Sequoia TRD Pro Max Tire Size
Discussion in 'Sequoia Builds' started by 2020cementsr5, Jun 13, 2021.
  1. Jun 13, 2021 at 5:12 AM
    2020cementsr5
    2020cementsr5 [OP] New Member
    I am almost positive this has been answered somewhere but I cannot find it. What is the max tire size I can fit on a Sequoia TRD Pro without removing anything and without any rub at all? It’s 100% stock currently
    donellyd likes this.
  2. Jun 14, 2021 at 6:56 PM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    I would love to know this as well. TRD Pro has 18" rims....
  3. Jun 15, 2021 at 10:15 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70-18 most likely. You may be able to get in 285/70s but there are very few tire choices in that size.
  4. Jun 15, 2021 at 8:41 PM
    2020cementsr5
    Does anyone have the answer to this? i know 285/65/18 fit but wondering if i could go bigger
  5. Jun 16, 2021 at 3:08 AM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    Does the trd pro ride higher than sr5’s, limited’s and platinums?
    Are you planning on keeping the stock trd wheels and what tires did you have in mind?
    I have a 2015 limited that I’m putting 275/70R18 on but the wheel offset is +45 so they will sit a bit further away from the UCA but not far enough to contact the fender. Same size tire but a more negative offset and you may start rubbing.
    2020cementsr5[OP] likes this.
  6. Jun 16, 2021 at 5:47 AM
    2020cementsr5
    I’m not positive if it rides higher, but definitely keeping the 18” TRD Pro BBS wheels
  7. Jun 16, 2021 at 6:06 AM
    frichco228
    The Sequoia Pro is the same ride height as the other trims. Think it is just the TRD Pro Tundra that has the extra 2 inches up front.
    from the webs: The front suspension features standard 2.5-inch internal-bypass Fox coil-over dampers with spring rates that are actually softer than the non-TRD Sequoia's. ... Although there's no suspension lift, the front end does gain 0.7 inch of additional rebound travel.
    Front end is that you need to worry about with clearance. Since Tundra's can fit 275/70 and even 285/70 18s with stock suspension and the stock +60 offset wheels, those are the sizes that will be about max tire without any fuss or trimming. Key is the wheel offset. 275/70 will fit and there are lots of good options in that size, readily available and less expensive than 285/70. Basically a 33x11 tire and they look really good on a stock truck. If you search the web, there are pictures out there of sequoias with 275/70-18.
  8. Jun 16, 2021 at 6:09 AM
    frichco228
  9. Jun 17, 2021 at 3:34 PM
    BassBlaster
    Jay
    2016 silver 1794
    Much appreciated!
  10. Sep 20, 2021 at 7:45 AM
    mattmillertime
    mattmillertime New Member
    2021 Sequoia TRD Pro
    Working on it slowly. Kuat Vagabond roof rack and Kuat NV2 bike rack currently.
    I have the same 2021 TRD Pro Sequoia. Did you end up going with 285/70 18's?
  11. Sep 22, 2021 at 6:13 AM
    2020cementsr5
    @mattmillertime I ended up not upgrading them just for $ reasons. I did the research though. 285/70/18 is the biggest you can go however there’s very few options. 275/70/18 is a very common tire and about same size.
    The new Tundra TRD Pro has very undersized 285/65/18s and I imagine FB marketplace will have plenty of them for cheap when it comes out and people start upgrading. Gonna keep an eye out there :)
  12. Sep 22, 2021 at 7:23 AM
    frichco228
    275/70-18 is a great size, run them on my tundra and yes, tons more tires available in that size vs 285/70.
  13. Jan 15, 2024 at 3:56 PM
    Harry.Crumb
    Harry.Crumb New Member
    Brad
    2023 Tundra
    275 60R 20 fits perfectly on a stock Sequoia with the factory 20” wheels. No rub, no spacers, no lift, no level.
    NCSCOTT likes this.
  14. Feb 19, 2024 at 5:49 PM
    donellyd
    donellyd Member
    Eastern PA
    2020 Sequoia TRD Pro
    SOLD: 2008 Sequoia Limited SOLD: 2004 Sequoia Limited
    Good post and discussion. I just picked up a 2020 Pro and am too keeping the BBS and no lift for now. Planning on the 275 70R 18 in General Grabbers. I like a little more poke than what comes with the stock +60 offset BBSs. Anybody know how a 1.25" spacer is going to affect running that size? Can I go bigger? Should I go smaller?
  15. Mar 1, 2024 at 1:57 AM
    farnsrocket
    farnsrocket New Member
    Here's a shot of 275/70/18's on 18x9 +18 wheels......not sure what a 1.25" space would put your offset at on the stock BBS rims.
    edit: just looked it up...........1.25" spacer is ~equivalent to running -32 offset. So in your case that would make your stock BBS rims +28 offset.
    And here they are on stock suspension
    NCSCOTT and donellyd like this.
  16. Mar 7, 2024 at 8:28 AM
    NCSCOTT
    NCSCOTT New Member
    Scott
    Charleston, SC
    Silver 2008 Sequoia 5.7L 2WD Towing Package, JBL on 35x12.5s
    2.5"/2.0" Lift Front Bilstein 5100s/Rear Coil Spacers w/Bilstein 5100s, 35" x 12.5 Nitto Terra Grappler G2, Hypertech Speedo Calibrator, XD 778 Monster 20" x 9" +35 offset, Go Rhino Matte Black Bullbar, Power stop Drilled/slotted rotors all 4 corners. Airlift 1000 Airbags. LED lo/hi Beams and Fogs replacement housings. Headlight Washers removed.
    I ran 1.25" Rugged Ridge Spacers on my 08 Sequoia with 275/60/20s 33.0" for a couple years with no rubbing & no Lift, which is almost the same exact size as the 275/70/18 33.2". It is also very easy to make a little inner fender well adjustments to stop any rubbing at that size.
    If Farnsrocket can run them at a +18 offset the +28 created by the 1.25" spacers is not a problem. A +35 offset is kind of the sweet spot to run the largest tire with minimal chance of rubbing but might require some other inner fender trimming/adjustment and or rolling the outside inch of the skidplate inward.
    donellyd[QUOTED] and farnsrocket like this.
  17. Mar 10, 2024 at 1:15 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    275s on 18s
  18. Mar 10, 2024 at 6:44 PM
    donellyd
    donellyd Member
    Eastern PA
    Nice pic. What's the middle #?
  19. Mar 10, 2024 at 6:53 PM
    Trdwillie14
    Billy
    2014 trd off road
    70 i think
    donellyd[QUOTED] likes this.
  20. Apr 18, 2024 at 10:20 AM
    Thundra27
    Thundra27 New Member
    Cement Tundra
    I’m running 35s on method nv +25 offset and oem tundra TRD off road shocks/springs.
    I removed the mud flaps and bent the skid plate to get rid of the rub.
    donellyd and S. Equoia like this.
  21. Mar 4, 2025 at 1:44 PM
    M_RED
    M_RED New Member
