SC dyno number comparison thread
Discussion in 'Performance and Tuning' started by e30cabrio, May 20, 2023.
  1. May 20, 2023 at 1:27 PM
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    '13 Sequoia, 2.3" pulley, 650 FIVE-O injectors, Deashcwerks 300, Aeromotive FPR, Dirty Deeds catback 1000 feet elev, hub dyno.
  2. May 20, 2023 at 1:29 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Your numbers are very typical on a Dyno jet or Dynocom
  3. May 20, 2023 at 1:31 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Magnuson, 2.0" pulley, 2600ft elevation, 9.6psi, 80F, Magnuson intake, Magnaflow catback, stock everything else, 10.5 AFR, Sniv Speed tune, 35s on stock wheels
    490whp/572tq, Superflow chassis dyno
    Crayon graph:
  4. May 20, 2023 at 1:52 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Probably should note wheel tire combo as that will play a factor. I expect less wheel hp than most of y’all.
  5. May 20, 2023 at 1:57 PM
    e30cabrio
    Added hub to my first post.
    Don't have one of the Tree with the hub connected.
  6. May 20, 2023 at 4:20 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Harrop w/85mm pulley, Prospeed intake, RCF throttle body, Prospeed fuel system w/750cc injectors, JBA long tubes, Gibson dual 2.5" exhaust
    Hub Dyno at Prospeed Houston
  7. May 21, 2023 at 12:11 AM
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    Prospeed/Arrow forged shortblock/ARP hardware
    - Harrop 2650 supercharger w/ 65mm pulley
    - Prospeed 4.5" race intake system
    - RCF Throttle body, w/ adapter
    - XAT crank balancer w/ 7" lower and Griptec upper
    - Prospeed complete E85 flex fuel system with billet rails and twin 450 pumps, 1000cc injectors, Aeromotive FPR
    - Radium catch can system
    - American Racing headers/midpipes
    - Corsa 3.0in exhaust ( with the power on this exhaust system the cats blew out)
    - Prospeed Motec package with D3 PCM flash
    - XAT ported oil pump
    - Prospeed premium transmission valve body
    - Powertrax differential
    - Prospeed/BTI 4.3" touch screen gauge display
    - Solid Offroad motor mounts
    - Prospeed full shield kit
    - SDHQ Traction bars
    Truck was tuned on the Mustang 1100SE** roller w/ 18x9 Method 305s, on a LT325/65R-18 FALKEN WILDPEAK A/T3W E tire, approx 106lbs/ tire. Truck made a little over 705/663 @126ft above sea level in Hoston heat.*Stock gears*
  8. May 21, 2023 at 5:39 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you at any point during fine tuning experienced extended cranking when the engine was warm (run to operating temperature then left to sit for 30 minutes or more) with those injectors? ExtendedCrank.xlsx - Google Sheets
  9. May 21, 2023 at 7:20 AM
    Winks4x4Toy
    Maryland
    I've noticed it on cold start ups. I'll let you know this weekend. So the truck gets warmed up to proper Temps... than shut it down, wait 30 minutes and see if I get the extended cranking? I'm trying to find the spark plugs we used so you have that info as well. What's your end goal with the collected info?
  10. May 21, 2023 at 7:59 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Correct. The sit time can range from 30 minutes to 12 hours, at least in my experience it's happened to me that long after having been at operating temperature. Some of us are having the issue with the 650 to 750cc injectors, mine seems to be the worst (could just be my perception though). In my case the engine will not start on the first attempt. On the second it will start but it will blow black smoke from the tailpipe (so adjust your sideview mirror to watch for that) and smell rich. I don't want to sidetrack this post too much as it's been posted about in the General S/C thread. I simply noted your mentioning injector size used here, but not in other posts so I asked here. If you happen to experience something worth mentioning, you can DM me as well. I'd be curious what software was used to tune your truck and if your tune happens to be unlocked so that you might be able to examine some of the tables/maps. Thanks.
  11. May 21, 2023 at 8:30 AM
    Winks4x4Toy
    Maryland
    Copy all, will let you know the results. Tuning was a combination of the Motec and HP Tuners. I'll be downloading the motec software today on my laptop so I can connect and view.. tables/maps/logs etc.
    Saltyhero13 and Wynnded[QUOTED] like this.
  12. May 21, 2023 at 9:08 AM
    AZBoatHauler
    So.Arizona
    :bananadead::bananadead::bananadead:
  13. May 31, 2023 at 7:59 PM
    Winks4x4Toy
    Maryland
    So no real issues to the extent of what your having, truck turns over a second after cranking(after at least 30 minutes from the truck being at operating temps). I get a normal single puff of condensation that looks like white smoke but it isn't. I forgot to hook the laptop up to the truck, I'll attempt in July and see if I can view some of the tables/maps for you.
