Seized rear diff breather valve
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Feb 21, 2021.
  1. Feb 21, 2021 at 1:42 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Alright guys so I took off my rear diff breather and a lot of pressure got released from the pumpkin, so its shot. Is there anyway I could remedy it before I get a part from Toyota? Is the top of the valve supposed to be kinda loose and free floating? Cause I saw in a youtube that one wiggles on the top. Maybe I could take some pliers and unseize it for the time being. I just dont want to drive around with a non functioning breather valve anymore. Any advice is much appreciated
  2. Feb 21, 2021 at 1:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did you hear air releasing or did you mistake that noise for a vacuum?
    Soak it in degreaser and it should be good to go, it’s only a one way breather, breathes out not in
  3. Feb 21, 2021 at 1:56 PM
    Professional Hand Model
    Hand Protectors
    Buy new. I posted the part number for you yesterday. Under $10.
    Shoulda just left it on and squiggled the cap loose. Now since its off use two sets of pliers and twist. Maybe smack it with a hammer loosely. Squirt it down with penetrator.
  4. Feb 21, 2021 at 2:08 PM
    Pucks18
    I'm just getting one from advance auti right now. It's just a valve so I dont mind going non Toyota
  5. Feb 21, 2021 at 2:11 PM
    Pucks18
    Def released pressure
  6. Feb 21, 2021 at 3:16 PM
    Pucks18
    Alright well, now I remember why to only buy Toyota parts.. the Chinese one does not screw in all the way by a hand, so I'm not risking messing up these threads. Went ahead and hammered on the my one, and got it to work.
    YardBird likes this.
  7. Feb 21, 2021 at 3:20 PM
    Hand Protectors
    That threading on the diff/breather is a special BPT (British Pipe Thread).
  8. Feb 21, 2021 at 4:34 PM
    Cogx5dad
    Cogx5dad New Member
    2010 SR5-TRD off road
    Debadged, waiting on bielsteins and shackles
    With whatever elements are corroding it that way you may want to consider the diff breather mod. I live in the rust belt and my 10 year old diff breather worked fine, looked in better shape too. Just food for thought. It’s cheap insurance!
    God bless!
  9. Feb 21, 2021 at 5:09 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Move it with diff breather mod
    decent price for kit here
    aredub and N84434 like this.
  10. Feb 21, 2021 at 5:23 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I did a DIY rear diff breather mod, super easy. Took about 15 minutes and totally worth it, especially if you hit the trails, if not it's an insurance piece.
    N84434 likes this.
  11. Feb 21, 2021 at 5:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The best repair is extending the breather and running a fuel filter at the end. Axle can breath in and out then.
    Sampson, rockmup, lsaami and 2 others like this.
  12. Feb 21, 2021 at 6:59 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
  13. Feb 21, 2021 at 7:56 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That's what I did. Made up my own, but got the breathing up and away from the axle.:thumbsup:
  14. Feb 22, 2021 at 3:40 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    It's just a loose fitting cap on a nipple. I'm pretty sure it allows air to pass both ways to compensate for contraction as well as expansion.
  15. Feb 22, 2021 at 3:56 AM
    Hand Protectors
    Its a One Way Valve. Outtie.
    FrenchToasty likes this.
  16. Feb 22, 2021 at 4:22 AM
    tvpierce
    Maine
    Sure, it's a crude one way valve: air moving out raises the loose fitting cap. But with the cap at rest, it doesn't actually seal, it just restricts the inward flow of air.
  17. Feb 22, 2021 at 4:30 AM
    Hand Protectors
    An Innie sometimes and Outtie most of the time. :rofl:
    tvpierce[QUOTED] likes this.
  18. Feb 22, 2021 at 4:38 AM
    FrenchToasty
    Mo
    Bone stock
    I believe it’s “spring loaded”
  19. Feb 22, 2021 at 4:58 AM
    Hand Protectors
    I remember blow testing mine and she only went one way.
    Sampson, tvpierce and FrenchToasty like this.
  20. Feb 22, 2021 at 5:25 AM
    Richid
    Richid New Member
    Swapped out the rear axle several years ago and checked the breather then. It was still fine, but I relocated it to the gas fill area as it was way easier to spend 10 minutes on that than replace axle seals. Old one was clogged.
    My luck is that the seals would leak when I needed the truck the most, so I figure it's cheap insurance.
  21. Feb 22, 2021 at 5:32 AM
    FrenchToasty
    Mo
    Bone stock
    Did the same thing with my bleeders, inquiring minds need to know!
  22. Feb 22, 2021 at 6:28 AM
    tvpierce
    Maine
    I just checked the Dorman vent in my parts bin (will be installed this spring) and it flows freely out, and restricted, but not sealed in. Maybe the Toyota parts seals better?
  23. Feb 22, 2021 at 6:47 AM
    Pucks18
    Be careful, pretty sure the threads on the doorman are not correct. Mine did not want to screw in, doorman part number :924262
  24. Feb 22, 2021 at 6:57 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I did a poor man's mod of pulling the little cap off the breather, pulling out the spring and valve, and coming the cap back on. airflow both ways, but no way for dirt and grime to get up in there because of the cap.
    my housing is so rusted there isn't really a breather to remove anymore. it's become 1 with the housing.
    :notsure:
  25. Feb 22, 2021 at 6:58 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I combined these two on my truck. The Dorman is restricted but not sealed breathing in as @tvpierce stated, then it goes to a fuel filter, then the axle.
    jimf909[QUOTED] likes this.
  26. Feb 22, 2021 at 8:24 AM
    Cogx5dad
    Cogx5dad New Member
    The reason it is supposed to be a one-way valve is so that when it is hot and immersed in water the rapid contraction won’t suck water into the differential. If you have modified yours in such a way that it breeds both directions and could be submerged you are seriously risking your differential.
  27. Feb 22, 2021 at 8:26 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    sure, if I drive through 18" of water. which I never have, and won't until I do a proper diff breather.
    the 1 way breather also makes it so that if you drive your hot differential through cold water, it sucks the co0ld water through your axle seals, ruining the seals, and your differential. either way, it's not meant to go through 18" of water.
    des2mtn likes this.
  28. Feb 22, 2021 at 8:27 AM
    Cogx5dad
    Cogx5dad New Member
    fair enough!
    Where I live, in the spring that’s not too uncommon of a swim for the truck.
    Sampson likes this.
  29. Feb 22, 2021 at 8:30 AM
    FrenchToasty
    Mo
    Bone stock
    I wouldn’t call myself a captain by any means...... well I do have multiple customized articles of clothing with “captain mo....” anyways, it was nice the times I’ve taken a boat out, and not have to worry about my axle seals or anything else sucking water in when the rear end kisses or dips in the water. I’d rather not ever drive thru anything that deep, but boat ramps are a different story
  30. Feb 22, 2021 at 8:46 AM
    Hand Protectors
