Shackles or Blocks?
Discussion in '2.5 Gen Tundras (2014-2021)' started by awlafleur, Sep 3, 2019.
  1. Sep 3, 2019 at 4:23 AM
    awlafleur
    awlafleur [OP] New Member
    2016 Black SR5 Tundra
    Leveling spacer in front
    Goal is to get +2 in rear with stock shocks if possible. Minimal off-road, minimal towing...which would be better option cost and long run?
  2. Sep 3, 2019 at 4:36 AM
    Mnorris1206
    08 tundra
    I vote shackles for sure.
    Watt maker and Rica25 like this.
  3. Sep 3, 2019 at 5:21 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    X2 shackles. The ride is smooth and less bed bounce.
  4. Sep 3, 2019 at 6:00 AM
    Rica25
    Ricardo
    Tulare
    I've had both and shackles are smoother
    JoshuaA likes this.
  5. Sep 3, 2019 at 6:38 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Shackles!!!!
    Rica25 likes this.
  6. Sep 3, 2019 at 6:59 AM
    Bigbird57
    Bigbird57 New Member
    MAGDADDY likes this.
  7. Sep 3, 2019 at 6:59 AM
    Blueknights75
    Ron
    Clayton, NC
    Shackles with poly bushings!
    JoshuaA, Rica25 and Watt maker like this.
  8. Sep 3, 2019 at 7:35 AM
    15whtrd
    15whtrd Mr. Blonde
    Just note that you are not going to get the full 2 inches out of +2 or +3 shackles. Even if you go with the toy tech adjustable. It seems that you get about half the longer length of the shackle. So if it’s 2 inches longer it will give you about an inch of lift. 3 inches longer gives you about an inch and a half.
    Rica25 likes this.
  9. Sep 3, 2019 at 7:39 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think the most important thing is what @15Yota pointed out. Blocks induce axle wrap so shackles fosho.
    15whtrd, Rica25, Watt maker and 3 others like this.
  10. Sep 3, 2019 at 9:28 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Shackles plus a tough country add a leaf. The tough country will get you about an 1.5” and is under $100. That’s what I had on my old truck plus coachbuilder #2’s. Center hub to rear fender was at 26.75”.
    Rica25 and 15whtrd like this.
  11. Sep 3, 2019 at 9:30 AM
    RFerre6
    RFerre6 New Member
    +1 for shackles. I have a brand new set of coach builder shackles (+2) if interested. Still in the box and wrapped in packaging. Comes with bushings and all hardware.
    I can give you a smoking deal since they won’t be used anytime soon.
    Rica25 likes this.
  12. Sep 3, 2019 at 9:41 AM
  13. Sep 3, 2019 at 9:54 AM
    15whtrd
    15whtrd Mr. Blonde
    Rica25 and Black Wolf[QUOTED] like this.
  14. Sep 3, 2019 at 9:57 AM
    TrdLtd26
    TrdLtd26 New Member
    Shackles! Super easy to install. I went with Toytecs
    Rica25 likes this.
  15. Sep 3, 2019 at 10:05 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Neither!! Add a leaf, way better, and you will blow out your rear shocks.
    Rica25 likes this.
  16. Sep 3, 2019 at 10:26 AM
    The Toytec shackles at highest setting will get you 1.5". I used them with AAL.
    awlafleur[OP] and Rica25 like this.
  17. Sep 3, 2019 at 10:28 AM
    I've got the 1.5" version on the way. I will use the brake line adapter kit from Toytec and possibly AAL.
    Rica25 and 15whtrd[QUOTED] like this.
  18. Sep 9, 2019 at 12:21 PM
    awlafleur
    Appreciate all the feedback...was thinking about a 3/2 lift but parked next to a 3rd Gen Tundra with a 6” lift and thought that is really the height I am looking for. Is there any way to get a 6” lift front and rear without blocks in the rear?
  19. Sep 9, 2019 at 3:14 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    How do shackles ride smoother than blocks?
    Rica25 likes this.
  20. Sep 11, 2019 at 12:38 AM
    reno_tundra
    reno_tundra New Member
    2019 White Tundra CM SR5
    Maybe someone else more knowledgeable can chime i here if I miss this, but I’m pretty sure shackles also include poly bushings for the leafs, and those bushings are the big difference. They are way better bushings than the OEM leaf bushings so you get the ride quality gains from that.
    15whtrd and Rica25 like this.
  21. Sep 11, 2019 at 12:42 AM
    reno_tundra
    From what I’ve seen in other threads BDS makes a quality lift if you’re okay with a little cutting (only applicable to 4x4s)...and apparently rough country doesn’t require cutting, but I haven’t seen a lot of praise for it.
    I’m not the expert though, I went with a 3/1.5
    Rica25 likes this.
  22. Sep 11, 2019 at 4:59 AM
    Rubberdown
    The factory shackles are splined, and don’t move freely. If you replace the shackles, you have to replace the bushings at the same time so the splines don’t eat up the shackles. Then the shackles can float, and movement is free in the rear end.
  23. Sep 16, 2019 at 11:37 AM
    awlafleur
    Did you retain factory rear shocks or upgrade?
  24. Sep 16, 2019 at 11:42 AM
    Old Man Emu Nitrocharger shock. Factory shocks are too short.
  25. Sep 18, 2019 at 4:07 PM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    Where would I go about getting the poly bushings for the shackles?
    Rica25 and Black Wolf like this.
  26. Sep 18, 2019 at 4:14 PM
    Toytec. Energy Suspension polys.
    Migraine and alwzdfiant[QUOTED] like this.
  27. Sep 18, 2019 at 4:16 PM
    alwzdfiant
    Awesome thanks
  28. Sep 18, 2019 at 4:18 PM
    FWIW..Coachbuilder sells the same Energy Suspension polys I believe..
  29. Sep 18, 2019 at 4:20 PM
    alwzdfiant
    Looks like they’re almost 20 bucks cheaper on CoachBuilders. Thanks again!
  30. Sep 18, 2019 at 5:59 PM
    Actually 4 wheel parts has them for $20...I avoid 4 Wheel Parts.....
