Seeking advice: Cold start groaning noise, crunch when rolling off curb
Discussion in '2.5 Gen Tundras (2014-2021)' started by modbox149, Jan 27, 2025.
  1. Jan 27, 2025 at 12:08 AM
    modbox149
    modbox149 [OP] New Member
    2015 Tundra 1794 Edition
    Noticing a couple issues with the 2015 Tundra and a shop has replaced a few parts with no luck, curious if you all have experienced these things?
    Groaning sound on startup:
    Been noticing recently on cooler mornings (around 50f), the Tundra makes an odd groaning type of sound for about a second. It sounds similar to maybe an alternator but I'm not sure why it's not consistent if it's that.
    Sound uploaded here: https://jmp.sh/6P7ec2GQ
    Crunch when driving off driveway:
    When I drive off the driveway, you can hear about 3 crunchy sounds, like parts are straining.
    Sound uploaded here: https://jmp.sh/eKN7Mzm4
    The parts replaced already that have not resolved the issues:
    Front Lower Control Arms / Bushings Cracked
    - Suspension Control Arm and Ball Joint Assembly
    Idler Pulley Kit
    - Accessory Belt Drive Kit (Standard)
    Sway Bar Links / Bushings Noisy
    - Suspension Stabilizer Bar Link Kit x2
    These issues do not occur after the vehicle is driven a bit / warmed up. Any advice or theories would be much appreciated, thank you!
  2. Jan 28, 2025 at 5:14 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If FFV the start up noise could be alcohol density. Mine never had a problem at 50 degrees only with temps in 30s and below. Search threads for hard or cold starts. Plenty of them.
  3. Jan 28, 2025 at 5:18 AM
    Start up noise could be AC or SAIS. Turn the AC off when you park at night and see if the noise is present when starting in the morning. Sounds more like one of the air pumps to me though.
    The noise when driving off a curb sounds like a bad shock, or leaf springs rubbing against each other. There are little pads on the ends of the leafs that help with friction. Pry the leafs apart and apply some lube to the pads. See if the noise goes away.
