Seat heater install.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jmakingmecrazy, Dec 3, 2019.
Aftermarket Seat heater power
  1. Seat heater
    6 vote(s)
    100.0%
  2. Power for aftermarket seats
    0 vote(s)
    0.0%
  1. Dec 3, 2019 at 4:55 PM
    Jmakingmecrazy
    Jmakingmecrazy [OP] New Member
    Brentwood,NH
    2019 TRD PRO Crew Max
    Magnuson supercharged
    Looking for support- just purchased a 2019 TRD PRO. About to install aftermarket seat heaters. And suggestions on ACC power and constant power options to tap from in under dash fuse panel?
  2. Dec 3, 2019 at 5:03 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Well how much current (watts) will the heaters pull? That will determine where you should connect.
    I'd recommend a full hot connection to the battery with a fuse right at the battery connection point for ultimate protection. That way in your NH winters you'll get the maximum amount of power to heat up.
    Then remember you can use the passenger heater to keep food toasty hot on the way home any day of the year - that's the best use of my seat heaters in central Texas, woohoo! Luck and enjoy your Toyota.
  3. Dec 3, 2019 at 6:32 PM
    Jmakingmecrazy
    Brentwood,NH
    Thanks for the recommendation. Here in New Hampshire, we Just got dumped on by Mother Nature with 2feet of snow with heavy water content. These heaters cannot get here fast enough.
    I’ll check the actual draw- in looking at other Tundra OEM fuse panels with factory installed seat heaters, it’s calling out a 20A fuse, in efforts to keep it as OEM “looking” as possible, I’ll do a draw test from a 12v battery on the bench first.
  4. Dec 3, 2019 at 6:48 PM
    Johnsonman
    Austin
    Sequoia
    A 20amp source would provide 20Ax12V=240 watts of current. Assuming each seat (bottom & back) use 85 watts, then you can wire up the front two seats safely to thd 20amp source, leave some some to spare. Luck and enjoy.
  5. Dec 3, 2019 at 6:52 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    I just installed a kit in my wifes 19 4runner each side came pre wired with a 10 amp inline fuse.
    So i would guess the amp draw would be 5 to 8 amps each side. I put a 7.5 amp fuse in temporary because i popped the original 10 amp and it worked fine with the 7.5 fuse till i got a 10 amp replacement
  6. Dec 3, 2019 at 7:00 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    It didn't come with a heated seat?
  7. Dec 3, 2019 at 7:06 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    I thought the same thing, i figured a trd pro would be loaded
  8. Dec 3, 2019 at 7:25 PM
    Rlynch356
    Rlynch356 New Member
    Apex NC
    2019 Tundra TRD Pro
    Nope... they don't even offer it from the factory for 19's that i am aware of. Basically a Pro is a SR5 with leather, wheels, and Fox suspension, we still get the Standard urethane steering wheel too.
    I am having to do the same thing.
    TundraTRD08 and IsaiahCanada like this.
  9. Dec 3, 2019 at 10:37 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
  10. Dec 3, 2019 at 10:49 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Stoddard, are you saying to tap the 4 gauge lead?
    That may be a cleaner install than I have with my add a fuses....
  11. Dec 4, 2019 at 1:28 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I installed some from Amazon in my 2016 last year. There's a fuse for heated seats under the dash. Yes, even if you dont have them. I used an add a fuse and worked perfectly. I ran both wires to the center console, where I put the switches, and to the dash where the fuse was. There's a write up on this page somewhere I used to guide me.
    Tamutundra and Tundradrenalin like this.
  12. Dec 4, 2019 at 2:29 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Although some may not agree, I tapped into my 12v cigarette light plugs to power my aftermarket seat heaters.
    I don't use those plugs for anything else.
    I actually replaced both console 12V, one with USB and the other with USB and HDMI that goes to my HU.
    I did keep an inline fuse that came with the heaters.
    They really don't draw that much power.
    You'll rarely use them on HIGH unless you want your ass on fire.
    No way would I put them unswitched to ACC directly from the battery.
    Too easy to forget to turn them off.
    Have not had a problem in 2 years since the install.
    I put them in just for the wife, but I use them myself a lot more than I thought i would.
    41957919-5D7F-49C4-981A-AB53A8D3BD9C_zps_efa7a15038faeabfb492faba96168d70dc84df76.jpg
    8FCE5971-E516-486C-905D-027100B9B88A_zps_3ef68b014cf90b239f84ed11d3bf58c47da8aef2.jpg
    C03F9DE0-748B-4C2E-A4B5-7728F2BCFE23_zps_98f3938d6790354c12a0df3f318f1e169dfdc771.jpg
    Used this video..
    https://www.youtube.com/watch?v=REG3_MZX7Mk
    I used 2 of these...
    https://www.amazon.com/gp/product/B00HSHRTNE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    And this tool and rings..
    https://www.amazon.com/gp/product/B00FS0WFAA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    JoshuaA, Tamutundra and Berdine like this.
