SECOND WEEK OF OWNERSHIP
Discussion in 'General Tundra Discussion' started by VEGITOMAN85, May 24, 2019.
  1. May 24, 2019 at 9:03 AM
    VEGITOMAN85
    VEGITOMAN85 [OP] New Member
    GERRY
    2019 TUNDRA TRD OFF ROAD
    NONE YET
    Hey all, second week was good. Still only have 600mi on her and im loving it more every time i drive it, getting about 17mpg average still and thats around town. Something i do want to address that im sure a bunch of you have dealt with is that awful bouncing in the rear at highway speeds. Some of you that live in the reno area know that a lot of the highway is cement slabs that are uneven. I dont know if is the suspension or the truck is just the perfect length to get this bounce on them but its pretty ridiculous. It seems to me that the stock shocks even though they are bilstiens arent enough to handle the weight/spring rate of the truck. Ive done a bunch of reading and it seems for what i want the 6112 kit will be perfect so i will be going to 4 wheel parts this weekend to order that setup and will probably get a set of 33" tires not sure on what yet but i had the terra grapplers on my last truck and they were great. Any suggestions or ideas would be awesome but i have done my reading so dont scold me please lol
  2. May 24, 2019 at 10:05 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    If you are lifting the front then you will want to get a hold of @Coachbuilder1 to order some shackles, he will guide you to the right rights size based on the amount of lift you want. They help TREMENDOUSLY with the bed bounce.
    15whtrd and VEGITOMAN85[OP] like this.
  3. May 24, 2019 at 10:13 AM
    VEGITOMAN85
    GERRY
    NONE YET
    I'll look into that also I was just going to get some 1" blocks and tapered shims to keep the pinion angle correct. I don't plan on lifting it very much maybe just 2" in the front and 1" in the rear to keep some what of a rake for when I tow/haul stuff. The tires will add a little more than .5" so 2-3" total which is just fine because I still have to load my dirtbike in the back and the lower the better I just want to correct the bounce BS
  4. May 24, 2019 at 10:56 AM
    Sephon
    Northwest PA
    I did 2" up front with shims and 5100's and did the Coachbuilder +2 shackles instead of a rear block and my ride is lots better than stock. Really helped with the bed bounce.
  5. May 24, 2019 at 10:59 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome from San Diego! I’ll second the @Coachbuilder1 recommendation. I installed a set of TRD Pro takeoffs (about 2” up front) with the CB+2s in the back. The stance, ride and rake are perfect in my opinion.
  6. May 24, 2019 at 11:02 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and:worthless:
  7. May 24, 2019 at 11:05 AM
    33” are basically stock sized tires
  8. May 24, 2019 at 11:18 AM
    VEGITOMAN85
    GERRY
    NONE YET
    i currently have 275/65/18 which is a 32 im looking at 285/70/18 so like 33.5 i guess lol
    its a little bit taller and wider but mainly i just want a different tire, the terrain out here isnt very michelin friendly
  9. May 24, 2019 at 12:59 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Welcome from CT
    Shackles will be better than blocks every day of the week and even more on a Saturday.
  10. May 24, 2019 at 2:20 PM
    15whtrd
    15whtrd Mr. Blonde
    The polyurethane bushings that come with the coachbuilder shackles really make a huge difference with the bounce. They come with the correct size carrier bearing spacers as well.
  11. May 24, 2019 at 2:38 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    We don't have very many CONCRETE roadways in Maryland and from what I read, it's a good thing we don't!
