SC 2016 Dyno'ed on 38s
Discussion in 'Performance and Tuning' started by texasrho83, Feb 26, 2023.
  1. Feb 26, 2023 at 6:29 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dan dynos this sick 2016 SC'ed Tundra on 275r55x20 tires first then swaps over to 38s for comparison.
    It's crazy how much hp loss occurs.
    Yes, the truck has 5.29s
    https://youtu.be/qILyFoGgH6k
    Saltyhero13 and snivilous like this.
  2. Feb 26, 2023 at 8:23 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Crazy.
    This is the most accurate third party testing I’ve seen since 2014. Those are the exact numbers + - 5 on Hp and tq with everything he is reciting.
    my truck did exactly all of the above with a trd supercharger.
    texasrho83[OP] likes this.
  3. Feb 26, 2023 at 8:27 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you run 38s on your Tundra, Keith?
    dirtydeeds[QUOTED] likes this.
  4. Feb 26, 2023 at 8:35 PM
    dirtydeeds
    Keith
    USA
    Ha! Forgot to mention that aspect. I tested 33’a and 35’s. Both lost 40 Hp!! It’s not the rotational weight losing the power, it’s the way the ecu ‘sees’ the load. By slowing down wheel speed in relation to the throttle position the ecu pulls timing and it adds fuel which is what is causing the Hp loss.
  5. Feb 26, 2023 at 8:41 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If only there was a way to fudge the ECU's read on the load. Sorta like the way one plays with the tire size and gear ratio on the Hypertech calibrator.
