Sealing The tundra bed for camper shells
Discussion in '2.5 Gen Tundras (2014-2021)' started by PeakIT, May 10, 2020.
  1. May 10, 2020 at 8:48 AM
    PeakIT
    PeakIT [OP] Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I use the back of my truck to camp in. But any dusty road pretty much covers everything in sand. How are you guys sealing the tailgate sides ETC.
  2. May 10, 2020 at 8:56 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    From my experience, a standard tailgate seal that you get at a local truck store doesn’t work well. I get water in the sides.
  3. May 10, 2020 at 8:57 AM
    15whtrd
    15whtrd Mr. Blonde
    They make tailgate seals. But none of them are really one hundred percent. You have to get creative. Use a tailgate seal kit and maybe some other material that you have to add to it. The kits usually go on the bed itself and the tailgate presses against it. But on the upper portions there is a gap still. You need to add more seal on the tailgate itself.67CF0B61-4B8E-4810-92CB-03FA81EDE364.jpgD4E862E4-698D-4974-A11A-41310B11E372.jpg Here’s mine. See I got creative with some extra weatherstrip I had lying around. It’s still not 100% because of the design of the tailgate jam. There’s also drain holes in your bed at the base of the bulkhead that allow dust in. As well as the upper portion of the bulkhead where it meets the bedside leaves a small area for intrusion.
  4. May 10, 2020 at 9:21 AM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    I bought a kit off Amazon, been super happy with it. Not sure of the brand, but it was the highest rated and $. Haven’t had any dust or water issues yet, keep my black gun cases in back on the way to shooting matches with ranges on dirt roads, zero dust in truck bed.
  5. May 10, 2020 at 9:29 AM
    15whtrd
    15whtrd Mr. Blonde
    The best way to test is to install the seal and get inside the bed and look for daylight through any of the gaps. Also a garden hose sprayed on any of the seams.
    Over the LINE likes this.
  6. May 10, 2020 at 9:33 AM
    Captainjohn
    2019 Tundra Dbl cab
    My bed has liner sprayed from factory also,so the gap is a bit less than without. I also did a real good job with installing, making sure that I had full contact with tailgate
  7. May 10, 2020 at 9:44 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I used the Extang tailgate seal kit. It actually applies to the outer edge of the bed. I found that after one hunting season (which is when I open and close the tailgate the most), the lower piece started to come loose. I then put a piece of the white foam seal (for windows and doors) along the bottom, and it’s held up much better.
    For the camper;
    I got the flat rubber seal (about 1/8” thick) from AutoZone.
    I didn’t want to apply any foam/seal to the tops of my bedsides so;
    I actually flipped my camper over on it’s top (with the help of some family) and applied the seal to the underside of the camper. The seal I used is about 1 1/2” wide, so I ran two strips to cover the entire part that sits on the bed sides. If memory serves, I think I only needed one strip across the top.
    No water or dust. Been on since last fall.
  8. May 10, 2020 at 10:09 AM
    PeakIT
    Utah
    The sides of the tailgate look like the biggest gaps. I can see like and inch of light coming thru them while driving.
    15whtrd likes this.
  9. May 10, 2020 at 11:22 AM
    Tundra9831
    Tundra9831 New Member
    Good idea for a tailgate handle. I haven't tried closing the tailgate from inside with my new topper, but this looks like a valuable addition.
  10. May 10, 2020 at 12:08 PM
    PeakIT
    Utah
    Yea its hard and I’m tall i have to toe hook the shell and lean way out to get the gate to close from the inside
  11. May 10, 2020 at 5:43 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just sealed mine up...no light shining thru...easy to figure out...the moisture and dust is sure to be slowed now! Thanks for everyone's suggestions!
    Joe333x, TTund16, PeakIT[OP] and 2 others like this.
  12. May 10, 2020 at 8:58 PM
    mofferman
    mofferman New Member
    Windsor, CO
    2019 double cab
    HulkSmurf14, Ely010606 and 15whtrd like this.
  13. May 10, 2020 at 10:11 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    That looks pretty sealed to me. Nice job.
    HulkSmurf14[QUOTED] likes this.
  14. May 12, 2020 at 3:26 PM
    Captainjohn
    2019 Tundra Dbl cab
    Yup, that’s the same product I used from Amazon, very please with results!
    HulkSmurf14 likes this.
  15. May 12, 2020 at 3:31 PM
    HulkSmurf14
    2014 Tundra Limited
    It's a good foam for sure! I purchased mine at Lowe's for about $8...
  16. Jul 3, 2020 at 12:58 PM
    DavidinPhx
    DavidinPhx New Member
    Phoenix
    2021 DC Tundra SR5
    Icons, Deavers, 34s, 4.88s, F&R e-lockers, Ovrlnd Camper, & other stuff
    Tacoma’s have a real problem with dust/water coming through UNDER The plastic bedside caps due to the voids/holes in the top “rim” of the bedside covered up by the cap.
    Do Tundras experience this? I’m contemplating a Tundra plus popup shell and wondering if I need to pull off the caps a seal underneath?
  17. Jul 4, 2020 at 11:28 PM
    HulkSmurf14
    2014 Tundra Limited
    It would be peace of mind, but I'm happy with the level of "sealed" I'm experiencing currently...
  18. Jul 5, 2020 at 12:59 AM
    TTund16
    TTund16 New Member
    Tailgate seal.
  19. Jul 5, 2020 at 6:58 AM
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Yes they do. I have a lot of dust on my interior bed rails. Need to pull the tipper and seal the bed caps.
  20. Jul 24, 2020 at 8:19 AM
    DavidinPhx
    Phoenix
    2021 DC Tundra SR5
    Any feedback on how you sealed the caps? KB Voodoo makes nice, flat aluminum cap replacements for Tacoma’s that a lot of guys with Drifter pop ups seal underneath and use, but the don’t make em for Tundras. I’m looking to get a Tundra for a camper shell so trying to figure out ahead of time. Did you remove the caps, seal and just replace the caps?
  21. Jul 24, 2020 at 8:58 AM
    Snowcat4360
    Derek
    I have not done mine yet, but my topper guy said to lift the topper than use silicone under the plastic caps on the interior edge.
  22. Jul 24, 2020 at 1:45 PM
    Stig
    Stig New Member
    Sequoia.
  23. Jul 24, 2020 at 2:13 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I used the weatherstrip tape also, like 1" wide, and about 1/2" thick. Works for dust but haven't tested it with water. It does work for rain.
    15whtrd[QUOTED] likes this.
  24. Jul 24, 2020 at 2:20 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I have found that I need real rubber to get it sealed correctly the cheaper foam does not do the job that well.
    They sell the good stuff at Advance Auto Parts much to my surprise but if you have a Body Shop Supplier where you are you can get the same rubber for a lot less money too.
    I like the stuff that is 2" wide and has 2 adhesive strips on it this covers more of the rail to top edge and seems to just seal better every time for me.
    It is also important to look at the cab end which on the 3ed gen is rounded for some reason and tougher to get a good lasting seal on and this is where I might use Silicone from a tube to enhance adhesion on the round surface.
    Especially crucial seems to be that the thickness of whatever you use equal the same overall edge under the front and sides or the corners in front will leak every time.
    I have even used a seperate set of clamps along the cab edge to make sure that the weird round edge makes a decent seal.
    At the tailgate you just have to play around with it,again the real rubber seals until you get it sealed well enough but luckily I have no tailgate and the French Doors are a lot easier to get sealed tight for sure!
    15whtrd likes this.
