Saw this in the 4R forum...he doesn't like the metal housing
Discussion in 'General Tundra Discussion' started by Tundra234, Nov 17, 2022.
  1. Nov 17, 2022 at 5:54 PM
    Tundra234 [OP] New Member
    ColoradoTJ and Tundra Dude 45 like this.
  2. Nov 17, 2022 at 6:58 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Guess I need to toss my plastic housing instead of using it as a backup
  3. Nov 17, 2022 at 7:33 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    I like this guy, he might even convince me to buy an OEM plastic housing and swap back.
    Dawoofles likes this.
  4. Nov 17, 2022 at 7:54 PM
    Dawoofles
    Santa’s Village
    Yeah, but if you run the oil tests and it says it’s good, I wouldn’t think that one part is going to cause your engine to fail. What’s next you can’t add a high output alternator or swap to LEDs?
  5. Nov 17, 2022 at 8:43 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    So... definitely do NOT remove the center pipe from the plastic housing?
    BravoDeltaRomeo likes this.
  6. Nov 17, 2022 at 11:12 PM
    Dawoofles
    Santa’s Village
  7. Nov 18, 2022 at 6:11 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I actually have the dorman! :rofl:
    The first oil change I did when I bought my car was missing the middle pipe so I went to Autozone and bought the dorman kit for the middle pipe. Have been fine for the 45k miles I have put on the car so far.
  8. Nov 18, 2022 at 6:27 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    According to the video. Many have done it without issue.
    Toyota videos will never condone or encourage using other aftermarket parts or even swapping non vehicle specific Toyota parts. 8/10 tundras on here have added the driver side grab handle, which I assume a Toyota tech would also advise again. And before some says "that's different, it's cosmetic". Yes, but a cosmetic.accrssory that can do lethal damage and you are messing around near the air bag, is a higher overall risk vs doing some financial damage to an engine.
    Most people will be able to make the switch carefully and properly with the housing into the new aluminum or.metsl cap, not everyone. I would like to think, most of us would not make the switch if we damaged the metal insert upon removal.
    It was an interesting video though, with a lot of good info into scaring hacks from attempting to mess around with it.
  9. Nov 18, 2022 at 10:16 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Sounds like he advises against swapping to the metal but only because of the metal pipe in the middle. I did mine very delicately and don't plan on doing it again unless it comes loose. I didn't factor in the pressure of the bypass valve though and thinking back on it, I think I swapped in my old spring as well so mine should be working identically as the plastic one did.
