Serpentine belt
Discussion in 'General Tundra Discussion' started by Yotalife, Jun 5, 2016.
  1. Jun 5, 2016 at 7:31 PM
    Yotalife
    Yotalife [OP] New Member
    2008 white sr5
    Changed my serpentine belt and truck squeals sharp and loud until what appears to be the fan clutch kicks in. Watched some videos on line and did the water test and that would stop it. It only does it when the motor is cold,like overnight. Any ideas? Tired of the neighbors looking at me.
  2. Jun 5, 2016 at 8:35 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    How old is it? Could just be worn out.
  3. Jun 6, 2016 at 3:38 AM
    Yotalife
    2008 white sr5
  4. Jun 6, 2016 at 3:39 AM
    Yotalife
    2008 white sr5
    The trk is 08 and the belt was a new one that I put on.
  5. Jun 6, 2016 at 4:04 AM
    Pulley or bearing ruled out?
  6. Jun 6, 2016 at 5:59 AM
    Yotalife
    2008 white sr5
    no not quite sure how to diagnos it. mechanic at garage said that it was the bearing behind the pulley that the fan mounts to. saw on a video on you tube(probably not the best) that if you put a little water on the ribbed part of the belt and the squeal goes away that it is more than likely the tensioner pulley. looking for help and advice. it did not have the problem until i changed belts. also heard that a goodyear gaterback belt might help as it is more flexible to help with pulley misalignment. thanks in advance for your time.
  7. Jun 6, 2016 at 6:39 AM
    You should ask the mechanic in the Ask a Toyota mechanic thread ;)
  8. Jun 6, 2016 at 6:48 AM
    Yotalife
    2008 white sr5
    how do i get to thet thread? new to the whole forum business.
  9. Jun 6, 2016 at 7:03 AM
    It's a sticky in the general Tundra discussion area
  10. Jun 6, 2016 at 7:48 AM
    AaronK
    AaronK New Member
    Aaron
    A mechanics stethoscope could help localize the sound.
