mpg's go up. If I don't see a huge difference, I'll stick to top tier gas. Didn't the EPA want 20 percent ethanol a few years ago but the auto makers pushed back on it?
  30. Dec 15, 2016 at 6:40 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Unless we all have the same set-up, same truck, same drive, and same lead foot.... it's impossible to bounce numbers off one another and say who is right or who is wrong. If 91 works for you, then by-god use it... if you thinks its a marketing scheme and for the birds, continue to use 87. Some of us drive like Earnhardt and Gordon while some of us drive the Blanch from the Golden Girls. Me personally I feel like I drive uphill both ways and my miles per gallon reflects it because I drive with a purpose and I am always cutting my commute close with time. IMO.
