SCS Ray 10’s leveled
Discussion in 'Wheels & Tires' started by fundra_goes_west, Oct 24, 2018.
  1. Oct 24, 2018 at 5:41 PM
    fundra_goes_west
    fundra_goes_west [OP] I’m just a guy with a girl
    Evan
    2022 SQ8
    yep tricked you into clicking because I don’t have a pic, but will soon! I’m that guy, I’ve read probably 100,000 or more posts on here but looking for specific ‘will it fit’ advice. So sorry everyone... here it goes:
    Is anyone running 1.9” lift on he front with SCS Ray 10’s (or similar offset +25) with 295/70/18 OR 275/70/18’s? (I am going to run the Falken’s)
    Pics would be much appreciated if you have either! I’m just nervous one will be too small and one will be a pain and too much trimming.
    You guys rock thank you a ton in advance! (Yes I have read, reread and reread the will it fit thread and the SCS group buy thread)
  2. Oct 24, 2018 at 5:44 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    From all the research I've done on here, you're going to rub quite a bit with 295s on that lift and offset. I'm going to have a 3" lift installed next week with Ray10s and 295s, and I'm still a little worried that some chopping will be necessary.
    fundra_goes_west[OP] likes this.
  3. Oct 24, 2018 at 5:46 PM
    fundra_goes_west
    Evan
    2022 SQ8
    Yeah I see that too. But then you see the Pro thread where they are running stock wheels and 295/70. That’s the only part that confused me.
  4. Oct 24, 2018 at 6:00 PM
    Degausser
    Kevin
    GA
    2024 LR SR5
    I assume they're having to do some chopping and/or add spacers to make that work, but like you, I really don't know.
  5. Oct 24, 2018 at 6:04 PM
    fundra_goes_west
    Evan
    2022 SQ8
  6. Oct 24, 2018 at 6:19 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Bilstein 6112's at 1.9 setting, driver side shim with 285/70r18's on SCS Ray 10's.20181012_091711.jpg
  7. Oct 24, 2018 at 6:22 PM
    fundra_goes_west
    Evan
    2022 SQ8
    4wd. Definitely helps!
  8. Oct 24, 2018 at 6:23 PM
    fundra_goes_west
    Evan
    2022 SQ8
    What tire is that the Terra Grappler? How much trimming?
  9. Oct 24, 2018 at 6:26 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Ridge Grappler, trimmed skid plate, pushed fender well forward about a inch.
  10. Oct 24, 2018 at 6:32 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    I am glad you started this thread. I was set on getting SCS +25 offset rims, 295/70/18, and 2.5” setting on 6112s in front and 5160 stock in rear.
    The whole time i thought they would fit with minimal adjustments. Am i wrong???
  11. Oct 24, 2018 at 6:43 PM
    fundra_goes_west
    Evan
    2022 SQ8
    So that pretty much answers my question 275/70 it is.
  12. Oct 24, 2018 at 7:16 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    You should be good with that setup. I was lifted that height with 285/70r18 on a +18 wheel so 295/70r18 on a +25 should be good. Might have to trim the skid plate
    Silv333[QUOTED] likes this.
  13. Oct 24, 2018 at 7:42 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Ok thanks
  14. Oct 24, 2018 at 9:00 PM
    bomber
    bomber New Member
    2017 tundra cm 4x4
    How about 6112 leveled to 1.9 with 295 70 18 on ray 10. Bmc and nfab m-rds pre runner front bumper. Do you think it can be done without rubbing?
  15. Oct 24, 2018 at 9:26 PM
    dsmith13
    dsmith13 New Member
    Derek
    2018 SR5
    Week old 2018. Bilstein 5100s set on middle ring. 275/70/18 Falkens. Take front mud flaps off. I had to unbolt and push forward the plastic bumper liner. Drill couple new holes and screw back in. Very slight rub in reverse full lock. Ordered the Coachbuilder bumper shims to clear everything completely.
  16. Oct 24, 2018 at 9:37 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I’m running 295/70/18 on a 3/1 lift. I rubbed on the front fender liner. So I did a full removal of it. There’s a few threads on how to push the liner forward instead of removing it though.
  17. Oct 24, 2018 at 9:38 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    That should work perfectly fine.
  18. Oct 25, 2018 at 6:49 AM
    bomber
    bomber New Member
    2017 tundra cm 4x4
    Thank you Guhner123. I think so too