    Wynnded[QUOTED] likes this.
  14. May 31, 2023 at 8:18 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Much appreciated. :hattip:
    Winks4x4Toy[QUOTED] likes this.
  15. Jun 1, 2023 at 8:05 AM
    snivilous
    SW UT
  16. Jun 1, 2023 at 8:28 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this is 3 stages of tuning. 2020 1794 4x4
    untuned stage 1 85mm pulley
    tuned stage 2 80mm pulley + 650's
    my intake is stock...like stockity stock. TRD exhaust. stock tires
    I did a retune with HPTuners (Peitz Performance)...and got similar stage 2 numbers....just can't locate the damn graph.
    Winks4x4Toy, snivilous and reywcms like this.
  17. Jun 1, 2023 at 8:34 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I can see from all y'all's graphs...my intake makes the power stop @ 5k....y'alls keeps growing.
    testament to my small girth intake.
    Saltyhero13, Winks4x4Toy and reywcms like this.
  18. Jun 1, 2023 at 10:00 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Waiting on exhaust and retune. Hopefully have the Kooks on before July :rolleyes:
  19. Jun 1, 2023 at 10:42 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    dyno.jpg Magnusson with 2.3 pulley, PS intake, RFC Tbody, stock header, 750cc injectors and 450 fuel pump. Wheels 22x12 and 305 tires.
    Winks4x4Toy, reywcms and snivilous like this.
  20. Jun 1, 2023 at 10:44 AM
    Fastlane47
    Maryland
    2018 Platinum
    I feel you, waiting on AR headers myself.
    Winks4x4Toy and V10Ace[QUOTED] like this.
  21. Jun 1, 2023 at 10:46 AM
    I could only imagine how much fun your truck is on the street/track.
  22. Jun 1, 2023 at 11:07 AM
    AZTundra
    Paul
    Phoenix, AZ
    2017 Crewmax FFV, Magnuson Supercharger, 2.3" pulley, green injectors, Magnuson intake, stock FFV fuel pump, TRD dual exhaust, 295/70/18 tires, Dyno Comp tuned, 2,165 elevation.
  23. Jun 1, 2023 at 1:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Stage 2 Harrop. 85mm + 650cc + 4.25" ID custom "Frankenstillen" Intake + RCF TB + SW LTHs 532HP/506TQ. Dynojet roller. Will post "proof" later.
  24. Jun 1, 2023 at 1:34 PM
    Saltyhero13
    Worth the wait. Headers get a perfect score of :bananadead::bananadead::bananadead::bananadead::bananadead: out of :bananadance::bananadance::bananadance::bananadance::bananadance:.
  25. Jun 1, 2023 at 2:02 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    What size tires? Good numbers for the 85mm pulley
    Saltyhero13[QUOTED] likes this.
  26. Jun 1, 2023 at 2:16 PM
    Saltyhero13
    Ah thank you. Pretty happy with those numbers too. Probably wont keep those numbers for long but currently running the stock P275/65R18s Michelin AT2.
  27. Jun 1, 2023 at 2:19 PM
    Saltyhero13
    Blue is Stage 2. Red is w/LTH and retune. Not big gains.
    I don't want to brag but I may have picked up .5 MPGs.
    My run before the intake fuckery was 520/500. My air is straighter now....I promise.
  28. Jun 1, 2023 at 2:39 PM
    snivilous
    SW UT
    It's weird that e30 and I make massively more torque than all but Winks with his completely built setup. If it wasn't for the fact there was two of us with nearly identical torque numbers I'd say something was a fluke (guess it could be two flukes?). And the only real similarities between us is the Magnuson and Magnuson intake, but plenty of you guys have one of those and are all consistently at 500ft-lbs +-10. And hell, in my case I'm making some of the lowest horsepower of the group, but tons of torque. Any thoughts?
  29. Jun 1, 2023 at 2:49 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Seems similar when I was doing the supercharged cobras. The smaller roots blower spun harder would always make huge tq as they lost hp efficiencies up top.
  30. Jun 1, 2023 at 2:51 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’m always a bit skeptical when the tq appears to come from the initial hit on the dyno
    not doubting. Just sayin it ain’t natural for a motor to produce tq that way
    maybe it’s the way the dyno run is set to start
    Steve morris engines did a great video on dyno anomalies
