Secondary Transmission cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by 808Tunda, Dec 24, 2020.
  1. Dec 24, 2020 at 11:46 PM
    808Tunda
    808Tunda [OP] 808Toyclusive
    Honolulu, Hawaii
    2016 Magnetic Gray SR5 4x4 Custom
    8 " Custom ProComp Coil over Kit built by 4 wheel parts Hawaii.
    Has anyone installed a secondary transmission cooler on a 2016 SR-5 4x4 Tundra with tow package. I have the OEM cooler that is present but wanted to add a secondary to maintain proper temperature. Comments, suggestions, recommendation from the forum would be very helpful ! TY & Aloha!
  2. Dec 25, 2020 at 12:54 AM
    TXTundra2722
    2015 Black Tundra
  3. Dec 25, 2020 at 4:48 AM
    What temps are you getting now?
    Cpl_Punishment likes this.
  4. Dec 25, 2020 at 4:51 AM
    timsp8
    NY
    I added one to my 2010. Mounted it in front of the sc radiator which was in front of the other radiator/condenser. I put a magnafine inline filter in it too. Just bolt it up and hook up the hoses from and to the other atf cooler. It was easier on the 2010 because the grill raised with the hood.
    Saltyhero13 and 808Tunda[OP] like this.
  5. Dec 25, 2020 at 5:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Start by defining your design objective. Reduced transmission fluid temperature?...That's too vague. Define what ATF temperature will be acceptable to you under your worst operating conditions. What fluid temperatures are you now seeing under those conditions?
  6. Dec 25, 2020 at 5:06 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I know that on my 2018 with tow package that pinning open the thermostat lowers my temperatures so that towing my loaded dump trailer weighing a little over 10k does not get over 185, so why the need for auxiliary cooler? Are earlier models running hotter?
  7. Dec 25, 2020 at 5:19 AM
    Vizsla
    Vizsla 2 = 2.5
    There is a forum member that is maybe making a kit?
    https://www.tundras.com/threads/2011-2018-external-transmission-cooler.80225/#post-2031275
    I’ve seen this installed on a few different Toyota’s locally.
    https://automatictransmission.com.a...-kit-to-suit-toyota-tundra-with-6-speed-auto/
  8. Dec 25, 2020 at 7:29 AM
    808Tunda
    Honolulu, Hawaii
    TY for the info & links , I 've had high temp reading of above 220 deg. twice on the soft sand beach trails on H4 and once with warning lights on dash.
    Vizsla and Leo's first like this.
  9. Dec 26, 2020 at 2:54 PM
    timsp8
    NY
    220 isn’t too high if you are off roading, going slow, and pushing your truck hard. The light coming on is a concern. My 2010 atf overheat light came on around 255 and the 2019+ are at 302, so a 2016 would be somewhere between there.
    Check your fan. Put a piece of paper in front of the radiator and the fan should hold it to the radiator. If the paper falls, your fan isn’t spinning correctly.
    How many miles do you have? Maybe time to change the atf. I think Toyota recommends changing at 60k if you drive hard. If you do change it, keep a sample and get it tested.
    Terndrerrr and Cpl_Punishment like this.
