Series 100 LC snorkel on a FGT
Discussion in '1st Gen Tundras (2000-2006)' started by The Black Mamba, Oct 15, 2023.
  1. Oct 15, 2023 at 10:47 AM
    The Black Mamba
    The Black Mamba [OP] A pure specimen of TX Black Snek
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    At the request of @KNABORES (for future forum searches), this thread will document my install of a cheap eBay snorkel designed for the Series 100 Land Cruiser on to a FGT.
    …as @DJenerated(Wumbo) would say, “For Science”
    Thanks to @whodatschrome for hooking me up with a link to the snorkel I purchased. Here’s the link https://www.ebay.com/itm/334623367681
    also, link to his build thread
    Now, because this snorkel is not necessarily designed for our trucks, there is not a template or an easy way to tell you how to do this. You have to eyeball it, pick a line and commit.
    Step number one is going to be remove the factory airbox assembly (both clam shells) and remove the right front inner fender liner. In my case I also had to remove the right front wheel arch molding. After all of that is out-of-the-way, you can access inside the right front fender.
    Next, you will take the rubber snorkel hose that connects the OEM airbox (lower clam shell) to the snorkel assembly and place it inside the fender. Because the factory air box draws air from inside the fender, the airbox itself has an inlet that protrudes through the inner fender well and makes a 90° turn towards the rear of the vehicle. After the rubber “inside the fender tube” is in place, you can then reinstall the factory airbox bottom clam shell by pushing the air box inlet into the rubber tube and then tighten the hose clamp from inside the fender.
    At this point you will have a really good idea about where you’re going to make the 4 1/2 inch hole in the fender to attach that rubber hose to the snorkel assembly.
    Next comes the point of no return. You now have to commit to cutting a 4 1/2 inch hole onto your fender or put everything back to stock.
    Take a shot of whiskey and send it.
    I’ve seen people use a carbide holesaw to make this cut. I’m pretty sure that’s the best route to go. I don’t have a holesaw of that size nor was I going to take a trip to the home improvement store to purchase one ($45). Instead, I put a carbide blade into my jigsaw, drilled a starting hole and sent it.
    With the inlet hole now cut into the fender, you can hold your snorkel up with the template and gauge where the mounting holes need to be.
    I used a 3/8 drill bit for these holes.
    Next I mocked up the snorkel again, just to make sure that that’s exactly where I want it.
    After that, attach the washers and locknuts to the studs on the backside of the fender. Tighten down with a 13mm wrench. Attach the inner hose to the snorkel assembly and tighten down the hose clamp.
    Reinstall the inner fender liner, wheel arch molding and airbox upper clam shell assembly.
    Take another shot of whiskey, sit back and bask in the beauty of what you’ve just accomplished.
    I took her for a hot lap to see how she acts. There is very minimal blockage for driver visibility.
    Being that this is a “true” cool air intake, there is a very minute yet positive increase in throttle response. Only time will tell if I actually have to replace the air filter more often than the OEM setup.
    In the future, I will probably take a heat gun to the snorkel neck and try to massage it closer to the A pillar without compromising the right side door. For now, it’s sturdy and functional.
    Below are links to a few videos that assisted in preparing me for this install.
    https://youtu.be/aEYzeOgke64?si=t63lwrjpkvWMnmml
    https://youtu.be/Zyij0INw4T8?si=XNldchr9YK_aAtH3
    https://youtu.be/1AFKZMoIh2s?si=wnkH82698K9aupr0
    https://youtu.be/eoCA8Z-hibY?si=sSDOFE2OZa2sZYM7
    I will say the last 2 videos from “The Other Guy” were most informative.
    Please reach out with any questions.
    - TBM
    G_unit3000, BroHon, FJ432 and 13 others like this.
  2. Oct 15, 2023 at 10:57 AM
    This is awesome! Great content.
    Voss, Tundra2 and The Black Mamba[OP] like this.
  3. Oct 15, 2023 at 11:02 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I did forget one very important step. You HAVE to remove the antenna. The snorkel is NOT going to work with the antenna in place. I have purchased a marine/RV AM/FM antenna and a mount that I plan to install somewhere in or around the bed when it arrives.
  4. Oct 15, 2023 at 11:04 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Does the 100 have an a pillar mount? Do you plan on using it if so?
  5. Oct 15, 2023 at 11:09 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It does but it’s not going to be functional. It would require a custom fabricated mount if you were to go that route.
  6. Oct 15, 2023 at 11:15 AM
    FrenchToasty
    Mo
    Bone stock
    At 60$ I’m half tempted to buy that kit only to use the inner fender tube and get a stainless pillar tube made……
    455h0le_dachshund likes this.
