Sealing garage floor yourself?
Discussion in 'Home Improvement' started by okstate, Jan 6, 2019.
  1. Jan 6, 2019 at 3:16 PM
    okstate
    okstate [OP] New Member
    not sure if this is the right place to post this. If it is not please move it. ;)
    I am finishing up building our house and wanted to know if anyone has sealed their garage floor themselves. How easy/hard is it? any before/after pics?
    Thanks!
  2. Jan 6, 2019 at 3:18 PM
    I have and you can just roll it.
  3. Jan 6, 2019 at 3:26 PM
  4. Jan 6, 2019 at 3:32 PM
    Vizsla
    Vizsla 2 = 2.5
    I just use a garden sprayer, most concrete guys use them as well.
  5. Jan 6, 2019 at 3:55 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I did just recently and used the rustoleum epoxy kit. Was super easy, just kinda time consuming since I had to scrub a bunch of grease and oil stains off first. It all in the prep like with any paint job.
  6. Jan 6, 2019 at 3:56 PM
    39 Chev
    39 Chev New Member
    2019 Cement Limited
    Depends on whether you are talking about just sealing the concrete or doing an epoxy floor. As others have said above, if you are just sealing the concrete, that is easy. Depending on the type of sealer you are using, you can either just spray it on with a Hudson sprayer or roll it on straight from the bucket.
    If you are talking about epoxying the floor, that requires quite a bit more prep and time. I epoxied in my shop with a commercial product that my cement contractor uses. The only thing I might do different is to use the chips that I bought with kit. In my previous shop, I used the chips and decided I wanted a "cleaner" look this time. The only downside without chips is that the chips tend to hide the little chips and scratches that accumulate over time.
  7. Jan 6, 2019 at 4:08 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    For sealing a low pressure sprayer will do the trick.
    Epoxy is a whole other story!
    NewImprovedRon and Vizsla like this.
  8. Jan 7, 2019 at 4:27 AM
    Slayer
    Slayer Member
    Slayer
    here's some advise from someone from the Pacific North WET.
    I recommend doing a moisture test prior to installing any type of product.
    tape down some plastic.. maybe a 4'x4' area..leave overnight.
    if you have any moisture on the underside of the plastic then do not seal.
    otherwise you will have a mess on your hands that will be ugly & hard to remove.
    ..Slayer
  9. Jan 7, 2019 at 4:35 AM
    War Machine
    War Machine SSEM # 5 3MW
    The epoxy is definitely something I’m considering. How long to cure?
  10. Jan 7, 2019 at 5:31 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    I did mine with epoxy 13 years ago when we had our house built. At that time is was easy, the garage was empty and the floor was new. there are few steps required to prep the floor before applying the epoxy but it was easy. My suggestion is to do it now before you move anything in. Mine has help up well but after 13 years starting to show it's age and I am dreading doing it again with all the stuff that will have to come out of the garage.
  11. Jan 7, 2019 at 5:54 AM
    Steve6
    Steve6 New Member
    Tucson
    I've always wanted to do the epoxy finish but lately I've been thinking that VCT (Vinyl Composite Tile) might be a better way to go after seeing a few epoxy failures. Another option to consider if you haven't made up your mind on the epoxy.
    Squatting Pigeon likes this.
  12. Jan 7, 2019 at 6:09 AM
    Squatting Pigeon
    Holden
    North Texas
    Vct would be a quick and easy garage floor but has fairly low moisture limits. If you decide to go this route make sure you test the RH and vapor emission of that slab!
  13. Jan 7, 2019 at 6:15 AM
    Squatting Pigeon
    Holden
    North Texas
    Depends if you go for a true epoxy 'coating' or a rustoleum-type floor system which would be more of an epoxy modified paint.
    The paint systems generally cure much quicker but aren't quite as hearty and durable in the long run. Depending on the specific brand, figure 3-5 days for coatings, and 2-3 for the garage floor kits from big box stores.
    War Machine[QUOTED] likes this.
  14. Jan 7, 2019 at 6:17 AM
    Big Yota
    Big Yota New Member
    2018 Double Cab TRD Off-Road 4x4 Blazing Blue Pearl
    Cap (soon)
    +1 regarding the Moisture Test that someone else mentioned above. Steve6 note that VCT adhesive is latex based (water). If you end up with moisture escaping from below the slab the glue will release and you will have tiles popping. The glue will turn into a white grease-like mess. You will then have to hire a professional to clean up that mess. The most important thing that you want installed before a concrete slab is poured is a HD vapor barrier. Not 2-3 mils but 10-15 mils. Also make sure your reinforcing mesh is set on blocks to keep it from sinking to the bottom of the slab where it does nothing. Watch to make sure that the concrete guy is not adding a lot of water to make the concrete easier to work with thus changing the mix and the strength.
    I would not recommend the VCT because once it gets wet it will be like an ice skating rink. You could end up sliding into the wall if you come in hot.
    NewImprovedRon likes this.
  15. Jan 7, 2019 at 8:07 AM
    Steve6
    Steve6 New Member
    Tucson
    Thanks for the info. I had not considered the vapor emission issue but I was aware of the potential slippery when wet concern (not usually a problem in Tucson). Looks like I need to do a little more research; may end up with the epoxy after all.
    I have seen several epoxy finishes in garages and in hangars where the finish peeled up where the rubber tires sat regularly. In one of the hangars I used to work out of we had to put carpet remnants under the tires to keep the finish from peeling. The last hangar that I worked out of had a much higher quality finish that we never had problems with. That finish was installed professionally over the course of several weeks (big hangars) using industrial quality material and it was awesome.
