Screeching noice when put in 4h mode?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rski85, Mar 4, 2018.
  1. Mar 4, 2018 at 12:29 PM
    Rski85
    Rski85 [OP] New Member
    So I put it in 4h mode today and it makes a screeching noise when given gas and deaccelearting , when put back in 2wd it's normal? What can it be ? 18cm tundra with 1200 miles
  2. Mar 4, 2018 at 12:34 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I'd suspect the front driveshaft or yoke assembly initially
  3. Mar 4, 2018 at 12:36 PM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t even stress out about it. Just take it to the dealer and let them deal with it.
    They should be noice about it
    netranger6 and mudslinger79 like this.
  4. Mar 4, 2018 at 12:39 PM
    Tierhog
    Tierhog SIG-AHOLIC
    15 has a valid point given your year and lack of mileage. It may have been built in 17 and sat for awhile. Even the owners manual suggests putting it in 4wd occasionally to lube things up a bit
    15whtrd and NCinCO like this.
  5. Mar 4, 2018 at 1:23 PM
    Rski85
    I know this sounds dumb, but is there a proper way to turning on 4h or 4lo? Or should I just turn the dial and go ?
  6. Mar 4, 2018 at 1:26 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Don’t quote me exactly, but I believe any speed under 45mph or so would be appropriate for 4H.
    4L is at a full stop and I believe It’s either in neutral or park.
    Someone will parrot the owners manual soon I’m sure.
  7. Mar 4, 2018 at 1:28 PM
    15whtrd
    15whtrd Mr. Blonde
    Check the card in the drivers side visor. 4hi can be engaged while in gear rolling. 4 lo in neutral
    T-Rex266 and Tierhog like this.
  8. Mar 4, 2018 at 1:38 PM
    Rski85
    So 4h can't be driven above 45mph?
  9. Mar 4, 2018 at 1:40 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    It can be driven past 45 mph.....i believe it’s below 62 mph engaging and disengaging from 2H - 4H
    15whtrd likes this.
  10. Mar 4, 2018 at 1:44 PM
    Tierhog
    Tierhog SIG-AHOLIC
    I can't imagine a scenario where I'd use 4H at 60mph lol.
    ToyotaDreaming and 15whtrd like this.
  11. Mar 4, 2018 at 1:49 PM
    Rski85
    Just making sure. It's sounds like something is rubbing or hitting metal to metal? Or something is possibly no greased?
  12. Mar 4, 2018 at 1:50 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes! 4x doesn’t help you stop.
  13. Mar 4, 2018 at 1:51 PM
    Tierhog
    Tierhog SIG-AHOLIC
    It's a theory based on the fact more moving parts are involved when in 4wd. Isolate said parts and identify cause..Thats it.
  14. Mar 4, 2018 at 1:53 PM
    15whtrd
    15whtrd Mr. Blonde
    Even if it is something that needs to be greased, which I doubt, it should not make any noise this early on. Don’t touch it. Take it in. Depending on what is have it documented.
  15. Mar 4, 2018 at 2:31 PM
    Are you sure it’s not the transfer case? Is this on a straight road on dry pavement? You can engage 4WD (high) up to 55mph. There’s no limit on how fast you go once engaged.
    Any video of this noise?
    Y0TA PR0 likes this.
  16. Mar 4, 2018 at 2:41 PM
    Rski85
    It's a perfectly smoothly road.
  17. Mar 4, 2018 at 2:51 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    You ever driven in a sand wash? Silt? That's where you need it.
  18. Mar 4, 2018 at 2:53 PM
    Rski85
    The noise gets faster / loader as I go faster. It kinda reminds of the noise when as kid I would put a baseball card by the wheel of my bike so it touches the wheel spokes
  19. Mar 4, 2018 at 3:41 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Never thought of that. I doubt I’d ever be in that position with the tundra but anything is possible. If I was at Pismo I’d RENT something and take the insurance lol
  20. Mar 4, 2018 at 3:45 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Now you have to tell us their findings. That sounds so much like a driveshaft/Ujoint issue.
    Factory robotics are damn accurate. This is something minor. I’ll stick with a lack of lubricant or faulty Ujoint.
    It is just a guess though.
  21. Mar 4, 2018 at 4:19 PM
    Rski85
    I'll call the dealer tomorrow and have them check it out. Least it's not a Chevy shake issue. Just noise and hopefully a easy fix
  22. Mar 4, 2018 at 4:22 PM
    Tierhog
    Tierhog SIG-AHOLIC
    You’ll be satisfied it’s not a Chevy on several levels.. lol.
    My Tahoe’s fell apart constantly.
    T-Rex266 likes this.
  23. Mar 9, 2018 at 7:10 AM
    Rski85
    Well got back from the dealer. It was a bent dust sleeve hitting the transfer case. It was bent on assembly. All brand new now
  24. Mar 9, 2018 at 7:50 AM
    Tierhog
    Tierhog SIG-AHOLIC
    So the sleeve was rubbing on the Tcase and no driveline issues. Well we had the region correct. Odd it would only do it in 4wd. The TC is stationary. Oh well. It’s a WIN.
    ToyotaDreaming likes this.
