Scosche Magicmount
Discussion in '2.5 Gen Tundras (2014-2021)' started by sean8787, Jan 29, 2024.
  1. Jan 29, 2024 at 2:17 PM
    sean8787
    sean8787 [OP] New Member
    Has anyone flush-mounted one of the Scosche Magicmounts for your phone to your dash? I'm thinking somewhere between the 2wd/4wd dial and the vent- but I'm curious how it looks mounted there. Thanks.
  2. Jan 30, 2024 at 9:28 AM
    rprine7983
    rprine7983 New Member
    Randy
    Slocomb Alabama
    2018 Tundra SR5
    Alpha Rex LED Headlights, Console Gun Safe
    20240129_172059.jpg This is what I have. Works great for me
    Midsouth Jacket and MedCityMoto like this.
  3. Jan 30, 2024 at 9:40 AM
    sean8787
    Awesome, thank you. Looks like it fits there pretty well.
  4. Jan 30, 2024 at 10:00 AM
    rprine7983
    Randy
    Slocomb Alabama
    2018 Tundra SR5
    It fit great. Cleaned the area good and hasn't come off. Been on for 2 years now. Never had a problem with the phone falling off or anything.
    sean8787[OP] likes this.
  5. Jan 30, 2024 at 10:12 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Have the same. Almost in the same exact location. I mount my tablet on it and it holds firm.
  6. Jan 30, 2024 at 10:15 AM
    sean8787
    I'm thinking about flush mounting it on mine. Is yours mounted flush or does it mount via the little plastic bracket like this one does?
  7. Jan 30, 2024 at 10:52 AM
    jdg1982
    jdg1982 New Member
    Mine like the one in the picture.
    sean8787[QUOTED][OP] likes this.
  8. Feb 1, 2024 at 6:08 AM
    seydou
    seydou Distinguished Member
    Here is my solution. It puts the phone closest to eye level without blocking your field of view. It is very strong/stable and will hold my phone or tablet without movement, while allowing the ability to adjust the angle a fair amount.. It is easily installed or removed without damage to dash. And it does not block the use of a vent. Only downside is that it is a bit expensive.
  9. Feb 2, 2024 at 1:06 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    What kind of a phone do you have? Do you think it can hold the bigger phones like a Samsung S23 Ultra?
  10. Feb 2, 2024 at 1:11 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    This is exactly what I had on my 2018, and I am planning on doing the same on the 2022. It worked great.
    At first I had it mounted a couple inches higher, but that placed the phone's camera right in front of the air vent, which is not good when you run the heater.
    Where it is shown in the picture worked perfect.
  11. Feb 2, 2024 at 1:18 PM
    Boerseun
    Ferdie
    Sarasota Florida
    I found a photo of mine.
  12. Feb 2, 2024 at 1:20 PM
    Boerseun
    Ferdie
    Sarasota Florida
    The only downside of this (and I am also in Florida so it doesn't happen much, but for others in colder climates) is when you run the heat then you blow that directly on the phone which is not good.
    Just have to keep that in mind and put it elsewhere the 3 days a year we run heat.
  13. Feb 2, 2024 at 1:24 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Same place I've got mine, good fit.
    Boerseun[QUOTED] likes this.
  14. Feb 2, 2024 at 2:27 PM
    ATXHusker
    ATXHusker New Member
    Chad
    Austin TX
    2016 TRD Pro CM Quicksand
    Ranch Hand brush guard, TRD rear sway bar, TRD air filter, Husky front mats, Weathertech rear mat, LED interior lights, tow mirrors, Salex console organizer, key ring light mod, AJT key fob, Gator bed cover
    I had one and phone kept falling off, def not worth it so I went with the Rago dash mount with Ram phone mounts, so much better!
  15. Feb 2, 2024 at 4:12 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Nah, not at all. The vent is fully closed when the phone is on it. And the iPhone has a built-in thermal shutdown which has never been triggered. The phone gets a little warm, but it ain't made out of butter.
  16. Feb 3, 2024 at 10:39 AM
    seydou
    I have a S22+ and it holds it solidly, as it does my Galaxy tablet.
  17. Feb 3, 2024 at 10:41 AM
    seydou
    Personally, IDGAF about the phone, but I do not want to eliminate one vent from providing me with heat or cooling.
  18. Feb 3, 2024 at 1:08 PM
    sean8787
    I appreciate everyone's replies. I ended up going with the flush mounted version that works with my Magsafe phone and case.
    Since it's a flush mounted version, I didn't have the option of mounting it on the lower portion (right above the 2wd/4wd switch), as the phone would interfere with that switch.
    The one negative is that I'll have to close that one vent when the heater's on. But overall, I feel good with this clean and easy option. Seems to have plenty of strength too.
    Boerseun likes this.
  19. Feb 3, 2024 at 4:12 PM
    Gene_in_FL
    FLORIDA
    FFS, man. There are ELEVEN VENTS in a double cab.
  20. Feb 4, 2024 at 8:39 AM
    seydou
    So? Only two of them are designed to hit the driver perfectly in the upper torso/face. Why would I give up one of these for an inferior phone mount? TEHO
  21. Feb 10, 2024 at 3:42 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Can you turn the phone sideways when the heat is on? It might be enough to get it out of the way of the vent.
  22. Feb 10, 2024 at 4:27 PM
    sean8787
    Yes, that's a good point. If you do that, it's not 100% clear of the vent, but pretty dang close. And you can point the vent away from the small part that is covering it.
