Sanding grits for prepping bare metal?
Discussion in 'Detailing' started by Wahayes, May 16, 2022.
  1. May 16, 2022 at 7:16 AM
    Wahayes
    Wahayes [OP] Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Not sure if this is the right spot but it seemed closest to what i need. Trying to prep a metal bumper for paint. Did all my welding and grinding, but.my question is do i need to step up flap discs in grit just like sand paper? I threw a coat of primer on to keep it from rusting until i can finish but it also served as a guide coat and i have some high a low spots from the grinder. Guessing since i was using a 40 grit disc step up to 80 then 120 and try again? Should i use bondo as a skim coat as well? Any help is appreciated, painting isnt really my thing
  2. May 16, 2022 at 7:20 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Are you talking about the chrome pieces or an aftermarket bumper? I've not seen good long standing paint on chrome but it is all in the prep.
  3. May 16, 2022 at 7:21 AM
    Wahayes
    Will
    2017 tundra limited
  4. May 16, 2022 at 7:29 AM
    If you have a few low spots, thin layer of bondo, dry, sand to a smooth finish, prime, paint.
    Saltyhero13 likes this.
  5. May 16, 2022 at 7:32 AM
    Wahayes
    Will
    2017 tundra limited
    I have some grinder marks that are low spots where i had to make another weld pass and smooth down. And just general grinder swirl. I was using a 40 grit flap disk and a grinding wheel. Should i go over with 80 grit and 120 flap disk, then prime again? Or should i hit it 80 ,120, bondo then 120 again and prime?
  6. May 16, 2022 at 7:34 AM
    Wahayes
    Will
    2017 tundra limited
    My ironworking back ground was structural not ornamental so prepping metal for a fine finish is not something i ever did. Lol
    gosolo and Saltyhero13 like this.
  7. May 16, 2022 at 8:10 AM
    Retired...finally
    My experience is 180 grit is enough for primer to fill in with a few coats. First coat of primer should be a self etching primer. Napa sells a Martin Senour primer in a spray can. I highly recommend this followed with a 240 grit wet sand.
    Wahayes[OP] likes this.
  8. May 16, 2022 at 8:13 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Will, the work you have done on this bumper is beautiful. Sorry I’m unable to help with the paint issue. My recommendation would be to have it powder coated, which would lead me to ask the shop for their thoughts.
    Please post pictures of this when it’s finished and mounted on your truck.
  9. May 16, 2022 at 9:13 AM
    Wahayes
    Will
    2017 tundra limited
    Im trying to keep it simple on paint. I probably wont go the powdercoat route just because when it gets banged up, i want to be able to just rattle can touch up. Im going to be spraying with rustoleum professional gloss black with my hvlp gun, then when it needs touch up rattle can as needed
    Retired...finally likes this.
  10. May 16, 2022 at 9:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Flap disc on an angle grinder? I would start flat sanding. You’ll never get it completely flat with a circular grinder. It might look smooth but the waves will come out when it’s painted.
    831Tun likes this.
  11. May 17, 2022 at 8:59 AM
    Wahayes
    Will
    2017 tundra limited
    Hit with 80, 120 then a bondo glaze where it needed it and 2 coats hi build primer. Going to sand when dry with 220, then 3rd primer coat , sand agin and then paint
  12. May 17, 2022 at 9:26 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I would suggest using Steel It over the Rustoleum. It is a bit spendy but holds up well and easy to touch up later.
