Secondary Air Injection Valve (AIP)
Discussion in 'Performance and Tuning' started by Benstoy, Jul 20, 2018.
  1. Jul 20, 2018 at 3:19 PM
    Benstoy
    Benstoy [OP] New Member
    2008 Tundra Crew Max 4x4
    3/1 ready lift, added step bars, blue tooth, back up camera, assault roll up tonneau cover...has spray in liner, fender flares, leather
    So the other day I had the dreaded limp mode. Mechanic confirmed that the secondary air injection valve was stuck open and that it would be $2800 to repair. After researching, I decided to bypass that system, as it was all replaced under warranty once before in 2013. There are two systems available, a Rutech and Hewitt-tech. The Rutech is cheaper, but doesn't come with a wire that engages the bypass whenever the key is turned. In other words, if you left the key in the on position, it would render the bypass useless when you tried to start the engine. I discovered that there is something different about the 08's that makes the Rutech systems malfunction on some trucks as well. After talking with both companies, I felt Hewitt tech was more knowledgable and more professional over all. They also had a kit wired specifically for 08's that resolved those issues, so that helped too. The harness part is totally plug and play, but the plates that block the exhaust port were a pain in the butt. The key was a well placed crowbar. Anyways, works perfectly. Codes eliminated. Saved my family $2500 today and the install looks totally factory. Just wanted to give an update. Oh, I called Toyota, and they told me to suck an egg.....that they had fully satisfied their end of the bargain and that the replaced parts in 2013 weren't guaranteed not to wear out again. Happy spending! Hope this helps someone doing research.
  2. Sep 7, 2018 at 7:08 PM
    Tundraissue
    Tundraissue New Member
    2012 Tundra
    Going through this now. What a nightmare. I'm happy that you were able to handle it yourself. I bought a toyota because they had a reputation for handling things like this and the last time I tried to fix something complicated I ended up having to buy my Tundra because I caused more damage than I fixed on the old vehicle. No doubt in my mind that trying to fix this myself will end in the same result lol
  3. Sep 7, 2018 at 7:24 PM
    TheBeast The Beach
  4. Sep 7, 2018 at 7:38 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Good to see you got it fixed with the bypass and saved money. The AIP system is such a failure, Toyota really dropped the ball on this. I had this system fail on my Tacoma, at relatively low mileage so I feel your pain.
    equin likes this.
  5. Sep 7, 2018 at 8:38 PM
    Benstoy
    Still running great! Couldn't be happier with the bypass. The hardest part was the cut off plates on the exhaust, but with some patience and ingenuity, its doable for most do it your selfers.
    Filthyphil likes this.
  6. Oct 24, 2018 at 6:21 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Just got this code again, this time bank 1. I am looking at purchasing the Hewitt kit also, hoping for good results!
  7. Nov 14, 2018 at 4:57 PM
    jnevill
    jnevill New Member
    2005 Tundra SR5 TRD 2wd
    Stereo, steps, more stereo
    Question, if you install the bypass while the system is still operational, do you also need to install the block off plates?
  8. Nov 15, 2018 at 5:01 AM
    parker44
    parker44 New Member
    You should. The bypass kit essentially keeps the system from running, and the block off plates help seal everything off so no more air is sucked in.
  9. Nov 15, 2018 at 5:16 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Is this a issue for all model years
  10. Nov 15, 2018 at 5:25 AM
    parker44
    parker44 New Member
    I'm not sure about the newer models, but it was fairly common from about 05-12.
    NjPro likes this.
  11. Nov 15, 2018 at 5:27 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    I went to the Hewitt site and they have the bypass systems only up to 2012.
  12. Nov 15, 2018 at 5:51 AM
    parker44
    parker44 New Member
    What year do you have? That could be all that they make? Call them and talk to them, they are very knowledgeable about their products, and do all the testing in house. They are actually about 20 minutes away from me, so I just drove by and picked mine up.
  13. Nov 15, 2018 at 5:59 AM
    ToyotaTundraMike
    2015 Tundra
    Haven’t heard any instances of this being an issue on a 3rd gens (15+).
  14. Nov 15, 2018 at 6:13 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    I have a 2017
  15. Feb 12, 2019 at 4:41 AM
    Onjaampk
    Onjaampk New Member
    SC
    '11 Tundra Lemon
    None
    Is the photo the actual place the bypass kit attached to?
  16. Feb 22, 2019 at 5:42 PM
    Benstoy
    Yeah, what you are seeing is the bypass harness connected to the original harness. It's plug and play. Where that loom heads off to the right is a little electronic deal that adheres to the backside of that plastic panel. You can't see it unless you know precisely what you are looking for. It all looks factory.
  17. Feb 22, 2019 at 6:02 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Nice fix, 2014 here with 67k miles no problems with it yet. Makes me want the DAP tune which fixes the AIP problem plus other improvements
  18. Aug 28, 2019 at 7:44 AM
    GreggB
    GreggB New Member
    Gregg
    09 4.7 2wd dbl cab tundra
    Had your ecm been reflashed when the Aip was replaced? I just installed bypass it worked for 100+ miles now it just goes right back into limp mode everyone's saying ECM reflash caused AIP to constantly check resulting in CEL VSC lights.
    If so, Toyota has permanently lost my loyalty... Not only do you give us a faulty product you make our fix inoperable so you can keep suckering $2500 out of us? Not cool
