School me on tss
Discussion in 'Suspension' started by Blkdmax, Mar 19, 2021.
  1. Mar 19, 2021 at 8:08 AM
    Blkdmax
    Blkdmax [OP] New Member
    Tennessee
    2021 Cement CrewMax 4x4
    My last tundra was a 2017. It had 6112s and 295s. Obviously didn’t have to worry about tss. Well I’ve ordered a 2021 and I plan to lift it as well and go either 285s or 295s. Can someone break it down for me the dos and don’ts of lifting a tundra with tss? Essentially just make sure I have the rear higher???
  2. Mar 19, 2021 at 8:15 AM
    Mine is level one 4/2 and no issues with TSS.
  3. Mar 19, 2021 at 8:17 AM
    timsp8
    NY
    Just don’t get a bumper or anything that will cover the sensor. I have a lift and no issues. I think some that had issues said they didn’t have any rake.
  4. Mar 19, 2021 at 8:27 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I think you can go to the dealer and ask them to remove it and reflash the software if you plan on heavily modding your truck. They have a waiver or form you fill out and they remove it. They also put a sticker on your car saying it was removed voluntarily or something.
  5. Mar 19, 2021 at 8:51 AM
    Blueknights75
    Ron
    Clayton, NC
    Some have issues after leveling or lifting their trucks. I have had no issues with my tss system after installing my leveling kit with 295s. Truck is perfectly leveled with zero rake. If you do have issues after installing your lift you can just have the system recalibrated but you may not have any issues.
  6. Mar 19, 2021 at 12:28 PM
    Blkdmax
    Tennessee
    Awesome thanks guys.
    Probably going to go with a Fox setup up 2/1. Not looking to get too much lift.
  7. Mar 19, 2021 at 1:59 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    You’ll be fine, should have no issues at all. I put on a 3/1 level and had no issues. The only problem I had was with a front camera I mounted in my grille sometimes causes TSS errors.
    Blkdmax[QUOTED][OP] likes this.
