ScanGauge now monitors tire pressure and temps
Discussion in 'Off-Topic Discussion' started by Tundra234, Feb 25, 2020.
  1. Feb 25, 2020 at 6:49 AM
    Tundra234 [OP] New Member
    The Dude and tunyota like this.
  2. Mar 15, 2021 at 8:06 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Greetings @Tundra234 thanks for posting this information. I configured our ScanGauge 2 to display the Transmission fluid temperature today upon discovering your post. Do you have a ScanGauge and did you get an opportunity to configured it to display tire pressures and temperatures? Cheers!
  3. Mar 15, 2021 at 8:23 PM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    That's awesome, thanks! Now if they made oil temps and pressures available, that'd be tits!
  4. Mar 15, 2021 at 9:33 PM
    tunyota
    The Dude likes this.
  5. Mar 15, 2021 at 10:52 PM
    tunyota
    Upon reviewing the TechStream vehicle diagnostic report, I am not seeing an oil pressure parameter listed. This is in line with @JohnLakeman's comment (https://www.tundras.com/threads/oil-pressure-gauge-with-pic.12351/page-2#post-1166842).
    Out of all the parameters listed on the report, I am surprised to see there is nothing else I would really care to monitor on a regular basis. I am going to configure the ScanGauge 2 to monitor tire pressure as mine has the (4.42 firmware). Too bad I can't monitor tire temperature as that requires (4.5+ firmware) and don't see myself paying $25+ to have it sent in to be updated.
    At least there is a dedicated engine oil pressure gauge within the Instrument cluster (w/ tachometer). https://www.toyota.com/t3Portal/document/om-s/OM34458U/pdf/OM34458U_edited.pdf
    According to the Haynes manual, the oil pressure at idle for 1st Gens should be 4-5 PSI for both v6 and v8 engines.
    It seems fairly common to feel as if the oil pressure is a little low for comfort but from what I've found online it's normal and within the expected range. https://youtu.be/iLqYs4aIErk
    I really enjoy watching that this guy's videos especially when it comes to working on the 2UZ-FE engines and associated drivetrain.
    Also, I would imagine the engine coolant and oil temperatures would be relatively consistent along with transmission fluid temperature given their proximities with some degree of variance considering external air temperature and engine/transmission loads. Glad I am now able to monitor the transmission fluid temperature to confirm this theory.
  6. Dec 29, 2021 at 10:51 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    I already have a Scan Guage II. Anybody here have the codes I need to make it show trans temp and coolant temp?
  7. Dec 30, 2021 at 5:44 AM
    Blue Thunder
    Washington
    I think the engine coolant temp is included in the pre-programmed parameters. As for the transmission, do some searching here on the forum. The coffees are posted in a few threads already
  8. Dec 30, 2021 at 6:09 AM
    They are listed on the SG site.
