Shake in front end
Discussion in 'Other Toyota Vehicles' started by Cflo65, Sep 20, 2019.
  1. Sep 20, 2019 at 5:18 PM
    Cflo65
    Cflo65 [OP] New Member
    2016 Tundra
    Leveled
    Installed new front brakes and rotors in April. I have a shake in tundra when I apply the brakes....could it be rear brakes?
    Mountun Goat likes this.
  2. Sep 20, 2019 at 5:23 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Could be rear. Did you clean the callipers and rotors properly? Sometimes pistons seize causing pads to pinch crooked and warping rotors as well. Inspect the rear quick by pulling a wheel off and see how it looks.
  3. Sep 20, 2019 at 5:31 PM
    Flatzby
    Flatzby New Member
    '18 Crewmax Limited MGM TRD OR
    It could be the rears. Do you do a lot of towing/heavy braking? Could have a warped front rotor after 5 months of that, depending on the quality of the rotor.
  4. Sep 20, 2019 at 7:23 PM
    Cflo65
    2016 Tundra
    Leveled
    Had brakes installed by my mechanic. No towing. I'll pull tire off in the am and check rear brakes
  5. Sep 30, 2019 at 11:22 AM
    Cflo65
    2016 Tundra
    Leveled
    Replaced rear brakes and aligned front end, still small shake but not each time I brake....any thoughts?
  6. Sep 30, 2019 at 11:31 AM
    Mnorris1206
    08 tundra
    All tires look good no un even spots ? I had some chop to my tires very little and when I would apply the brakes I could feel it for some reason. I just rotated them and it went away.
    Casper421 likes this.
  7. Sep 30, 2019 at 12:06 PM
    Cflo65
    2016 Tundra
    Leveled
    No....tires are brand new
