Sensitive Topic? Adult pew pews" fitting in the center console?
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Mar 20, 2022.
  1. Mar 20, 2022 at 12:43 PM
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    I have a full-size pew pew and attempted to give it a secure location in the center console and make it accessible enough through the quick access slide. I don't want to have it near my knee in a driving position (may have a rubber band go off). Anyone care to share how they installed their rubber band pew pew?
  2. Mar 20, 2022 at 1:44 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
  3. Mar 20, 2022 at 1:50 PM
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    He is referring To firearms
  4. Mar 20, 2022 at 1:51 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Why? You're not leaving it in the truck and stepping away, are you? Because that sounds like a bad idea. Pewpew belongs where it was in the first place before you took it out to put it in the center console.
    Shadowfax1 likes this.
  5. Mar 20, 2022 at 1:51 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    The subject and question is rather obvious, where is your confusion?
    snivilous likes this.
  6. Mar 20, 2022 at 1:56 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I don’t know what the gen3 console looks like inside, but in my Gen 2 I had attached a panel of lip fabric to the inside side of it and then attached a maxpedition velcro holster to it. Made it easy to transition from my IWB to the console and then back.
  7. Mar 20, 2022 at 2:03 PM
    Sunnier
    Sunny
    San Diego, CA
    Easier if you don’t try asking in code. There are dozens of threads on here about firearm storage and transportation, in the console or on the driver’s side of the center shifter area. Maybe search around and, if you don’t find what you need, let us know more specifically what you’re wanting to do.
  8. Mar 20, 2022 at 2:13 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    There's an entire subforum dedicated to guns, not at all sensitive. The only thing sensitive is dissing Military/LEO and talking politics from the best I can tell. Hell they don't even censor the word fuck, it's awesome :D
  9. Mar 20, 2022 at 2:16 PM
    Buellride
    Olympia
    THE BOULDER
    Roger....some forums are super sensitive to "firearms", etc. and the admins could have an issue.....but it IS a truck forum. I will search around the forums but my question is specific to the Gen 3 center console. I want to avoid lift the center console lid if possible and use the quick access panel, the removal plastic divider that is immediately below the access panel is the most logical place...just wondering about suggestions.
  10. Mar 20, 2022 at 2:21 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Unfamiliar with 3rd gen as well but I agree its best kept where you keep it.
    What I do is use a drop leg holster if I know Ill be in and out of the truck a bunch or on long drives. Keeps it on my person but out of my spine, hip, or stomach when I'm seated
    DarkMint likes this.
  11. Mar 20, 2022 at 2:25 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Rip off the lid, problem solved. Your not James Bond, so your not going to get a pop up pistola holder in a truck.
    ACDC2ZZTop and Black widow TRD like this.
  12. Mar 20, 2022 at 2:56 PM
    TundraTun
    TundraTun New Member
    I literally posted about this today. There are pictures and all of the 3d gen OEM console safe.
    Blufin likes this.
  13. Mar 20, 2022 at 2:56 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    My bad. Obvious if you have heard of "pew pew" before. I was thinking phew phew and immediately thought shitty diaper as in the op wears adult diapers lol so for sure sensitive
    gj953, Blufin, TrimTab and 10 others like this.
  14. Mar 20, 2022 at 2:59 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  15. Mar 20, 2022 at 3:07 PM
    DarkMint
    Ben
    Best comment March 2022.
  16. Mar 20, 2022 at 3:31 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    @Buellride, guns aren't a touchy subject here. As long as you aren't talking about doing stupid/unsafe or illegal crap. That will get you some unwanted attention and, depending on what you are doing, a timeout of varying lengths.
    That said, when looking at making modifications, don't forget to look up laws for your state. Non-OEM hidden compartments may be illegal (generally for drug trafficking, but an uptight officer/prosecutor may try to reach).
    I installed a console safe in a truck and mounted a holster to the side of it to have relatively easy access and an out of site and secure spot for when the owner goes somewhere and has to leave the pistol behind.
  17. Mar 20, 2022 at 4:45 PM
    snivilous
    SW UT
    Wtf hahahaha
    OnThaLake likes this.
  18. Mar 20, 2022 at 5:04 PM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    Dude get the 5.11 single strap daily bag and put it in the hidden ccw pocket. I take mine into the office daily. I have my ccw license. I take my 45 ‘Muricaaa TRP Operator with me daily
    WesternDawg and Windsor like this.
  19. Mar 20, 2022 at 8:38 PM
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    No joke- in my old truck I put an old ratty looking diaper on top in the center console. It was totally clean, but I knew any valet, mechanic, etc. that opened that thing up would close it right back up. Under that diaper were a few things that probably would have been lifted over the years if someone went looking for them. Leatherman's, lights, etc..
