Screw in tire, near side wall.. repairable recommendations
Discussion in 'Wheels & Tires' started by phabej, Jul 11, 2019.
  1. Jul 11, 2019 at 6:47 AM
    phabej
    phabej [OP] New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Hey guys, so this morning as I was starting to drive off to work my TPMS was set off and when I looked at the PSI it was showing 20 (rear passenger tire)! Last evening it was around 30, I was wondering why it was low..
    So I pumped my tire back up and scanned my tire for puncture, sure enough there was a puncture.
    From what I've researched, it may not be repairable it's about 1 1/4" from the outside?.. thoughts?
    The tires have around 9,000 miles. Thanks.
  2. Jul 11, 2019 at 6:51 AM
    Rica25
    Ricardo
    Tulare
    Dealer will most likely not repair that due to being near side wall....but a smal shop might due to some times not giving a shit about your safety......lol.....not recommended better off purchasing a tire
    15whtrd and YardBird like this.
  3. Jul 11, 2019 at 6:57 AM
    phabej
    Yeah that's my conclusion too in case I need to tow or haul heavy stuff..
    Rica25[QUOTED] and YardBird like this.
  4. Jul 11, 2019 at 7:04 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    Most stores here will patch as long as it's in the tread.
    Rica25 and phabej[OP] like this.
  5. Jul 11, 2019 at 7:05 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Plug/patch inside repair
  6. Jul 11, 2019 at 7:09 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Just repair it yourself, takes a few minutes, done it many times in the same area..
    Black Wolf likes this.
  7. Jul 11, 2019 at 7:15 AM
    yeah, it's far enough away from the sidewall.
  8. Jul 11, 2019 at 7:30 AM
    phabej
    would plugging it yourself cause issue later down the road if you're hauling a heavy load in the bed or pulling a trailer?
    The last time I had to repair a tire was like in the 90's and I did it on small vehicles.
    THanks
  9. Jul 11, 2019 at 7:31 AM
    phabej
    is this a DIY or done a the shop?
    I've scheduled an 11AM today at Discount Tires.. let's see what they say about it being repairable.
  10. Jul 11, 2019 at 7:37 AM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    These are what I use. I've even got one in my trailer tire with zero problems. They are great.
  11. Jul 11, 2019 at 7:41 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    If repairable cost is usually about 25 bucks at a tire discounters or similar. Usually will repair if in tread. Not sure how close. They'll pull tire off and patch from inside. Personally I'd feel better about that for 25 bucks if they'd do it. Sounds like others have good luck though diy
  12. Jul 11, 2019 at 7:57 AM
    jtaco11
    jtaco11 New Member
    2 brand new tires
  13. Jul 11, 2019 at 8:22 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Looks like it is outside Discount's repair zone to me. I have plugged several trailer tires and never had a problem. I would not hesitate to plug a screw or nail hole.
  14. Jul 11, 2019 at 9:34 AM
    phabej
    Sounds good.. i'll venture that route if they won't repair it.
  15. Jul 11, 2019 at 10:45 AM
    phabej
    so is this something I would do by pulling the tire off?
  16. Jul 11, 2019 at 10:47 AM
    TRDProLife
    St.Louis
    yes the tire has to come of to do the plug/patch. you have to push it through from the inside of the tire.
  17. Jul 11, 2019 at 11:37 AM
    phabej
    Awesome. Discount tires fixed it! Looks like the plug type.
    Fix was free and they rebuilt part of my tpms as well.
    Awesome thanks Discount tires on 192nd in Vancouver.
  18. Jul 11, 2019 at 7:07 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    I grew up on a dirt road, many nails in the tires. I used the rubber snakes for anything close to the tread. I have never had them fail. Probably used 25 of these patches.
    We all have a spare anyway..
  19. Jul 11, 2019 at 8:06 PM
    phabej
    My coworker used these on his focus the other week after it got a nail right in the center of the tire.
    Those were the stuff I used long ago too.
  20. Jul 11, 2019 at 8:13 PM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    Still use these.. I have never had a problem patching holes with these pretty much anywhere on the tire.
    phabej[OP] likes this.
  21. Jul 12, 2019 at 4:58 AM
    ed3trd
    ed3trd New Member
    2017 Silver Crewmax 4x4 Off Road
    Plug and patch,or tire shopping.
    Be safe :spending:
  22. Jul 12, 2019 at 5:42 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Agree 100% - easy fix
  23. Jul 12, 2019 at 5:53 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I would plug it and swap it with the spare.
