Second gen vs 2.5 gen shell
Discussion in 'Tonneau Covers, Caps and Shells' started by Tundra1D6, Dec 17, 2021.
  1. Dec 17, 2021 at 3:07 AM
    Tundra1D6
    Tundra1D6 [OP] Well that escalated quickly…
    Looking for a used topper for my 2008 crew max. I’ve found a semi local Leer in my color but the seller said it was installed on a 2020.
    Will a topper from a newer truck fit the older bed? I’ve seen threads about older tops not fitting the beds/tailgates of newer trucks. Never the other way around.
  2. Dec 17, 2021 at 4:26 AM
    ezdog
    ezdog New Member
    Gateway To The West
    The newer one will be 1.5" too long for the bed on your truck.
    The tailgate thickness is the difference and because a standard flip up back window on a shell needs to index against the tailgate to shut and lock usually this can be an issue for sure.
    Going the other way with an older shell on a newer truck can be easily dealt with but unless the one you are looking at is not a standard flipping back window I dont think it will work.
  3. Dec 17, 2021 at 5:13 AM
    timsp8
    NY
    I took my ARE cap off my 2010 and tried to put it on my 2018 and, like others said, it was about 2”-4” too short due to the wider tailgate. It wouldn’t close. However, the other way around (2.5 to 2 Gen) it will be too long. It’ll close but you’ll have a gap where water or thieves will be able to get in.
  4. Dec 17, 2021 at 5:52 AM
    Tundra1D6
    Thanks all for the information.
    Sometimes I really dislike my 08.
    If anyone is looking, in Nashville someone has a Leer silver sky topper off of a 2020 for super cheap. Facebook market place
    I’ll keep hunting