    Love the new lock box on the '22.
  20. Mar 20, 2022 at 9:15 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It is funny how many of you only consider having 1 accessible firearm available.
    Always one on me, but it is nice to have spares.
    Different tools for different situations..
    To the OP, is a G17 with 2 spare mags full size enough?
    Although this may not fit in your half console vault of your 2022.
  21. Jun 7, 2022 at 3:15 PM
    Jman208
    Jman208 New Member
    2019 Cavalry Blue TRD
    What holster do you have for your G17 on the right? I like that minimalist trigger guard style!
  22. Jun 7, 2022 at 4:55 PM
    Kayaking Tundra
    Kayaking Tundra New Member
    2019 White Toyota Tundra TRD PRO
    If I left it in the truck i would buy a safe for it.
    Otherwise my Nightmare Sig comes with me.
  23. Jun 7, 2022 at 11:52 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Yes, it is just a trigger guard.
    Held in with a small rope secured to the magnet.
    Stays in place as you draw the firearm, if needed...
    phtm3vgs_zpsnqwovupw_e2740a938281b2c0ee9aa1b3cb84b6412144305d.jpg 10qur0f9_zps4aarmv8x_df5c19c1f809d8496a7e22e66a10008fa1f8ecad.jpg
    You'll find several on Amazon, they are all pretty much the same thing, molded Kydex with a rope attached..
    Amazon.com : glock trigger guard
    Black widow TRD likes this.
  24. Jun 8, 2022 at 12:42 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Drawing from, concealing, conveying, etc. in the center console has never really made sense to me. The delay in accessing the weapon makes that a no-go for me, and a center console doesn't secure the weapon it merely hides it from plain sight. Although, if you have to store it in the vehicle for some reason, I agree w/the safe/console vault concept.
    With that being said, ideally, you want the weapon on you (both in and out of the vehicle); this way your access/draw remains consistent in the event of an immediate imminent threat. Also, there is no risk of someone breaking into the vehicle and stealing the gun. However, as we age, most of us are no longer sporting a 32 waist; so, I understand the discomfort in maintaining it concealed on your person (in a seated position) for an extended duration, especially for those of us that appendix carry a full size weapon.
    My solution is this... If my commute is short distance, the weapon stays put (on my person in and out of the vehicle). Yeah, it pokes here and there a little (especially when first sitting down), but those 'hot spots' quickly become unnoticeable and you kinda find a niche' for it. If I'm going to be in the vehicle for a duration and don't want it pinned to my waste, I'll transfer the weapon to a holster I have mounted in the vehicle and then transfer it back to my waist prior to exiting the vehicle.
    My mounting set up is the MMP (Multi Mount Panel) specifically for the Tundra by Desert Does It (the original seat jacker dudes)...
    The MMP mounts to the front driver's or passenger's seat using the 2 front seat bolts. Their products are well made and have a nice black powder coat finish. Hardware bolts are grade stamped where appropriate. Anyhow once this is mounted to your front seat, you can install most molle or belt clip style holsters to the mount. I don't transition the holster back and forth just the weapon. Also, they have an optional clock-able extension, which allows you to elevate your mounting position and change angle of how your holster mounts to increase system flexibility.
    This allows you to adjust the position of the holster to give you easy access to your weapon and a natural and familiar draw angle.
    Plus, there is plenty of space along the mount to add a flashlight, knife, spare mag, handheld ham radio, handheld GPS, tourniquet, etc..... and have it all readily accessible
    DesertDoesIt likes this.
  25. Jun 8, 2022 at 3:26 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I just put mine in the little pocket of the center arm console. It sits outside every time, till I get out and it comes with me.
  26. Oct 1, 2023 at 6:53 AM
    vorkuta775
    vorkuta775 New Member
    why not just conceal on the body?
    Tripleconpanna likes this.
  27. Oct 1, 2023 at 8:25 AM
    pursuit2550
    My gun goes right on the center console armrest. No hiding, no storing it, no sliding into a holder. Or I just tuck it between the seat and console. If, I get pulled over, tuck it under my leg. It's with in the conceal carry law in FL.
  28. Oct 1, 2023 at 9:44 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Photos taken prior to aliens (the kind from outer space) taking my firearms...
    Eurodriver likes this.
  29. Oct 1, 2023 at 12:58 PM
    ArticTundra
    ArticTundra New Member
    Cold
    Wait wait wait....
    ADULT pew pews??
    As opposed to.....Child pew pews?!!?
  30. Oct 1, 2023 at 12:59 PM
    ArticTundra
    Cold
    Uhm. What are all those plastic looking cases with writing on them?
    ACDC2ZZTop likes this.
