Sequoia Headlight washers
Discussion in 'Sequoia Builds' started by Bulldog1776, Feb 22, 2021.
  1. Feb 22, 2021 at 5:48 PM
    Bulldog1776
    Bulldog1776 [OP] New Member
    2008 Sequoia
    I have an 08 sequoia limited that has the factory head light washers. I never use them, can I install any aftermarket headlights and just disconnect the washer itself if the aftermarket light is not made for them?
    Thanks guys.
    Tundra2 likes this.
  2. Feb 22, 2021 at 7:38 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Yes, you can disconnect them. Just plug up the passenger side that have the washer fluid tube coming down from the reservoir. I took mine off because i have the drl panel install.
    Bulldog1776[OP] and Tundra2 like this.
  3. Feb 23, 2021 at 6:12 AM
    Bulldog1776
    2008 Sequoia
    You have any pics of the drl you switched to? Thanks
  4. Feb 23, 2021 at 6:19 AM
    BrandonL812
    Brandon
    Bulldog1776[OP] likes this.
  5. Feb 23, 2021 at 11:49 AM
    Bulldog1776
    2008 Sequoia
    That looks great. Do they just snap into the spot where the washers were at?
  6. Feb 23, 2021 at 11:50 AM
    BrandonL812
    Brandon
