Seeking First Travel Trailer Advice
Discussion in 'Towing & Hauling' started by cloudvk, Apr 12, 2024.
  1. Apr 12, 2024 at 5:25 AM
    cloudvk
    cloudvk [OP] New Member
    2022 1794 TRD OR
    Hi all - I am shopping for my first travel trailer and am seeking advice on weight and length considerations for towing. Previous towing experience is just small U-Hauls. Here's my setup:
    Truck: 2022 Tundra 1794 TRD OR (no air suspension)
    Sticker Payload Capacity: 1281 lbs
    Hitch: Plan to use an Equalizer or other WDH/anti-sway option
    I have narrowed my search down to two primary trailer options:
    Trailer 1: Grand Design Imagine XLS 21BHE (https://www.granddesignrv.com/travel-trailers/imagine-xls/21bhe)
    Hitch: 456 lbs
    Unloaded Weight: 4698 lbs
    GVWR: 6395 lbs
    Length: 24' 11"
    Trailer 2: Grand Design Imagine XLS 23BHE (https://www.granddesignrv.com/travel-trailers/imagine-xls/23bhe)
    Hitch: 504 lbs
    Unloaded Weight: 5325 lbs
    GVWR: 6995 lbs
    Length: 27' 11"
    This will be a camper for trips for my small family. Minimum typical truck payload will be wife, toddler/young child, dog, and myself. Estimating conservative passenger payload of 500 lbs. Also have a tonneau cover and predator steps not factored into payload weight yet (plus whatever hitch I get).
    I plan on taking my truck to a CAT scale to get an accurate weight reading for correct potential payload calculations.
    My two main questions:
    1.
    How will I realistically be doing on payload with either of these trailers? I understand that is the primary limiting factor.
    2. Is Trailer 2 too long, at almost 28 feet? I know that the truck can tow it, but is it advisable given length and payload?
    Thanks!
  2. Apr 12, 2024 at 5:27 AM
    You’ll be fine with either
    cloudvk[OP] likes this.
  3. Apr 12, 2024 at 5:34 AM
    aj350925
    aj350925 New Member
    I just towed a 28' trailer weighing 11,000 lbs from Chicago to Daytona Fl and back. The truck ran flawless and never missed a beat. I have about 25k miles of towing over 10k on my 22 plat.
    You shouldn't have any issue with either of those trailers.
    KNABORES and cloudvk[OP] like this.
  4. Apr 12, 2024 at 6:20 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Whatever you get make sure it has 4 wheel/dual axle setup. Not much sucks more than a flat on a single.
  5. Apr 12, 2024 at 6:55 AM
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
    I had a 2008 Keystone Passport 245RB. Length was 27ft, dry weight of 4,420 lbs. I towed with a stock 2006 Tundra limited. Your truck is way more capable and will handle either of those trailers fine.
  6. Apr 12, 2024 at 7:36 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Use the trailer's payload to carry stuff for camping. This will help shift some of the load off the truck so you can carry passengers or pets.
    Consider 1,000 lbs of cargo and if loaded in the trailer, it would only add about 100 to 150 lbs against the truck's payload.
    daverxa and cloudvk[OP] like this.
  7. Apr 12, 2024 at 12:39 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is that quoted length the total external length from hitch to bumper or is it the inside length of the living area. My trailer is 25' inside and 28' outside and that's about as big as I would go.
  8. Apr 12, 2024 at 1:33 PM
    MtWhitney
    MtWhitney New Member
    '23 4WD Limited Dbl long bed
    You be able to tow either one comfortably. My 2023 has been towing at TT that is 27' 8" and have not had any issues. Mine is a bit heavier than your prospects but as long as you are getting some of the weight pushed back on to your front axles with the WDH, you should be OK. I made a trip to the CAT scale and weighed truck alone, hitched up to TT with and without WDH. I'm well under GCVW and only needed to adjust the WDH to get some weight returned to the front axle since the coil springs are squishy.
  9. Apr 12, 2024 at 2:20 PM
    MtWhitney
    Door jamb
  10. Apr 12, 2024 at 2:26 PM
    MtWhitney
    oops . . .mis read . . .
    For GVWR I was at 6800, my door jamb says max is 7310. For RAWR I am 3600, door jamb max is 3860 so you can see my RAWR is getting close. All hitchhikers will have to be 200# or less
  11. Apr 22, 2024 at 7:44 AM
    cloudvk
    2022 1794 TRD OR
    All - thank you for your feedback. To close the loop on this one, I ended up purchasing a Grand Design Transcend 235BH (https://www.granddesignrv.com/travel-trailers/transcend-xplor/235bh). Same GVWR as that 23BHE (6,995lbs) but a foot and a half shorter at 26' 4". Somewhat heavier tongue weight empty at 567 lbs.
    I also weighed my truck at a CAT scale and did find that the sticker payload rating is somewhat conservative. Sticker payload is 1,281 lbs; my measured max capacity is somewhere around 1,400 (factoring in tonneau cover and various other stuff in the truck, which could even be removed in worst case).
    I'll need to keep tongue weight on the lower end and manage WDH properly...which I can hopefully do...and will likely be at max payload if trailer is at max weight, which I do not plan on doing. Will see how it goes!
    Cpl_Punishment and Mattedfred like this.
  12. Apr 22, 2024 at 8:25 AM
    cloudvk
    2022 1794 TRD OR
    Thanks @Mattedfred , I appreciate that. Yes, at max trailer weight I need to be ~11% tongue weight to stay safe. So I hope I can manage that. Realistically, the only way I see myself hitting that max trailer weight is if I fully load up with water and gear for an extended boondocking situation, which is not our primary use case. Much more likely to travel with trailer very dry to campgrounds and do that sort of thing. This trailer also only has an 1,100 lb capacity over dry weight so I am discouraged from going overboard on gear from the get-go.
    Mattedfred likes this.
  13. Apr 22, 2024 at 8:37 AM
    cloudvk
    2022 1794 TRD OR
    Thanks, yes, I've already got this on my shopping list. Will check those brands.
