Seatbelt Chime Solution
Discussion in '2nd Gen Tundras (2007-2013)' started by trog636, Mar 17, 2023.
  1. Mar 17, 2023 at 1:55 PM
    trog636
    trog636 [OP] New Member
    2011 White Tundra Rock Warrior
    I have been searching for weeks on a good way to disable this with a good solution besides taking to dealer, using a dummy clip, trying to get the software running, pulling springs, etc.
    The easiest and most simple solution I found was to take a magnet and put it on the bottom part of the buckle on the side nearest the center console. The one I used stayed in place without any adhesive or anything. Annoying seatbelt chime is gone and I can still use my seatbelt.
    tigerpaw1129 and Cruiserpilot like this.
  2. Mar 17, 2023 at 1:57 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How strong of a magnet are we talking here
    Cruiserpilot likes this.
  3. Mar 17, 2023 at 1:58 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    If you ever want to do it the easiest way via software just buy this. Plug into obd2 port and less than 5 mins you can have it paired and turned off.
    comes with a one month subscription, change the setting, cancel subscription and you’re good to go. And then if you ever need to change it in the future you just buy a month subscription
    also allows you to change a few other things if you like
    https://www.turnermotorsport.com/p-...ETiVDQmiqBqk5arKgD5_ns-kUln17ENwaAmVSEALw_wcB
    trog636[OP] likes this.
  4. Mar 17, 2023 at 2:20 PM
    trog636
  5. Mar 17, 2023 at 2:27 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    If you search Amazon for Techstream you can get hacked software and an OBD connector to let you change lots of settings (including seatbelt chimes), program keys, diagnostics, etc. Requires a Windows laptop but it does a lot and anybody who does any tinkering should have it.
    VCI J2534 Cable Fit for Toyota TIS Techstream - Latest Version V16.00.017, Firmware V1.4.8, Scanner Adapter Diagnostic Cable Scan Tool, OBD2 Diagnostic Cable, Support Win XP WIN7 WIN10 32/64bits https://a.co/d/3WJcTy8
