Secondary air injection pump and valves
Discussion in '1st Gen Tundras (2000-2006)' started by JessiJane06Tundra, Oct 27, 2018.
  1. Oct 27, 2018 at 6:52 PM
    JessiJane06Tundra
    JessiJane06Tundra [OP] New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Check engine light is on and codes are reading that the valve are stuck closed. Ive read it's a typical problem with first gens. Should I pay the 200 for the bypass kit and install myself or go thru a mechanic and spend 100s to 1000s between parts and labor to repair faulty parts.
  2. Oct 27, 2018 at 6:58 PM
    Casper421
    In the woods
    06 DC
    @piscespokerbrat just installed the bypass the other day with no issues yet. Read the link below.
    https://www.tundras.com/threads/2005-tundra-4-7-p2445-p0418.33095/#post-826215
    https://www.tundras.com/threads/wha...1st-gen-tundra-today.2558/page-55#post-829977
  3. Oct 27, 2018 at 6:58 PM
    Casper421
    In the woods
    06 DC
    And welcome!
  4. Oct 27, 2018 at 8:16 PM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Hello to you, and thank you for sharing his personal experience. I bought the truck earlier this year and I stare at that engine light every day, I can't seem to get off the fence. I know I technically could fix it either way myself, but replacing all the parts properly just doesn't seem to have a big enough reward.
  5. Oct 28, 2018 at 12:44 AM
    piscespokerbrat
    piscespokerbrat New Member
    Jeremy
    Portland, OR
    2005 Tundra Access Cab 4.7 4x4
    None yet - plan backup camera, led lighting, head unit, box organizer, and canopy or tonneau if one can be found local affordable.
  6. Oct 28, 2018 at 3:40 AM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Take good pics of the location of the exhaust plates for me. I seem to be having a really hard time seeing clearly in any videos. The rest of the set up seemed self explanatory. I've found several cheaper versions, should I just splurge on the 300$ one everyone seems to use.
    piscespokerbrat likes this.
  7. Oct 28, 2018 at 4:14 AM
    koditten
    Kirk
    Midland of the Mitten
    This is the fix I used. Save some money by doing it yourself.
    Black Wolf likes this.
  8. Oct 28, 2018 at 9:20 AM
    piscespokerbrat
    Jeremy
    Portland, OR
    The plates was easy. I did the drivers side from above, and the passenger side from the wheel well. Since you have the same codes I did, you'll need the bypass module and proxy pack. That's $313 shipped priority vs $400+ to fix it all correctly. I'll see if I can get my pics uploaded today. One thing about the plates, don't take the nuts off. Loosen then enough to slip the plate in, then finger tight to hold it. The gasket stays between the plate and the head.
    HewittTech01 and Casper421 like this.
  9. Oct 28, 2018 at 1:36 PM
    Professional Hand Model
    Hand Protectors
  10. Oct 28, 2018 at 2:32 PM
    koditten
    Kirk
    Lol. Oops.
    Will go to a PC.
  11. Oct 28, 2018 at 3:38 PM
    koditten
    Kirk
  12. Oct 28, 2018 at 5:25 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I like the washer boobies.
  13. Oct 28, 2018 at 5:39 PM
    koditten
    Kirk
    I did too, that's why I saved it.
    Hopefully the second link was more appropriate.
  14. Oct 28, 2018 at 5:43 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Washer boobies are ALWAYS appropriate.
  15. Dec 26, 2018 at 8:42 PM
    stevechumo
    stevechumo New Member
    I read somewhere that after installing the bypass kit, the truck needs to be idled at least 10 seconds for it to work correctly. I went through replacing the parts with the aftermarket parts, and it was a real headache. So maybe the bypass kit is the way to go. :)
    HewittTech01 likes this.
  16. Dec 27, 2018 at 4:03 AM
    koditten
    Kirk
    Any time the batter is disconnected, the truck will have to go thru a 2 start initialization. !st start the truck will stall, second start the truck will start recognizing all the sensors.
  17. Aug 4, 2020 at 10:57 AM
    Tundraip
    Tundraip New Member
    Has anyone gone through emissions after installing the bypass kit?
  18. Aug 4, 2020 at 8:55 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    shifty` and GODZILLA like this.
  19. Aug 4, 2020 at 9:38 PM
    Casper421
    In the woods
    06 DC
    I passed smog in CA with the kit.
  20. Aug 4, 2020 at 9:45 PM
    Tundraip
    Tundraip New Member
    Really? That gives me a good feeling, thanks!
  21. Sep 12, 2020 at 5:31 PM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Thanks for the advice. Easier than I thought it was gonna be. After the reset it, it fixed the PO442 code like I had hoped. But the check engine light came back on giving me 2 codes for emissions systems leak and purge flow. Tried 2 different new gas caps..no change. I had a new/used fuel tank installed by someone else 1 month ago so it might be the fuel lines, or purge valve or an avalanche that just never stops. At least I get to spend quality time with the truck every Sunday.
  22. Sep 28, 2022 at 1:00 PM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @JessiJane06Tundra I know we are a little late to this party but hope you decided give us a call and install the Bypass Kit. Would love to hear how it went. I also wanted to provide some additional thread resources for anyone one looking for more information about this inevitable issue.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
    Tundra2 likes this.
  23. Sep 28, 2022 at 2:16 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    I dealt with this a year ago and had the same symptoms. So I wrote this big hog to give people on instructions for replacement. and there is also a good resource linked for bypassing. If you lose it it's pinned at the top of the 1st gen page =)
    https://www.tundras.com/threads/secondary-air-system-sais-replacement-info-and-instructions.90175/
    Tundra2 and HewittTech01 like this.
  24. Sep 28, 2022 at 2:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I believe she sold her truck after some Jack ass "mechanic" punched a hole in her gas tank...
    https://www.tundras.com/threads/2006-sr5-v8-rwd-for-7-000.85201/
  25. Sep 28, 2022 at 2:26 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    Terrible. I also didn't even see the last OP post date *face palm*
    Tundra2 likes this.
  26. Sep 28, 2022 at 2:40 PM
    shifty` I'm having daydreams about night things
    Yup, that's the only danger/downside to @HewittTech01 poring over for threads to resurrect.
    It's great for future reference of random fly-by-night users who are looking for answers.
    It sucks for regulars who visit daily and don't look at the original post date but want to help.
    Tundra2 likes this.
  27. Sep 29, 2022 at 5:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    2 revivals in one thread. Neat.
    Tundra2, wandering_boy and shifty` like this.
  28. Sep 30, 2022 at 6:51 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    Lol so It got shifty and I to appear?
    Tundra2, bmf4069[QUOTED] and shifty` like this.
  29. Sep 30, 2022 at 6:53 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I believe so! Happens to the best of us!
