Sanity Check!
Discussion in '1st Gen Tundras (2000-2006)' started by Dirtrcr13, Jan 27, 2023.
  1. Jan 27, 2023 at 1:00 PM
    Dirtrcr13
    Dirtrcr13 [OP] New Member
    Jerm
    03 Tundra// 16 4Runner
    Mama wants a new ride. Good news for me, I get the 4Runner!
    But here is what is rolling around ion my head, so asking for y'alls input to decide...
    Dealers want to give me 3k for for my 03 AC. I understand they need to make money on trades. So if I sell private party, this is what Im looking to get... Minimum 6K. Im going to post it for 7K and see what happens. As gearheads/ enthusiasts, would you think this is a fair asking price?
    The vehicle:
    3rd owner. Bought it in Arizona in 2007 with 42K on it. Spent 11 years in Virginia and 5 in Oklahoma.
    2003 Access Cab 2wd SR5 (built 12/02) with 220K miles.
    The good:
    Mechanically immaculate. Oil changed every 5k with Toyota filter and full synthetic oil.
    Tranny fluid done every 15K with Toyota Type-IV AFT.
    Rear diff done every 30K with synthetic 75-90W.
    Timing belt, outer drive belt. water pump, cam and crank seals done 60K ago.
    Valve cover gaskets (seeping a little not leaking/ making a mess) and plugs done 10k ago.
    Not a leak anywhere ( oil, tranny, diff, P/S or coolant)
    All 4 shocks and rear full rear brake job last spring (maybe 8k ago)
    New tires put on in December
    AC will freeze you out in the Oklahoma heat
    Everyone loves the crotch vent below the steering wheel!!!
    No rips in the interior, seats are not work out, minor wear/ stains on the carpet
    NO RUST on body or frame other than light surface corrosion in some of the paint scratches (very minor)
    Up to date on all recalls/ warranty work.
    Never been in a major accident. Did have a few fender benders/ parking lot dings which resulted in the rear bumper, front bumper skin and a fender replaced and some trim pieces. No airbags deployed or anything major.
    The BAD:
    Its a 20 year old vehicle
    Typical Toyota paint. Hood and roof look like hell. But no rust!
    She has a CEL. Its a O2 Sensor Heater. Ive had this code since 2015. Im not replacing an O2 sensor for the portion that only works for 5 or so minutes upon start up. Sensor portion is fine and regulates like it should. I scan it every oil change to make sure it hasnt died. So far so good!
    So do yall think Im crazy for asking 7K?
    No, I dont "need" to sell it but I wont have a use for it?
    Taco-Spike likes this.
  2. Jan 27, 2023 at 1:04 PM
    Taco-Spike
    Two Trucks
  3. Jan 27, 2023 at 1:08 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’m surprised the dealer would give you $3k for a hood and roof that need repaint. My gut says you won’t get more than $5k, but who knows?
    It wouldn’t sell in my neck of the woods without 4wd due to the snow.
    Dirtrcr13[OP] likes this.
  4. Jan 27, 2023 at 1:12 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Your pricing seems fine. I'd probably just throw an O2 sensor in it just to get rid of the light, even though you know it's not a big problem other people will look at is as neglect.
  5. Jan 27, 2023 at 1:43 PM
    Aerindel
    Aerindel New Member
    Montana
    I'd pay that, if the light was out. The problem with CELs is that you never know if its REALLY just the sensor, or something much more expensive and a PITA so I'm highly skeptical about those as I've been burned before.
  6. Jan 27, 2023 at 1:54 PM
    shifty` Bohannon Bohannon Bohannon Bohannon
    This ^^
    Let's be realistic: If the roof doesn't look like the hood, and you paid a shop $500-600 to re-paint the hood, you could for sure get $7k depending on your local market.
    O2 sensor heater doesn't necessarily mean O2 sensor fail, it could be other issues. But again, if you bought the correct DENSO replacement and swapped, you could potentially eek out twice or thrice what you pay for the DENSO sensor. I personally always like to replace upstream/downstream at the same time, though.
    Dealership will always offer 2x-3x less than what they think they'll net at auction on something. They probably think it'll pull $6k at auction, and are offering you $3k. Likewise, private quick sale is probably around $6k, assuming frame is clean.
  7. Jan 27, 2023 at 4:22 PM
    Dirtrcr13
    Jerm
    Agree and understand. CEL is always one of the first things I look for in a used car. Thats the reason I scan it every oil change just to make sure. I did pull the sensor a couple years back just to make sure I could get it off. Reinstalled and anti seazed the studs. Does that stuff go bad after a decade:rofl:
  8. Jan 27, 2023 at 4:25 PM
    Dirtrcr13
    Jerm
    Hood is really the worst of it. Bad part is, that is the first part you see:( Roof is more oxidized than anything. Lost its clear coat many moons ago.
    Im really trying not to sink money into it since Im trying to sell it. But it takes money to make money right?!?!
  9. Jan 27, 2023 at 7:48 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Old man tan, 2wd, needs paint work, and is throwing a code? I would just put it up for 5k firm and turn it quick, screw doing any work to it. You should be hitting the market at the right time for tax return money.
    ETA: Real sanity check should be ditching a Tundra for a 4runner
    shifty`, JasonC., bmf4069 and 2 others like this.
  10. Jan 27, 2023 at 9:02 PM
    Sunnier
    Sunny
    San Diego, CA
    Hard to offer to buy your truck when you don’t say where you are. :boink:
    Aw, man, I just saw it’s 2wd. Worth more than 3k. I like the advice above, list at 5,500 then take 5k.
    Aerindel likes this.
  11. Jan 27, 2023 at 9:04 PM
    Dirtrcr13
    Jerm
    Oklahoma City...
    Wasnt really trying to sell on here, but you right
    txagg and Sunnier[QUOTED] like this.
  12. Jan 27, 2023 at 9:54 PM
    Aerindel
    Aerindel New Member
    Montana
    Same, that cuts the value significantly.
    txagg likes this.
  13. Jan 28, 2023 at 3:20 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    8 years in open loop mean your cats are full of gunk and your knock sensor was disabled. These are expensive problems.
  14. Jan 28, 2023 at 3:27 AM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    I think your right on track for the $$$ ,trucks always hold there value
  15. Jan 28, 2023 at 5:24 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    How much of a hurry is Mama ?
    Meaning, have you got a month to either dicker with another dealer for say $3500.
    Last timing belt was @ 160K, possible 3 years before new needed. From birth to 160K was a timing belt put on ?
    I'd definetly have to personally see the frame since it was on the East coast a certain numbers of years.
    If what I see and IF what you say maintenance wise is kosher and IF you were in my neck of the woods, we'd be dickering around $4500.
    I'd want to know what that carpet stain came from driver side passenger door at door opening bottom area.....spillage, water leak ?
    What my thoughts are on what I'd have to dish out in my neck of the woods....
    • All O2 sensors if no code indication/readings point to Cat replacement $500
    • Roof $500
    • Hood $500
    • Bumper $500 plus cost of new bumper....unless you throw in the below hood ornament
  16. Jan 28, 2023 at 6:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Pffff, we don't need no stinking hood clear coat.
  17. Jan 28, 2023 at 12:13 PM
    Dirtrcr13
    Jerm
    So funny thing...
    Dealer called and offered 5k. Which was my bottom dollar. So..... Yeah. Its now sold as is! Got to love the end of the month panic!!!
    Thanks for yalls inputs!
    KNABORES, txagg, dbittle and 4 others like this.
