Scanner can't read ABS code
Discussion in 'General Tundra Discussion' started by Cherrybomb, Nov 5, 2020.
  1. Nov 5, 2020 at 8:52 AM
    Cherrybomb
    Cherrybomb [OP] New Member
    Greg
    07 tundra 4 door 4x4
    Hi all , my kid got an 07 Tundra 4.74 door for next to nothing but dash is lit up . Brake light , (abs), 4hi &4 low flash,tpms and spedometer doesn't work at all . Snap on scan tool reads eng/trans but when I try read the (abs) codes ,the scanner can't comunicate .I do have power to the abs pump ,12v and a good ground . Will a bad (abs) pump stop comunication with a scan tool ? I broke the pass side front abs sensor after the fact but refuse to pay $200 a side until i know this truck has a chance and the ecu is not pooched
    YardBird likes this.
  2. Nov 5, 2020 at 1:25 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  3. Nov 5, 2020 at 1:33 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome from PEI!
    Check the relays/fuse for the ABS.
  4. Nov 5, 2020 at 9:01 PM
    Cherrybomb
    Greg
    Sorry thats first thing I did all fuses and relays good .I should have stated that I tried already.
  5. Nov 5, 2020 at 9:28 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm not sure an OBD2 can read ABS codes, correct me of I'm wrong, but it has to be plugged in directly to the ABS module???
    Tundyfundy likes this.
  6. Nov 5, 2020 at 10:02 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That would be a big ole’ negative. Techstream will connect and read ABS codes via the OBDII connector, and a Snap-on scanner should be able to as well.
    That said, be sure the appropriate scanner software versions are loaded for Toyota ABS before assuming it’s an issue with the truck / ABS module.
    glowblue likes this.
  7. Nov 6, 2020 at 2:37 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    ^This. Not all scan tools/software can read all ECM data. ABS info usually requires special scan tool software to read codes beyond just the general OBD2 codes.
  8. Nov 6, 2020 at 8:15 AM
    Cherrybomb
    Greg
    I've never had a prob gettin into (abs) on toyotas or any other car , I will try wifes 2010 corola to make sure . That's something I didn't think of thanks
    landphil likes this.
  9. Nov 6, 2020 at 11:25 AM
    Welcome from NY.
    Do you have a aftermarket remote starter installed?
    If so unplug it and then try plugging in the reader.
  10. Nov 6, 2020 at 2:26 PM
    Cherrybomb
    Greg
    No mods whatsoever ..not even a bumper sticker lol . We got it off an older gentleman who bought new car and used it as a yard truck last year he had it
  11. Nov 6, 2020 at 2:27 PM
    Cherrybomb
    Greg
    Although it does seem to draw battery overnight sometimes ...nothing is obvious
  12. Nov 6, 2020 at 2:44 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    How old is the snap on scanner and does it have an update to read your model year? I've got a modis here that can scan up till 2012. My autel will do up to 2018. They will read more ecu codes on just about anything but newer abs, bcm, tcm, etc modules may not be supported.
  13. Nov 6, 2020 at 9:18 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    My only other idea is to use the jumper method in the OBDII connector to try to read the blink codes via the ABS dash light.
    Would help determine if the ABS ECU is powering up and alive and well with a circuit fault, or if the fault IS the ECU or power / ground supply to it.
  14. Nov 6, 2020 at 9:52 PM
    Cherrybomb
    Greg
    Ok good thinking landphil. Also the scanner is good to 2011 .never counted the light flashes on a old 2 ,did the paperclip on the obd 1 same thing. Whats pins do I jump ?
  15. Nov 6, 2020 at 9:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’ll try to dig it up for you.
  16. Nov 6, 2020 at 10:56 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  17. Dec 13, 2020 at 2:44 PM
    Cherrybomb
    Greg
    Update : picked up a used abs module for $300 plugged in and all my problems are now gone ! Scanner communicates and abs ,4x4, and spedo works now .tha ks for all the ideas and fast replys
    blackdemon_tt likes this.