  13. Dec 4, 2019 at 4:50 AM
    Jmakingmecrazy
    Brentwood,NH
    thanks for the response. I’ll run with 20amp and grab power from the fuse bank under dash. The brand is called Watercarbon and likely made overseas ( trying to be politically correct here ) and the switch for me is what matters most.
  14. Dec 4, 2019 at 4:58 AM
    Jmakingmecrazy
    Brentwood,NH
    thanks Sstoddard- this is almost the same I’ve purchased.
    WATERCARBON Universal Built-in Car Heated Seat Heater Pad Car Seat Warmer Covers K... https://www.amazon.com/dp/B074C5GPQ7/ref=cm_sw_r_sms_c_api_i_TZ65DbAXF5BYV
  15. Dec 4, 2019 at 4:59 AM
    Jmakingmecrazy
    Brentwood,NH
    No sir- I was baffled by it too. Coming out of a limited dbl cab, this was a change. Urethane steering wheel, plastic color coordinated bumpers.
  16. Dec 4, 2019 at 5:56 AM
    Jmakingmecrazy
    Brentwood,NH
    Not sure if the image posted of the actual location I’m intending to install the switch in. The width and length seem to be in line with what I purchased, I’m concerned about the depth of the new switch. C564B26E-C3BE-45C9-BD70-2497A0D4FA94.jpg
    Rlynch356- I'll keep you posted on how it goes. Seat heaters are coming tomorrow.
  17. Dec 4, 2019 at 7:41 AM
    panicman
    Eric
    This was true up to 2017, I think. ‘18 and up does not have this provision on the fuseblock.
  18. Dec 4, 2019 at 9:08 AM
    Berdine
    Binghamton, NY
    That's good to know, I'm planning to do this on my 2020
  19. Dec 4, 2019 at 9:53 AM
    incredibillhulk
    incredibillhulk New Member
    Bill
    Here's our videos from the Tacoma cover removal and heating pad install (Tundra is nearly identical):
    I too simply tapped into the power outlets to power the heating elements.
  20. Dec 4, 2019 at 11:11 AM
    DesertRoads
    Utah's West Desert
    Thank you for the write up on the heated seats. Good info. Surprising what some manufacturers add as options, or leave out for mid-upper level trims.
  21. Dec 4, 2019 at 1:18 PM
    AdventureAddict
    AdventureAddict New Member
    Josh
    19 Cement Limited TRD off road
    I didnt realize the Pro didnt come with heated seats
  22. Dec 4, 2019 at 1:53 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I need cooled seats since I'm in desert AZ, lol.
    SMTundra and Berdine like this.
  23. Dec 10, 2019 at 10:35 AM
    Jmakingmecrazy
    Brentwood,NH
    I once lived in Gilbert just outside of Tempe. Loved it but, land locked.
  24. Dec 10, 2019 at 11:51 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    If your interior left kick fuse panel is like this, there’s a blank 20A Seat Heater you can add a fuse (Amazon). It’ll only operate when the ignition is on so no fires, unless as you said you want access to constant power. Put the switches where you can easily see and operate while driving.
  25. Dec 10, 2019 at 11:57 AM
    Berdine
    Binghamton, NY
    I stated this earlier, what year is your truck? They stated that 2018+ doesn't have it. I'm looking to do this soon! Thanks. I'll have to look at my 2020 later, I had it in my 2016
    JoshuaA[QUOTED] likes this.
  26. Dec 10, 2019 at 12:05 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Sorry missed that, I guess that fuse panel is for 2014-2017. Bean counters took it out damn
  27. Dec 10, 2019 at 12:08 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Where I put my switches. There’s a YouTube vid somewhere how to remove the center.
  28. Dec 10, 2019 at 12:17 PM
    matictundra
    Franco
    AZ
    But you must admit, it is a big city landmass wise. I'm in Chandler myself and also land locked.
  29. Dec 10, 2019 at 12:51 PM
    Berdine
    Binghamton, NY
    No, it's cool, I was hoping you were 18+ and it existed. I just dont feel like crawling up under there and look in this pouring rain lol
  30. Dec 10, 2019 at 12:52 PM
    Berdine
    Binghamton, NY
    Put mine here in my 2016
    1lowlife and JoshuaA like this.
