Self Leveling with Lift?
Discussion in 'Suspension' started by cooperalant, Jan 13, 2023.
  1. Jan 13, 2023 at 7:04 PM
    cooperalant
    cooperalant [OP] New Member
    Alan
    2023 Tundra
    Does anyone know if your able to put a 4" lift on a rear self leveling air system?
  2. Jan 18, 2023 at 1:49 PM
    Quick_23TundraPlat
    Quick_23TundraPlat New Member
    2023 Tundra Platinum MGM
    Westcott Lift AVS/Rear Air, 35/12.5/18 Toyo Open Country AT3, Method 305 NV 18x9 (+18 Offset), Extang Solidfold 2.0 Tonneau
    The answer to that is a little murky right now.... some of the bigger suspension companies are still working on their lift kits for the AVS/rear air...and those with just rear air. As of right now there are a few options out there... but none of the ones I have see get you up 4 inches.
    Here are some of the few options available:
    1. Westcott lift (specific to AVS/air) works
    2. Front levels - pucks with an open top for the AVS sensors (RC 1.75, etc) works
    3. Kits specific to AVS (Readylift sst lift kit for AVS air-ride)
    The biggest issue is the rear... currently people are using spacers and adjusting the rear air control arm using aftermarket AFE arms that give you a bit more lift. Again - im not sure if any of these will get you as high as you want to go but its what we ave available at the moment. Ive talked to Icon and Cornfed and they are still in development unfortunately. Let me know how the search goes. Cheers-