  7. Oct 15, 2023 at 11:23 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  8. Oct 15, 2023 at 11:26 AM
    FrenchToasty
    Mo
    Bone stock
    Definitely cheaper, but how more functional?
    I grew up watching Tim the Toolman Taylor, so I’m kinda a fan of Binford5000-ing lots of stuff I own. It would be a one off custom for sure.
  9. Oct 15, 2023 at 11:28 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  10. Oct 15, 2023 at 11:43 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Or just tape up the hole and you have a great way to tighten your antenna! Great post, BM.
  11. Oct 15, 2023 at 11:50 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  12. Oct 15, 2023 at 11:53 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    So the wife went to Six Flags yesterday with her girlfriends. She came home, walked through the door and sarcastically said, “I saw your mud bogging snorkel thingy. Looks nice”
    bulldog93 and FrenchToasty like this.
  13. Oct 15, 2023 at 12:03 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    They are supposed to help a ton with dust by getting the intake into cleaner air so I guess you could sell her on that.
    I've never really considered a snorkel, but damn that looks great. It is a dusty MF around here.
  14. Oct 15, 2023 at 12:05 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    No thanks to that shit the blows in from West Texas! :p
    There’s no “selling” her. She knows this truck has more seniority:rofl:
    JakeJake[QUOTED] likes this.
  15. Oct 15, 2023 at 12:07 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    BTW, you wouldn’t believe the 23 years worth of compost I pulled out of that fender :eek:
    FrenchToasty likes this.
  16. Oct 15, 2023 at 12:11 PM
    JakeJake
    2000 Tundra AC 4X4
    Truth!
    Although I think we get about 1/2 of ours from southern NM. Theres couple of climbing areas I go to that have very alkaline soil. The dirt access road is like driving on the moon. Cant see shit if you are behind another car.
    I added one to my eBay list. I'll probably do a cnc plasma A pillar bracket when the time comes. Happy to send you one if you are interested.
  17. Oct 15, 2023 at 12:12 PM
    FrenchToasty
    Mo
    Bone stock
    How sassy was her tone?
    https://www.youtube.com/watch?v=OowljuWOaac
  18. Oct 15, 2023 at 12:13 PM
    FrenchToasty
    Mo
    Bone stock
    Moon dust @AZBoatHauler
    AZBoatHauler likes this.
  19. Oct 15, 2023 at 12:15 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes, please. I bet there’s a market for that. I’ll buy the snorkel, you produce the bracket and we’ll bundle them for a huge mark up! o_O:thumbsup:
    In fact @JakeJake, if we had a donor truck, we could mold the neck perfect on each one and FGT owners would eat it up.
    Mr.bee and FrenchToasty like this.
  20. Oct 15, 2023 at 12:22 PM
    FrenchToasty
    Mo
    Bone stock
    My sequoia buddy used the same kit, and it attaches at a weird part in the door sil, requiring you to cut gasket material…….. not exactly my cup of tea. On my 4runner the TJM arm attaches to the face of the a pillar, which our sunny weather rotted out the rubber nut certs in no time…..
    so if I did attach to the A pillar, I’d use legit nut certs to some kind of bracket, without looking to hoky
    JakeJake likes this.
  21. Oct 15, 2023 at 12:24 PM
    JakeJake
    2000 Tundra AC 4X4
    sheeeeeit. I'll send you a handful if you want to give it a shot.
  22. Oct 15, 2023 at 12:25 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  23. Oct 15, 2023 at 12:26 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Black Mamba FGT Snorkel LLC
  24. Oct 15, 2023 at 12:30 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Whens the test run?
    JasonC., Voss, FirstGenVol and 2 others like this.
  25. Oct 15, 2023 at 12:31 PM
    FrenchToasty
    Mo
    Bone stock
    BMFGTSLLC
  26. Oct 15, 2023 at 12:31 PM
    JakeJake
    2000 Tundra AC 4X4
  27. Oct 15, 2023 at 12:34 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  28. Oct 15, 2023 at 12:36 PM
    FrenchToasty
    Mo
    Bone stock
    I’m not even trying that, but after a bumper is installed and liners cut to fit, the air box intake is super exposed, that’s my main concern. One of the work vans has the most glorious spray thru a puddle, no water gets anywhere near the windshield.
    In the truck, barely 2” of water on the road and I can’t go over 3mph without getting blinded by the windshield spray.
    whodatschrome and Voss like this.
  29. Oct 15, 2023 at 12:36 PM
    FrenchToasty
    Mo
    Bone stock
    Preach!!!
  30. Oct 15, 2023 at 12:36 PM
    JakeJake
    2000 Tundra AC 4X4
    Well that depends, how well do you speak Mandarin?
