Service question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by yoneytan, Nov 10, 2018.
  1. Nov 10, 2018 at 5:55 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    What is required for service aside from the obvious oil change on a 14 5.7 2wd with 85k miles?
  2. Nov 10, 2018 at 5:56 PM
    It’s in your service manual too
    TXRailRoadBandit73 likes this.
  3. Nov 10, 2018 at 6:13 PM
    Stig
    Stig New Member
    I'd suggest changing the in cabin air filter and wiper blades.
  4. Nov 10, 2018 at 6:30 PM
    yoneytan
    Asi
    14 CM
    I changes both of those about 3k miles ago. I found a thread with service info that states trans fluid should be replaced at 90k miles so definitely having it changed as well as engine oil, engine coolant, trans case oil and differential oil. I might have them change the spark plugs and brake fluid and call it a day.
