Seat buckle won’t click
Discussion in '2.5 Gen Tundras (2014-2021)' started by chemist71186, Nov 2, 2019.
  1. Nov 2, 2019 at 8:56 AM
    chemist71186
    chemist71186 [OP] New Member
    my uncle bought a 2019 tundra and sold me his 2014 tundra. We swapped the seats out and the buckle was well. Out of my truck and his, the ONLY buckle that won’t fasten is the middle back seat buckle on my truck. Now I do notice that when it comes to the (male) metal pieces that actually insert into the buckles, there are two different shapes depending on front seat, back seat, etc and they are that one has a small square opening in the metal and the other has a bigger rectangular opening in the metal. I also checked that his metal piece has small square and mine has the big rectangle. Now if both didn’t work, I’d say we just need to swap them but only mine doesn’t work now. Any thoughts?
  2. Nov 2, 2019 at 9:29 AM
    P-Factor
    P-Factor New Member
    My .2 cents - Make sure that your not trying to buckle it into the child seat receiver...
  3. Nov 2, 2019 at 10:20 AM
    chemist71186
    I did check for this but no that wasn’t it
  4. Nov 2, 2019 at 10:32 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Since it's a major safety component the dealer may fix it for free, worth a try at least.
    Pinay and chemist71186[OP] like this.
  5. Nov 2, 2019 at 11:17 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I would swap all the belts and buckles over, I think everything is just bolted in. Or at least the one that isnt clicking in
  6. Nov 2, 2019 at 12:17 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Does it need flipped over? No issues with the tundra, but my old tacoma would only buckle one way. If turned 180 it would buckle. Just a thought.
    Pudge likes this.
  7. Nov 2, 2019 at 1:16 PM
    chemist71186
    I tried flipping the metal piece over and inserting it that way to no avail
  8. Nov 2, 2019 at 3:46 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Probably have tried this but did you test the receiver with your other belts/receivers that reach and vice versa. Also look for a foreign object in the receiver. It doesn’t take much.
  9. Nov 2, 2019 at 5:16 PM
    Justin Case
    Justin Case New Member
    TX
    Does the male buckle have a notch in the tip? The buckles on my 2019 are female specific. Just another "irritating on purpose" thing Toyota did. Toyota better get their act together or this will be my last.
    chemist71186[OP] likes this.
