Sequoia 2008
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by bikebass14, Apr 20, 2025.
  1. Apr 20, 2025 at 6:46 PM
    bikebass14
    bikebass14 [OP] New Member
    Cruise control won’t turn on. Changed fuse and the cruise switch with the wiring. Neither of these fixed the issue. What should I check next? Thanks
  2. Apr 20, 2025 at 6:57 PM
    TheBeast The Beach
    horn good ? how about radio switch ? might be the clock spring slowly going out.
    KNABORES likes this.
  3. Apr 20, 2025 at 6:58 PM
    bikebass14
    Horn works. Radio controls on the left side of steering wheel don’t. Temp controls on the right side do work.
  4. Apr 20, 2025 at 6:59 PM
    TheBeast The Beach
    sounds like your clock spring is slowly going out. when the horn stops working, you know it's time to tear down the steering wheel :)
    any noise turning the steering wheel ?
  5. Apr 20, 2025 at 7:00 PM
    bikebass14
    Thanks a lot for the info. I guess to get cruise I may just have to put that on my list.
    No noise when I turn wheel that I have noticed.
  6. Apr 20, 2025 at 7:25 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Switch on the brake pedal, check that too.
    bikebass14[OP] likes this.
  7. Apr 20, 2025 at 7:33 PM
    bikebass14
    If there was an issue with the brake pedal switch would it affect the brake lights as well as cruise?
  8. Apr 20, 2025 at 7:35 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Should be a separate kill switch that is behind the brake pedal.
  9. Apr 20, 2025 at 8:03 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Is your engine light on? Any other codes? As dumb as it sounds, try disconnecting the battery for a few seconds and reconnect.
  10. Apr 20, 2025 at 8:04 PM
    bikebass14
    No engine light on. I have disconnected the battery with no positive results
  11. Apr 20, 2025 at 8:07 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    Shoot. Might have to scan it with a higher end scanner or techstream to see if there's anything helpful it can bring up. That's an odd one. Might have to do some continuity testing on the cruise switch wires from the switch to where ever they go to. To see if there a break or short in a wire.
  12. Apr 20, 2025 at 8:13 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    It’s 100% your clock spring. Just had the same thing…no issues other than cruise control not working. Was the clock spring.
    Rodtheviking and bikebass14[OP] like this.
  13. Apr 20, 2025 at 8:14 PM
    bikebass14
    I am going to order one. Around 35 bucks so it can’t hurt. How difficult of a job is it to change that?
  14. Apr 20, 2025 at 9:01 PM
    TheBeast The Beach
    pretty easy, just be careful with air bag charge and the steering wheel orientation or else you end up with a crooked steering wheel :) plenty of YT videos.
  15. Apr 27, 2025 at 8:18 PM
    bikebass14
    Wanted to thank everyone for the information. Changed the clock spring and cruise and left side of steering wheel are working again.
