Shaking at 45 to 55 mph
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ricksta13, Mar 24, 2024.
  1. Mar 24, 2024 at 6:55 AM
    Ricksta13
    Ricksta13 [OP] New Member
    Rick
    2020 tundra trd sport
    6” lift n after market rims
    The shaking comes at 45 to 55 mph and it's really bad and ones I pass 55 it stops n feels ok and then when I start to slow down it does it again right at those speeds and mind you I took it to get an alignment and it's worse so wat could it be
  2. Mar 24, 2024 at 7:11 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Your truck just hates going slow….
    Tire balance
    Alignment
    Worn steering components
    Can’t think of too many other things that would be suspect here.
    IsaiahCanada and Ricksta13[OP] like this.
  3. Mar 24, 2024 at 9:10 AM
    2010SR5NIC
    2010SR5NIC New Member
    2010 Salsa red pearl DC
    Dobinson lift front and rear, SPC UCA’S, icon add a leaf, coach builder shackles, 18x8 method wheels with 295/75 falken wildpeaks.
    id get your wheels balanced maybe the weights fell off.
  4. Mar 24, 2024 at 9:16 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Wheel bearings, ball joints will do that too
  5. Mar 24, 2024 at 10:33 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Can you feel it on the steering wheel or seat..??
  6. Mar 24, 2024 at 4:13 PM
    tkr412
    tkr412 New Member
    Middle Tennessee
    2020 Cement Crewmax
    I have the same thing going on. Can feel it in the steering wheel. Tires balanced and rotated then rotated back. Had the truck since October. Steering has always felt like it wasn't as tight as it should be. Thought about some type of steering stablelizer when or if I can find what's causing the shaking.
  7. Mar 24, 2024 at 7:12 PM
    Plantguy
    Plantguy New Member
    2017 Tundra 1794 Edition
    TRD dual exhaust, TRD rear sway bar, Bilstein 4600
    Get a road force balance.
  8. Mar 25, 2024 at 4:09 AM
    tkr412
    tkr412 New Member
    Middle Tennessee
    2020 Cement Crewmax
    Mine were road force balanced. What's the difference in feeling it in the steering wheel vs. seat?
  9. Mar 25, 2024 at 4:49 AM
    agrestic1
    2016 CrewMax
    Steering wheel vibe is usually front end , tire issue, Seat vibe is usually rear tire, rear end, drive train issue..
    https://www.tirerack.com/images/tires/vibechart.pdf
  10. Mar 25, 2024 at 7:46 PM
    tkr412
    tkr412 New Member
    Middle Tennessee
    2020 Cement Crewmax
    Makes sense. Thanks