  16. Jan 7, 2019 at 8:33 AM
    Berettafan
    Berettafan New Member
    2017 CM
    We had a detached garage built a couple years ago. Power trowelled the concrete floor and it doesn't need to be sealed. Oil (thanks Toyota for the drain pointed at the wheel...at least I won't have to worry about those parts rusting) just sits on the surface and won't stain.
    Something to consider.
  17. Jan 7, 2019 at 9:53 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    My dad and brother have been building high-quality custom homes for 40 & 25 years respectively. For sealing concrete they have always used an acid wash to make sure it's clean then seal with SUPER Diamond Clear (similar to what Prostar posted above but add SUPER :) ). Due to regulations in Ohio you can't buy it here so they would drive 3hrs to Michigan and buy a truck load of it 1-2 times a year. This stuff will leave your concrete looking wet instead of drab/dry and the water will bead up and run off. You need to seal it once a year for the first 2-3 years then you should be good. Maybe need to apply every few years after that if it's high traffic or exposed to the elements.
    As for epoxy - the products have changed quite a bit over the last 10-15 years. The epoxy back in the day was junk and didn't last long. Now it's gotten better and the 2-part epoxy from Sherwin Williams is good. Make sure you wear a nice respirator when putting it down cuz without one it'll get you HIGH...then SICK! Also, to get it to last a while and stick properly you need to prep the unsealed concrete by shot-blasting it. It's basically a device that takes ball bearings or bee-bees and hits the concrete so that little chunks break apart. This gives the floor a little texture for the epoxy to adhere to. Of course sweep up all the dust/little chunks before applying the epoxy.
    NoMoTaco and Prostar 190[QUOTED] like this.
  18. Jan 7, 2019 at 10:25 AM
    Cfincke
    San Antonio
    I did my garage floor 7 years ago today. I did it 2 months after moving into my house and I purposely kept the garage pretty empty, knowing I would be doing the floor and walls. After 7 years, the only spot I am having issues with, is where the previous owner had a defective water softener and stored the salt bags. the salt penetrated into the slab and is now causing the coating to separate from the concrete. I had ground the flooring with a diamond wheel and did an acid wash in the softener area too. I have a 2 coat system - epoxy with flakes, then a clear coat with sand for some grit.
  19. Jan 7, 2019 at 11:22 AM
    Big Yota
    Big Yota New Member
    Cap (soon)
    For an epoxy floor shot blasting is recommended. Typically is required for any warranty. Check the manufacturers requirements.
    SOB likes this.
  20. Jan 7, 2019 at 12:08 PM
    When I get home, I’ll snap a picture of my garage.
    TheBeast likes this.
  21. Jan 7, 2019 at 12:45 PM
    32D9A343-F99C-47A1-B7FD-34DAE92CFFA0.jpg A7B02DBC-3C98-4566-9829-7E709AADA1C5.jpg 2848121C-4FBA-4EA6-9242-E32EA47664FF.jpg
    I didn’t apply this covering, so I can vouch for the install.
    However, the black spray paint is holding up better. I use this to put my drivers side Jeep tire on so the passenger side doesn’t run into the door rails.
    Mountun Goat likes this.
  22. Jan 7, 2019 at 12:57 PM
    Squatting Pigeon
    Holden
    North Texas
    The garage floor at my last house looked like that. The PO very obviously didn't prep anything beforehand, and it came up in sheets in some places....
    ColoradoTJ[QUOTED] and TheBeast like this.
  23. Jan 7, 2019 at 1:12 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    for anyone checking into this jump over to garagejournal.com page. there is more info on product and application then you can possibly read.
  24. Jan 7, 2019 at 1:59 PM
    So the million dollar question:
    How did you get the residual craptastic epoxy material up?
    I personally don’t want to be on my knees all day with a 4.5” angle grinder and wire wheel.
  25. Jan 7, 2019 at 2:01 PM
    I personally would never put down an epoxy floor cover with all the welding, cutting, grinding I have been known to do. That covering, no matter who did it wouldn’t last a few months.
    Slayer and Prostar 190 like this.
  26. Jan 7, 2019 at 2:01 PM
    Squatting Pigeon
    Holden
    North Texas
    You can rent a shotblaster or stand up floor sander to get it up.
    The shotblaster will make quick work of it, but it will profile the floor in the process. So you will have to coat it again with something else.
  27. Jan 7, 2019 at 2:06 PM
    Thanks. Stand up floor sander it is.
  28. Jan 7, 2019 at 2:16 PM
    I personally have never seen a epoxy floor hold up long term.
    Slayer likes this.
  29. Jan 7, 2019 at 7:25 PM
    Slayer
    Slayer Member
    Slayer
    personally,
    I chose the vinyl tile route when I remodeled my modest garage / man cave.
    I alternated between black & grey.
    it's been down for 15 years.. still looks awesome. cleans up well to boot.
    did the entire floor in about 3 hours.. these are milled / manufactured very well & go together easily.
    look at this option if any of you are thinking about a garage floor.
    these can be found a Lowes.
    I also built custom cabinets to meet specific needs & sizes of my tools and used these tiles on the countertops.
    ..Slayer
  30. Jan 7, 2019 at 7:39 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Wow:eek: you win. That’s beautiful
    39 Chev[QUOTED] likes this.
