Shake n shimmy after slight turn on interstate??
Discussion in '2.5 Gen Tundras (2014-2021)' started by lukedias00, Apr 26, 2023.
  1. Apr 26, 2023 at 5:04 AM
    lukedias00
    lukedias00 [OP] New Member
    2014 Tundra 4x4 Off-Road Limited
    Hey guys, question.
    I have a 2014 Tundra, 3inch lift, 35in tires.
    Driving on the interstate 80mph this morning, took a slight turn and during the turn I could feel a shake develop and not go away when I was through the turn.
    My thought is either a bad front axle or wheel bearing? Has anyone experienced this?
    Thanks
  2. Apr 26, 2023 at 6:37 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have you ruled out it's not warped brake rotors?
    A bad wheel bearing should resolve once you're driving straight. Still hum though.
    When you get a chance, hop underneath and do a visual of the axle and lift up the front and check both wheels for play.
  3. Apr 26, 2023 at 7:06 AM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    I have a 2015 that was doing it at lower speeds. It ended up being the emergency brake cable hinge device being stuck. My front rotors were also slightly warped.
  4. Apr 26, 2023 at 7:27 AM
    lukedias00
    Well, steering wheel doesn’t shake when I brake, so I don’t think it’s the rotors. Visual inspection of the axles, they look fine but that doesn’t mean they are good
  5. Apr 26, 2023 at 10:23 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    My truck has a front-end vibration that develops when entering the highway up to ~70-75mph from ~45mph. I also have the well documented needle bearing/front diff issue and will be replacing it with the ECGS bushing in the next week. Hoping the bushing resolves both issues. There is a crap ton of play in the driver side CV-axle.
    I would be interested to hear what fixes yours.
  6. Apr 26, 2023 at 10:40 AM
    lukedias00
    I just did that bushing repair on my 2007 4Runner, was unaware that they were using the same needle bearing in the tundras?!
    Well if I just run straight it’s smooth, the shimmy only develops if I’m turning a lot.. kinda think it’s the wheel bearings, side load via turning maybe idk. I’ll keep this thread updated
  7. Apr 26, 2023 at 11:05 AM
    yakeng
    Both use needle bearings, I don't think they are the same as the ECGS bushing has different part numbers. The Tundra's don't seem to be effected as much as Taco's and 4Runners are. Seems to be more isolated by year on the Tundras. Based on my research, 2008-2011 and 2020 seem to have it worse than other years.
  8. Apr 30, 2023 at 5:37 AM
    lukedias00
    Can you elaborate?
    Sweeping left turn is the last thing to induce it. Have you heard of the torque converter wobble?
    Or the driveshaft being unbalanced?
    TundraLLama[QUOTED] likes this.
  9. May 1, 2023 at 3:31 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Bad tire,maybe rotate tires and see..
  10. May 2, 2023 at 6:27 AM
    TundraLLama
    Massachusetts
    I did some research before I took it to a Toyota dealership for diagnosis, and then brought it to my mechanic to get it fixed. I actually did contact a local transmission shop and he told me if something was wrong with your transmission. He would know it for sure it would do it constantly. He was right it ended up being the E brake cable hinge. it started when I engage my E brake, then released it. I drove off and I could feel a semi in the front and it felt like it was coming through the middle of the truck. I thought it was the tranny too but thankfully I was wrong.
  11. May 3, 2023 at 5:19 AM
    lukedias00
    Where is this hinge located?
  12. May 3, 2023 at 6:33 AM
    TundraLLama
    Massachusetts
    I’m not sure of the exact location, but is it is attached to the emergency brake cable
  13. May 3, 2023 at 7:58 AM
    agrestic1
    2016 CrewMax
    Drivers side, between front /rear door, near the frame
    myfirsttundra1 and TundraLLama like this.
